DC pump shutting down
Sleepingtiger
Post by Sleepingtiger »
The pumps do not run. The only time it runs is after feeding mode when the NTM is enabled. I got this code off another member from the forum. Can someone tell me what i did wrong. BTW, according to the display, the DP and AP has numbers next to it. I guess it means that it should be running. I am really new to this. thanks for the help
sketch_sep22a.ino
(5.51 KiB) Downloaded 337 times
Re: DC pump shutting down
I think there was an error in the if statement.
Try this:
  ReefAngel.AddStandardMenu();  // Add Standard Menu
  ReefAngel.WaterChangePorts = Port1Bit;
  InternalMemory.OverheatTemp_write( 840 );
  ReefAngel.DCPump.FeedingSpeed=5;
  ReefAngel.StandardHeater( Port1,790,808 );
  ReefAngel.StandardFan( Port2,810,820 );
  ReefAngel.DosingPumpRepeat( Port3,10,120,1 );
  ReefAngel.DosingPumpRepeat( Port4,3,120,1 );
  ReefAngel.StandardLights( Port7,12,0,23,30 );
  ReefAngel.StandardLights( Port8,12,0,23,30 );
  ReefAngel.PWM.SetChannel( 0, PWMParabola(10,30,22,45,0,85,0) );
  ReefAngel.PWM.SetChannel( 1, PWMParabola(10,30,22,30,0,85,0) );
  ReefAngel.PWM.SetChannel( 2, PWMParabola(11,0,22,15,0,85,0) );
  ReefAngel.PWM.SetChannel( 3, PWMParabola(11,30,21,50,0,90,0) );
    // Schedule for WP40 #1 and #2
  if (hour()<8) // WP40 #1 and #2 at 30% from 12am-8am
    ReefAngel.DCPump.SetMode( Lagoon,30,10 );
  if (hour()>=8 && hour()<11) // WP40 #1 and #2 at 50% in Lagoon mode from 8am-11am
    ReefAngel.DCPump.SetMode( Lagoon,50,10 );
  if (hour()>=11 && hour()<20) // WP40 #1 and #2 at 60% in Reef Crest mode from 11am-10pm
    ReefAngel.DCPump.SetMode( ReefCrest,65,20 );
  if (hour()>=20 && hour()<21) // WP40 #1 and #2 at 50% in Lagoon mode from 10pm-11pm
  if (hour()>=21) // WP40 #1 and #2 at 30% 11pm-12am
  // Run Nutrient Transport Mode after Feeding Mode completes
  static unsigned long feeding;
    feeding = now();
    ReefAngel.DCPump.SetMode( Constant,10,10 ); // Set WP40 #1 and #2 to 10% speed
    if (now()-feeding<=30) // Next 30 seconds are in Nutrient Transport Mode(for testing)
      ReefAngel.DCPump.SetMode( NutrientTransport,70,30 ); // Set WP40 #1 and #2 to 70% speed with 30ms pulse in Nutirnet Transport Mode
  int x,y;
  // Dimming Expansion
  x = 15;
  y = 2;
  for ( int a=0;a<6;a++ )
    if ( a>2 ) x = 75;
    if ( a==3 ) y = 2;
    y += 10;
  ReefAngel.LCD.DrawMonitor( 15, 39, ReefAngel.Params,
  ReefAngel.LCD.DrawMonitor( 15, 39, ReefAngel.Params );
  // pH Expansion
  ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,76, "PHE:" );
  ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.PHExp,COLOR_MEDIUMSEAGREEN,39,76, 100 );
Sleepingtiger
I uploaded the new code. The wp40 works fine in reefcrest, when it goes to lagoon, it shuts down the pump. The DP and AP still has a percentage next to it.
That may be the pump.
I'm pretty sure they shut down when you go below around 25%
Sleepingtiger
i think you're partially correct. when on lagoon mode and i set the power to 50%, the wp40 does not work. I raised it to 55% and its been working great. so now I got a problem, the wp40 is to powerful at night. during the daytime its fine, but at night i would prefer the water to be a bit calmer. do you think there is a way i can turn off one of the pump at night? i know i can probably put one of the wp40 on the power bar and set a timer, but that doesn't sound as cool. or maybe have the two pumps alternate at a set interval. thanks
You can set them to constant 30% instead of lagoon.
Sleepingtiger
i really don't like the idea of constant... makes me feel like i got a koralia instead of a dc pump. so i guess there is no way to shut down one of the pumps without taking out the power?
There is, but not if you are using the DCPump class.
You would need to refactor the code to use the channels directly instead.
http://forum.reefangel.com/viewtopic.php?f=14&t=2895
