Alk and Calc overdosing precaution
ecam
Post by ecam »
Guys. Im trying to figure out how to safegaurd my dosers from killing my tank in case of an accidental button push on my phone. Im hoping to be limit the running time to 5 to 10 seconds tops. Im currently dosing by volume based on Lnevo's code. Any advice would be great
    #include <DS1307RTC.h>fafa
    #include <RF.h>fa
      byte myRFMode=0;
        byte myRFDuration=0;
        byte myRFSpeed=0;
    ReefAngel.WaterChangePorts = Port1Bit | Port8Bit; // Turn off Ports 5 and 6 when Feeding Mode is activated
      ReefAngel.FeedingModePorts = Port1Bit | Port6Bit | Port8Bit; // Turn off Ports 1, 6, 7 and 8 when Water Change Mode is activated
      ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit| Port5Bit;
      ReefAngel.OverheatShutoffPorts = Port2Bit |Port3Bit | Port4Bit | Port5Bit | Port7Bit; // Turn off Ports 3,
        ReefAngel.Relay.On( Box1_Port2 );  // Razor Led
        ReefAngel.Relay.On( Box1_Port4 ); // Sump Equipment - UV, Pump
        ReefAngel.Relay.On( Box1_Port5 ); // MP40s
        ReefAngel.Relay.On( Box1_Port6 ); // JBJ
      //  Port1 Return pump...  on all the time!!!
          ReefAngel.Relay.Set( Port2, !ReefAngel.Relay.Status( Port4 ) ); //Refuge
      //  Port3 ...  not used
          ReefAngel.StandardLights( Port4,10,0,20,0 ); //ATI Actinic
          ReefAngel.StandardLights( Port5,11,0,19,0 );  //ATI Daylight
          ReefAngel.StandardLights( Port6,10,0,20,0 );  //ATI Fan
          ReefAngel.StandardHeater( Port7,778,790 ); //Heater
          ReefAngel.Relay.DelayedOn( Port8,2 ); //Skimmer
          //box 2
          ReefAngel.Relay.Off( Box1_Port1); // Lunar Hub Not used   Port #9
    //   Box1_Port2 Razor_LED (Sump)...  on all the time!!!      Port #10
          ReefAngel.Relay.Off( Box1_Port3); // Start with the relay off       Port #11
                  if (hour()>=5 && hour()<10) ReefAngel.Relay.On(Box1_Port3); // Moonlight Between 5-10am turn the relay on
                  if (hour()>=20 && hour()<=23) ReefAngel.Relay.On(Box1_Port3); // From 8pm-Midnight turn the relay on
    //   Box1_Port4 Ecotech MP_40 Pumps  on all the time!!!      Port #12
    //   Box1_Port5 Razor_LED (Sump)...  on all the time!!!      Port #13
    //   Box1_Port6 JBJ ATO ...          on all the time!!!      Port #14
         ReefAngel.Relay.Off( Box1_Port7);  // ALK Doser ...      Port #15
         ReefAngel.Relay.Off( Box1_Port8);  // Calc Doser ...     Port #16
    // ReefAngel.PWM.SetDaylight(PWMParabola(20,0,23,0,0, MoonPhase(),0 ));
        ReefAngel.RF.SetMode( ReefCrest,85,10 );
          if (hour()>=6 && hour()<11)
            myRFSetMode(ReefCrest,85,10);
          else if (hour()>=11 && hour()<13)
          else if (hour()>=13 && hour()<16)
            myRFSetMode(Smart_NTM,85,15);
          else if (hour()>=16 && hour()<19)
            myRFSetMode(ReefCrest,65,10);
            myRFSetMode(Lagoon,40,10);
        // Hardcode PH calibrations
         //ReefAngel.PHMin=544; // PH7.0
         //ReefAngel.PHMax=830; // PH10.0
         RunDosingPumps();
         LogDosingPumps();
        ReefAngel.Portal( "ecam" );
        // Parameters
        ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params,
        ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params );
        // Main Relay Box
        // Date and Time
    // Define Your dosing pumps
    #define numDPumps 2
    byte pumpRelays[numDPumps]={ Box1_Port7, Box1_Port8 };
    int DPVolume[numDPumps]={ 3, 3 } ; // 1ml for each alk and calcium
    int DPRepeat[numDPumps]={ 240, 240 } ; // Repeat every 4 hrs 5x a day
    // Define Calibration here
    int CalTime[numDPumps]={ 600, 600 }; // 10 minutes / 10 minutes
    int CalVol[numDPumps]={ 350, 300 }; // 350ml / 300ml... .58 / .5
    // Function: RunDosingPumps()
    void RunDosingPumps() {
      float rate;
      int calcTime[numDPumps];
      for (int i=0;i < numDPumps; i++) {
        rate=(float)CalVol[i]/CalTime[i];
        calcTime[i]=DPVolume[i]/rate/(1440/DPRepeat[i]);
        // Run the pumps
        ReefAngel.DosingPumpRepeat(pumpRelays[i], i*20, DPRepeat[i], calcTime[i]); // Offset between each pump is 20 minutes
      // Display Time calculated in portal
      ReefAngel.CustomVar[0]=calcTime[0];
      ReefAngel.CustomVar[1]=calcTime[1];
    // Function: LogDosingPumps()
    void LogDosingPumps() {
      static time_t pumpTimer[numDPumps];
      static boolean pumpStatus[numDPumps];
      float rate;
      for (int i=0;i< numDPumps;i++) {
        if (ReefAngel.Relay.Status(pumpRelays[i])) {
          if (!pumpStatus[i]) {
            pumpStatus[i]=true;
        } else {
          if (pumpStatus[i]) {
            pumpStatus[i]=false;
            // Report How much volume has been dosed per day.
            // Could make this in minutes... excercise for the reader..
            ReefAngel.CustomVar[2]=pumpTimer[0]*rate;
            ReefAngel.CustomVar[3]=pumpTimer[1]*rate;
        // Clear timer at end of day
        if (now()%SECS_PER_DAY==SECS_PER_DAY-1) pumpTimer[i]=0;
        void myRFSetMode(byte m, byte s, byte d)
          if (m!=myRFMode || s!=myRFSpeed || d!=myRFDuration || millis()<5000)
            myRFMode=m;
            myRFSpeed=s;
            myRFDuration=d;
            ReefAngel.RF.SetMode(m,s,d);
Re: Alk and Calc overdosing precaution
Theres a feature i added to lock ports so they could not be overridden by phone/portal etc. i believe its built into the libraries for a while now. It will still let the ports run only in auto mode. I assigned a virtual relay to change this so if i needed i could "unlock" them. I don't even think it needs any internal memory!!!
ecam
Post by ecam »
I'm going crazy here with issues!!!
I cannot access my example folders where that cold would be. It's almost like its a picture and not a menu item. I've re installed 3x already tomo effect
Its in my code..not in the examples..
Its like the feeding mode and water change ports...
I believe its
ReefAngel.OverridePortsE[0]=Port7Bit | Port8Bit;
Put that in setup and it should disable on/off from phone for your dosing pumps... Box1_Port7/8
If you look at my LockPorts() function you'll see how I toggle it.
