I believe you would need to add or make sure it is in the code what I have highlighted red...
List code is set to run the "Else" mode from 12pm to 10pm and then run a constant 30% at night and it drops to 20% during feeding and 0% during Water Changes.
// Define Relay Ports by Name
#define Actinic_Lights 1
#define Day_Lights 2
#define Unused 3
#define Pumps 4
#define Sump_Fan 5
#define DeNit_Pump 6
#define DeNit_Doser 7
#define Unused 8
#define ATO_Pump Box1_Port1
#define Moon_Lights Box1_Port2
#define Unused Box1_Port3
#define Unused Box1_Port4
#define Unused Box1_Port5
#define Unused Box1_Port6
#define Unused Box1_Port7
#define Unused Box1_Port8
// Does not need to be global.
// unsigned long ATOUpdate=0;
//Set Standard Menu
ReefAngel.AddStandardMenu();
ReefAngel.DCPump.FeedingSpeed=20;
ReefAngel.Relay.On( Pumps );
ReefAngel.StandardLights( Actinic_Lights,12,0,22,0 );
ReefAngel.StandardLights( Day_Lights,13,0,21,0 );
ReefAngel.StandardLights( Sump_Fan,13,0,21,0 );
ReefAngel.Relay.Set( Moon_Lights, !ReefAngel.Relay.Status( Actinic_Lights ) );
ReefAngel.Relay.Set(DeNit_Doser,(now()-3600)%21600<1200); // Runs for 1200s every 21600 seconds
ReefAngel.Relay.Set(DeNit_Pump,((now()-3600)-1200)%21600<1200); // Runs for 1200s every 21600 seconds with 1200s offset
// ReefAngel.Relay.DelayedOn( ATO_Pump,10 );
// ReefAngel.WaterLevelATO(ATO_Pump,720,32,32); // Enable ATO the ATO
// Delay WL ATO after water change and DeNit_Dosing
static time_t wcTimer=0;
static time_t denitTimer=0;
if (ReefAngel.Relay.Status(DeNit_Pump)) denitTimer=now();
// Start with defined WaterLevel ATO
ReefAngel.WaterLevelATO(ATO_Pump,720,32,34);
// You should see a much more stable pump usage with a wider threshold 32-34.
// Also since the water level measure can fluctuate it could lead to a lot of on/off cycling
// which could also cause the relay to be on more often and it we reboot, we may maintain the state we don't want...
// Especially if it could take up to 30 seconds to reboot
// First 10 minutes after WC disable ATO
if (now()-wcTimer >= 0 && now()-wcTimer < 600)
ReefAngel.Relay.Off(ATO_Pump);
// First 5 minutes after DeNit_Doser was on
if (now()-denitTimer >= 0 && now()-denitTimer < 300)
// Disable ATO if Salinity is below 33.5.
if (ReefAngel.Params.Salinity<335)
// Disable ATO if ATO High IsActive()
// Modified to use the DCPump class
if (hour()<12 || hour()>=22) {
ReefAngel.DCPump.Speed=30;
} else if (InternalMemory.DCPumpMode_read()==Custom) {
ReefAngel.DCPump.Mode=Constant; // Won't really be constant. See next line.
ReefAngel.DCPump.Speed=ElseMode(40,20,true ); // ElseMode on sync mode, 40 +/- 20%
ReefAngel.DCPump.UseMemory=true; // Use whatever is in the portal
// No longer necessary since we've defined the speeds for these modes in setup();
// if( ReefAngel.DisplayedMenu==FEEDING_MODE ) ReefAngel.PWM.SetActinic(20);
// if( ReefAngel.DisplayedMenu==WATERCHANGE_MODE ) ReefAngel.PWM.SetActinic(0);
ReefAngel.Portal( "Sacohen","Seth0310" );
int x,y;
// Water Level
strcat(text," ");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,39,75,"Salinity:");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,99,75,text);
ReefAngel.LCD.DrawOutletBox(12, 104, TempRelay);
if (WaveSync)
return NewSpeed;
return AntiSpeed;
