sorry, When I press the buttons on the RA, it doesn't turn the lights on or off. Here is the code:
#include <WiFiAlert.h>
// Globals for Params on Custom Main
byte x,y;
// Define Custom Variables for Portal
// Custom Menu
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Turn Lights On";
prog_char menu1_label[] PROGMEM = "Turn Lights Off";
prog_char menu2_label[] PROGMEM = "Start Feeding";
prog_char menu3_label[] PROGMEM = "Start Water Change";
prog_char menu4_label[] PROGMEM = "Clear Overheat";
prog_char menu5_label[] PROGMEM = "Calibrate pH";
prog_char menu6_label[] PROGMEM = "Calibrate Salinity";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label };
void MenuEntry1()
ReefAngel.DisplayMenuEntry("Item 1");ReefAngel.Relay.RelayMaskOn = ReefAngel.LightsOnPorts;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE[i] = ReefAngel.LightsOnPortsE[i];
#endif // RelayExp
ReefAngel.Relay.Write();
void MenuEntry2()
ReefAngel.DisplayMenuEntry("Item 2");ReefAngel.Relay.RelayMaskOn = 0;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE[i] = 0;
#endif // RelayExp
void MenuEntry3()
ReefAngel.DisplayMenuEntry("Item 3");ReefAngel.FeedingModeStart();
void MenuEntry4()
ReefAngel.DisplayMenuEntry("Item 4");ReefAngel.WaterChangeModeStart();
void MenuEntry5()
ReefAngel.DisplayMenuEntry("Item 5");ReefAngel.OverheatClear();
void MenuEntry6()
ReefAngel.DisplayMenuEntry("Item 6");ReefAngel.SetupCalibratePH();
void MenuEntry7()
ReefAngel.DisplayMenuEntry("Item 7");ReefAngel.SetupCalibrateSalinity();
// End Custom Menu Globals
// Define Relay Ports by Name
#define DT_LightsOne 1
#define DT_LightsTwo 2
#define Unused3 3
#define Unused4 4
#define DT_LWM 5
#define GT_LWM 6
#define Unused7 7
#define Unused8 8
#define Unused11 Box1_Port1
#define Unused12 Box1_Port2
#define GT_LightsOne Box1_Port3
#define GT_LightsTwo Box1_Port4
#define DT_RWM Box1_Port5
#define GT_RWM Box1_Port6
#define DT_Heat Box1_Port7
#define DT_Pump Box1_Port8
#define RV_Heat Box2_Port1
#define RV_Pump Box2_Port2
#define GT_Heat Box2_Port3
#define Unused24 Box2_Port4
#define GT_OverFill Box2_Port5
#define GT_Fill Box2_Port6
#define Skimmer Box2_Port7
#define GT_Pump Box2_Port8
void setup() {
ReefAngel.InitMenu(pgm_read_word(&(menu_items[0])),SIZE(menu_items)); // Initialize the menu
ReefAngel.FeedingModePortsE[0] = Port8Bit; // Turn off on Box1 when feeding mode is activated is activated
ReefAngel.FeedingModePortsE[1] = Port7Bit | Port8Bit; // Turn off on Box2 when feeding mode is activated is activated
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit ; // Turn off when water change mode is activated
ReefAngel.WaterChangePortsE[0] = Port5Bit | Port6Bit | Port7Bit | Port8Bit; // Turn off on Box1 when water change mode is activated
ReefAngel.WaterChangePortsE[1] = Port3Bit | Port8Bit | Port7Bit | Port6Bit | Port1Bit; // Turn off on Box1 when water change mode is activated
ReefAngel.PHExpMin = 1832;
ReefAngel.PHExpMax = 2150;
ReefAngel.TempProbe = T2_PROBE; // Set the 2nd plug to be DT Main temp
ReefAngel.OverheatProbe = T2_PROBE; // to monitor the overheat and temperatures
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit; // Items turned off when Overheat temperature exceeded
ReefAngel.OverheatShutoffPortsE[0] = Port7Bit | Port3Bit | Box1_Port4; // Items turned off on Box1 when Overheat temperature exceeded
ReefAngel.OverheatShutoffPortsE[1] = Port3Bit | Port7Bit; // Items turned off on Box2 when Overheat temperature exceeded
InternalMemory.OverheatTemp_write( 829 ); // Set the DT Overheat temperature setting
ReefAngel.LightsOnPorts = Port1Bit | Port2Bit; // Toggle Lights
ReefAngel.LightsOnPortsE[0] = Port3Bit | Port4Bit; // Toggle Lights
// Ports that default on
ReefAngel.Relay.On(DT_Pump); // Turn on DT Pump
ReefAngel.Relay.On(GT_Pump); // Turn on GT Pump
ReefAngel.Relay.On(Skimmer); // Turn on Skimmer
// CheckPower(); // Monitor for power outages
// CheckSwitches(); // Monitor for float switches
ReefAngel.StandardLights( DT_LightsOne,14,00,22,00 ); // DT Lights on at 2:00pm and off at 10:00pm
ReefAngel.StandardLights( DT_LightsTwo,22,00,01,00 ); // DT-Moon Lights on at 10:00am and off at 1:00am
ReefAngel.StandardLights( GT_LightsOne,14,00,21,45 ); //GT Lights Main 2:00pm - 9:45pm
ReefAngel.StandardLights( GT_LightsTwo,15,00,22,30 ); //GT Lights Actinic 3:00pm - 10:30pm
ReefAngel.WavemakerRandom( DT_LWM,60,100 );
ReefAngel.Relay.Set( DT_RWM, !ReefAngel.Relay.Status( DT_LWM ) ); //Randomize DT powerheads
ReefAngel.WavemakerRandom1( GT_LWM,60,100 );
ReefAngel.Relay.Set( GT_RWM, !ReefAngel.Relay.Status( GT_LWM ) ); //Randomize GT powerheads
StandardHeater1( DT_Heat,779,791 ); //DT-Heat
StandardHeater2( GT_Heat,779,791 ); //GT-Heat
// if the hour is 2p or 8p, minute is 55 and seconds is 0, start the feeding mode
if ( ((hour() == 14) || (hour() == 20)) &&
(minute() == 55) &&
(second() == 0) )
if (hour()>=1 && hour()<6) // Turn on Reservoir Pump
ReefAngel.Relay.On(RV_Pump);
ReefAngel.Relay.Off(RV_Pump);
// turn on RV_Heat when temp falls below 76.0 and turn off when temp gets above 80.0
if (ReefAngel.Params.Temp[T3_PROBE] <= 780 && ReefAngel.Params.Temp[T3_PROBE] > 0) ReefAngel.Relay.On(RV_Heat);
if (ReefAngel.Params.Temp[T3_PROBE] >= 791) ReefAngel.Relay.Off(RV_Heat);
// I_O Expansion & Float Valves
// ReefAngel.CustomVar[7]=1;
//turn off DT pump when switch is tripped and sound buzzer
ReefAngel.Relay.Set(DT_Pump,ReefAngel.IO.GetChannel(0));
ReefAngel.PWM.SetDaylight(100-(ReefAngel.IO.GetChannel(0)*100));
ReefAngel.CustomVar[0]=ReefAngel.IO.GetChannel(0); //tell the portal we have a overflow problem
//turn off GT pump when switch is tripped and sound buzzer
ReefAngel.Relay.Set(GT_Pump,ReefAngel.IO.GetChannel(1));
ReefAngel.PWM.SetDaylight(100-(ReefAngel.IO.GetChannel(1)*100));
ReefAngel.CustomVar[1]=ReefAngel.IO.GetChannel(1); //tell the portal we have a overflow problem
//turn on GT Fill when switch is tripped
static time_t LastATO=millis();
if (!ReefAngel.IO.GetChannel(2)) LastATO=millis();
if (millis()-LastATO<5000 && millis()-LastATO>100)
ReefAngel.Relay.Off(GT_Fill);
ReefAngel.SingleATO(true,GT_Fill,10,0);
// ReefAngel.Relay.Set(GT_Fill,ReefAngel.IO.GetChannel(2));
// ReefAngel.PWM.SetDaylight(100-(ReefAngel.IO.GetChannel(2)*100));
//turn off GT OverFill when switch is tripped and sound buzzer
// ReefAngel.Relay.Set(GT_OverFill,ReefAngel.IO.GetChannel(3));
// ReefAngel.PWM.SetDaylight(100-(ReefAngel.IO.GetChannel(3)*100));
// ReefAngel.CustomVar[2]=ReefAngel.IO.GetChannel(3); //tell the portal we have a overflow problem
// Dosing Pumps
//set up dosing pump one to run twice a week for 4 minutes
//ReefAngel.Relay.Set(Box1_Port2,((weekday()==1||weekday()==4) && hour()==14 && minute()<6));
//ReefAngel.Relay.Set (Box1_Port3,(hour()%2==0)); //stir chemicals in water top off unit
// ReefAngel.Params.ORP=ReefAngel.PH.Read();
ReefAngel.Portal("rossbryant1956");
void StandardHeater1(byte HeaterRelay, int LowTemp, int HighTemp)
if (ReefAngel.Params.Temp[T2_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
if (ReefAngel.Params.Temp[T2_PROBE] <= LowTemp && ReefAngel.Params.Temp[T2_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay); // If sensor 2 temperature <= LowTemp - turn on heater
if (ReefAngel.Params.Temp[T2_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay); // If sensor 2 temperature >= HighTemp - turn off heater
void StandardHeater2(byte HeaterRelay, int LowTemp, int HighTemp) //Heater for Grow Tank
if (ReefAngel.Params.Temp[T1_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
if (ReefAngel.Params.Temp[T1_PROBE] <= LowTemp && ReefAngel.Params.Temp[T1_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay); // If sensor temperature <= LowTemp - turn on heater
if (ReefAngel.Params.Temp[T1_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay); // If sensor temperature >= HighTemp - turn off heater
int x,y;
char text[7];
ReefAngel.LCD.DrawDate( 6, 122 ); //6 pixels left, 122 lines down
// I/O Expansion
byte bkcolor;
x = 14;
y = 11;
for ( int a=0;a<6;a++ )
if ( ReefAngel.IO.GetChannel(a) ) bkcolor=COLOR_WHITE; else bkcolor=COLOR_GRAY;
ReefAngel.LCD.DrawText(0,255,18,26,"GT"); //18 left, 10 down
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 37, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,57,26,"DT"); //57 left, 10 down
ConvertNumToString(text, ReefAngel.Params.Temp[T2_PROBE], 10);
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 50, 37, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,94,26,"Res"); //94 left, 10 down
ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 90, 37, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,16,52,"DT pH"); //18 left, 39 down
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 15, 65, text, Num8x8);
ReefAngel.LCD.DrawText( 0,255,57,52, "GT pH"); //57 left, 39 down
ConvertNumToString(text, ReefAngel.Params.PHExp, 100);
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 55, 65, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,100,52,"Sal"); //100 left, 39 down
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 98, 65, text, Num8x8);
ReefAngel.LCD.DrawOutletBox( 12, 80, TempRelay );
// Relay Expansion
// Relay Expansion
TempRelay = ReefAngel.Relay.RelayDataE[1];
TempRelay &= ReefAngel.Relay.RelayMaskOffE[1];
TempRelay |= ReefAngel.Relay.RelayMaskOnE[1];
// ReefAngel.LCD.DrawGraph( 5, 5 );
