ReefAngel.SingleATO( true,Port1,60,0 );
Im using my reef angel ATO port low to tell me when the tank is half empty to refill. Do i need to do anything to this code to make it work. Is there anyway to tell it to trigger an email when its triggered? does it need a port assigned to it?
ATO float valve
Re: ATO float valve
That is for ATO function.
If you only need an alert, you don't need to add anything to your code.
Just set the Portal to send you an alert on ATOLOW>0
