Another Alternative to get PWM Ports On
I got a port in my relay box without use and i need to know if i can do something in the code to get lights on when i turns on the port in the portal or my iphone app.
My Leds are hooked and programed in the code but if i need to verify something in the tank, i needs to get the lights on or something and i dont have how to do it.
Something like,
If port5 gets on, get pwm channels at 100%
That relay its always off, just get that in the code if i need it like make mantenance or move corals or get out a fish!! Thanks
Something like,
Re: Another Alternative to get PWM Ports On
Try adding port5 to the lights on ports:
ReefAngel.LightsOnPorts = Port5Bit;
I do that but the ports only shuts off when they are on but when are off, they dont turns on back.
int avgph[10];
unsigned long totalavgph=0;
byte avgindex=0;
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port3Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port3Bit;
ReefAngel.OverheatShutoffPorts = Port7Bit ;
for (int a=0;a<10;a++) avgph[a]=analogRead(PHPin);
totalavgph=0;
avgph[avgindex]=analogRead(PHPin);
avgindex++;
if (avgindex==10) avgindex=0;
totalavgph+=avgph[a];
totalavgph/=10;
totalavgph=map(totalavgph, ReefAngel.PHMin, ReefAngel.PHMax, 700, 1000); // apply the calibration to the sensor reading
totalavgph=constrain(totalavgph,100,1400);
if (totalavgph <= 644) ReefAngel.Relay.Off(Port3);
if (totalavgph >= 655) ReefAngel.Relay.On(Port3);
// ReefAngel.CO2Control( Port3,644,655 );
ReefAngel.StandardFan( Port4,798,811 );
ReefAngel.StandardLights( Port7,0,30,14,0 );
ReefAngel.WavemakerRandom( Port6,600,120 );
ReefAngel.StandardLights( Port8,12,0,2,0 );
ReefAngel.PWM.SetDaylight(PWMSlope(17,0,0,3,0,12,3,0));
ReefAngel.PWM.SetDaylight(PWMSlope(18,30,22,33,12,50,3,ReefAngel.PWM.GetDaylightValue()));
ReefAngel.PWM.SetActinic( PWMSlope(15,0,1,0,0,70,60,0) );
ReefAngel.Portal( "Bo0sted_Rafi" );
byte x = 6;
byte y = 2;
byte t;
char text[7];
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.DrawText(0,255,3,17," Rafi's 75 Reef");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 90, "--------------------");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 126, "--------------------");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 93, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 103, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 113, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 123, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 93, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 103, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 113, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 123, "|");
ReefAngel.LCD.DrawText(0,255,10,30,"Display");
ReefAngel.LCD.DrawText(COLOR_BLACK, 255, 10, 40, text);
ReefAngel.LCD.DrawText(0,255,90,30,"CA pH");
ReefAngel.LCD.DrawText(COLOR_BLACK, 255, 95, 40, text);
ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
ReefAngel.LCD.DrawText(0,255,8,100, "White");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,15,119, ReefAngel.PWM.GetDaylightValue());
ReefAngel.LCD.DrawText(0,255,88,100, "Blue");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,90,119, ReefAngel.PWM.GetActinicValue());
Sorry, I didn't understand what you meant.
Did you try using the wizard?
When I start with this controller I used the wizard but now I modify the same code.rimai wrote:Sorry, I didn't understand what you meant.
My LEDs ares hooked to the pwm channels but they are preprogrammed to gets on at 3pm to 1am, I want to get the alternative to get the lights on if I need it before the preprogrammed timer for maintenance or something.
I put the code you recommended and when the lights are on, they turns off when I toggle the port in the portal or the iPhone app but when the lights are off, I toggle the port to try to gets the lights on without luck
What values for AP and DP does the screen show when you override port5 on?
When the lights are on, if I override (toggle ports on my app) they shut down the lights and in the screen, they show the 00% in the lights. But I needs to get the lights on when they're off, then I tried to override (app or portal toggle) and the % don't change in the screen and lights don't gets on like I want/need!rimai wrote:What values for AP and DP does the screen show when you override port5 on?
Thanks Roberto for your time with my code. How you can understand my words
You probably have the wrong settings in internal memory then.
You must have changed it to 0% at some point in time.
Try adding this to setup() section:
Make sure it is in the setup and not loop
InternalMemory.LEDPWMDaylight_write(100);
InternalMemory.LEDPWMActinic_write_write(100);
