Reef Angel Malfunctioning
Re: Reef Angel Malfunctioning
Nothing is happening. Here is the connection and my com is @ 3
Made the change to COM1.. getting the error:
libusb0.dll is missing...
Sorry... Copy the one you have in C:\Windows\System32 into the folder where your update files are.
Just did the firmware and out back online. Will let u know.
Just happened again Roberto.
Maybe it is not the RF then.
Can you try running without the RF?
It returns to normal the minute i take off the RF. If it doesn get fixed by tomorrow, Im going to have to take it offline. My light stayed on for over 18 hrs on friday. B\c of this issue
Roberto, what can we do about the RF switch? Is it fixable?
I'm going to lower the refresh rate in the libraries to see if we can get better results.
Okay FYI.
Im not sure if this is relevant. But its never happened before. After removing the RF switch I went out. I came back home around 3:15pm to see my fish tank in the dark (the lights don't go out till 8:15). The head unit was saying the time was 8:30pm. I promptly pulled the plug and its been working fine since.
As for the library update please let me know when i can but the RF switch back online.
Roberto, any updates?
It is going to be on the next release.
There is no target date for next release yet though.
So is there anything I can do for my RF module. or is it just useless, till the new update (say it aint so Roberto). I really like my mode switching.
Please help!!!!
Please help!!!!
Try to find out where you are picking up the noise that is causing the issue.
I also checked the libs code and found out that if you use UseMemory=false, which I think you are, you can change the refresh yourself.
Can you post your code?
here you go roberto. Also what noise are you referring to for the RF switch. The only change to my setup has been that I now run 4 MP40s as opposed to 2.
#include <RF.h>fa
ReefAngel.WaterChangePorts = Port1Bit | Port8Bit; // Turn off Ports 5 and 6 when Feeding Mode is activated
ReefAngel.FeedingModePorts = Port1Bit | Port6Bit | Port8Bit; // Turn off Ports 1, 6, 7 and 8 when Water Change Mode is activated
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit| Port5Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit |Port3Bit | Port4Bit | Port5Bit | Port7Bit; // Turn off Ports 3,
{ //Port1 Return pump... on all the time!!!
ReefAngel.Relay.Set( Port2, !ReefAngel.Relay.Status( Port4 ) ); //Refuge
ReefAngel.Relay.Off( Port3); // Start with the relay off
if (hour()>=5 && hour()<10) ReefAngel.Relay.On(Port3); // Moonlight Between 5-10am turn the relay on
if (hour()>=20 && hour()<=23) ReefAngel.Relay.On(Port3); // From 8pm-Midnight turn the relay on
ReefAngel.StandardLights( Port4,10,0,20,0 ); //ATI Actinic
ReefAngel.StandardLights( Port5,11,0,19,0 ); //ATI Daylight
ReefAngel.StandardLights( Port6,10,0,20,0 ); //ATI Fan
ReefAngel.StandardHeater( Port7,778,790 ); //Heater
ReefAngel.Relay.DelayedOn( Port8,2 ); //Skimmer
// ReefAngel.AI.SetChannel( White, PWMParabola(11,0,17,0,0,75,0) );
// ReefAngel.AI.SetChannel( Blue, PWMParabola(9,0,20,0,15,100,0) );
// ReefAngel.AI.SetChannel( RoyalBlue, PWMParabola(9,0,20,0,15,100,(MoonPhase()/5)<3 ? 3:MoonPhase()/5) );
ReefAngel.RF.SetMode( ReefCrest,85,10 );
// ReefAngel.RF.SetChannel( Radion_White, PWMParabola(9,0,20,0,0,60,0) );
// ReefAngel.RF.SetChannel( Radion_RoyalBlue, MoonPhase() );
// ReefAngel.RF.SetChannel( Radion_Red, PWMParabola(9,0,20,0,15,65,15) );
// ReefAngel.RF.SetChannel( Radion_Green, PWMParabola(9,0,20,0,15,50,15) );
// ReefAngel.RF.SetChannel( Radion_Blue, MoonPhase() );
// ReefAngel.RF.SetChannel( Radion_Intensity, PWMParabola(9,0,20,0,15,94,15) );
// if ( second()==0 ) ReefAngel.RF.RadionWrite();
if (hour()>=6 && hour()<11)
ReefAngel.RF.SetMode(ReefCrest,85,10);
else if (hour()>=11 && hour()<13)
else if (hour()>=13 && hour()<16)
ReefAngel.RF.SetMode(Smart_NTM,85,15);
else if (hour()>=16 && hour()<19)
ReefAngel.RF.SetMode(ReefCrest,65,10);
ReefAngel.RF.SetMode(Lagoon,40,10);
// Hardcode PH calibrations
//ReefAngel.PHMin=544; // PH7.0
//ReefAngel.PHMax=830; // PH10.0
ReefAngel.Portal( "ecam" );
int x,y;
// Aqua Illumination
x = 10;
y = 20;
ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x,y,"WH:" );
ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+38,y,"BL:" );
ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+76,y,"RB:" );
for ( int a=0;a<3;a++ )
ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+18,y,ReefAngel.AI.GetChannel(a) );
x += 38;
ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params );
ReefAngel.LCD.DrawOutletBox( 12, 94, TempRelay );
To use the new code, you will need to return the RF module to the original firmware.
- update.zip
- (423.63 KiB) Downloaded 356 times
Try this code:
#include <RF.h>fa
byte myRFMode=0;
byte myRFDuration=0;
byte myRFSpeed=0;
// ReefAngel.RF.UseMemory = false;
// ReefAngel.RF.SetMode( ReefCrest,85,10 );
myRFSetMode(ReefCrest,85,10);
myRFSetMode(Smart_NTM,85,15);
myRFSetMode(ReefCrest,65,10);
myRFSetMode(Lagoon,40,10);
int x,y;
x = 10;
y = 20;
x += 38;
void myRFSetMode(byte m, byte s, byte d)
if (m!=myRFMode || s!=myRFSpeed || d!=myRFDuration || millis()<5000)
myRFMode=m;
myRFSpeed=s;
myRFDuration=d;
ReefAngel.RF.SetMode(m,s,d);
rimai wrote:To use the new code, you will need to return the RF module to the original firmware.
Roberto, i was regarding in one of the post that you thought the dimming home might be having adverse affects with the Angel. Should i try disconnect the hub and finding out if that works?
http://forum.reefangel.com/viewtopic.php?f=12&t=3865
Cause this same thing happened to me last weekend. With the time changing on me.
Yes, same problem. It's related to the expansion bus signal.
The 2 modules that can do that are the old dimming module and the RF module.
But if you replaced the twi.c, you should not see the controller blinking and the time changing. Your controller should reboot instead.
I'm thinking some interference noise is causing your RF module to lockup, which causes all that.
rimai wrote:Yes, same problem. It's related to the expansion bus signal.
What kind of interference, am i looking for?
I haven't really added any electric devices in my tank area, expect for the new MP40s and your new modules
rOBERTO I RAN THIS UPDATE I SAW THE INITIAL 3 LIGHT FLASH AND THE ENDING AND NOTHING IN BETWEEN.. dID IT WORK?rimai wrote:To use the new code, you will need to return the RF module to the original firmware.
Roberto just happened again with the old firmware restored. Any other ideas?
Did you load the code I posted?
Does it work ok without the RF module?
Dont understand the question.. but will try to answer a few possible version;
When the RF module fails. It puts my RA into a flashing red status on the head unit at which points it no longer takes instructions. whatever it is doing at the time of the freeze will continue. (i.e: my lights were on for over 18 hrs one day!!!! i disconnect the module and everything goes back o normal.
#include <DS1307RTC.h>fafa
#include <RF.h>fa
byte myRFMode=0;
byte myRFSpeed=0;
// ReefAngel.AI.SetPort( lowATOPin );
ReefAngel.Relay.On( Box1_Port2 ); // Razor Led
ReefAngel.Relay.On( Box1_Port4 ); // Sump Equipment - UV, Pump
ReefAngel.Relay.On( Box1_Port5 ); // MP40s
ReefAngel.Relay.On( Box1_Port6 ); // JBJ
// Port1 Return pump... on all the time!!!
// Port3 ... not used
//box 2
ReefAngel.Relay.Off( Box1_Port1); // Lunar Hub Not used Port #9
// Box1_Port2 Razor_LED (Sump)... on all the time!!! Port #10
ReefAngel.Relay.Off( Box1_Port3); // Start with the relay off Port #11
if (hour()>=5 && hour()<10) ReefAngel.Relay.On(Box1_Port3); // Moonlight Between 5-10am turn the relay on
if (hour()>=20 && hour()<=23) ReefAngel.Relay.On(Box1_Port3); // From 8pm-Midnight turn the relay on
// Box1_Port4 Ecotech MP_40 Pumps on all the time!!! Port #12
// Box1_Port5 Razor_LED (Sump)... on all the time!!! Port #13
// Box1_Port6 JBJ ATO ... on all the time!!! Port #14
ReefAngel.Relay.Off( Box1_Port7); // ALK Doser ... Port #15
ReefAngel.Relay.Off( Box1_Port8); // Calc Doser ... Port #16
// ReefAngel.PWM.SetDaylight(PWMParabola(20,0,23,0,0, MoonPhase(),0 ));
// Define Your dosing pumps
#define numDPumps 2
byte pumpRelays[numDPumps]={ Box1_Port7, Box1_Port8 };
int DPVolume[numDPumps]={ 30, 30 } ; // 30ml for each alk and calcium
int DPRepeat[numDPumps]={ 60, 60 } ; // Repeat every 60 miniutes
// Define Calibration here
int CalTime[numDPumps]={ 600, 600 }; // 10 minutes / 10 minutes
int CalVol[numDPumps]={ 350, 300 }; // 350ml / 300ml
// Function: RunDosingPumps()
void RunDosingPumps() {
float rate;
int calcTime[numDPumps];
for (int i=0;i < numDPumps; i++) {
rate=(float)CalVol[i]/CalTime[i];
calcTime[i]=DPVolume[i]/rate/(1440/DPRepeat[i]);
// Run the pumps
ReefAngel.DosingPumpRepeat(pumpRelays[i], i*20, DPRepeat[i], calcTime[i]); // Offset between each pump is 20 minutes
// Display Time calculated in portal
ReefAngel.CustomVar[0]=calcTime[0];
ReefAngel.CustomVar[1]=calcTime[1];
// Function: LogDosingPumps()
void LogDosingPumps() {
static time_t pumpTimer[numDPumps];
static boolean pumpStatus[numDPumps];
float rate;
for (int i=0;i< numDPumps;i++) {
if (ReefAngel.Relay.Status(pumpRelays[i])) {
if (!pumpStatus[i]) {
pumpTimer[i]=now()-pumpTimer[i]; // Pump was off, timer is now a time
pumpStatus[i]=true;
if (pumpStatus[i]) {
pumpTimer[i]=now()-pumpTimer[i]; // Pump was on, timer is now a timer
pumpStatus[i]=false;
// Report How much volume has been dosed per day.
// Could make this in minutes... excercise for the reader..
ReefAngel.CustomVar[2]=pumpTimer[0]*rate;
ReefAngel.CustomVar[3]=pumpTimer[1]*rate;
// Clear timer at end of day
if (now()%SECS_PER_DAY==SECS_PER_DAY-1) pumpTimer[i]=0;
int x,y;
x = 10;
y = 20;
x += 38;
myRFMode=m;
myRFSpeed=s;
myRFDuration=d;
