Can I code my 2 jebao wp40's to run at different speeds?
DavidinGA
Post by DavidinGA »
I have two Jebao WP40 wavemakers and it seems like one of them has lost noticeable power and so I was wondering if I could code them to have the weaker one run at higher percentages to make up for the power loss...???
    InternalMemory.OverheatTemp_write( 810 );
    ReefAngel.StandardHeater( Port1,795,800 );
    ReefAngel.StandardHeater( Port2,793,800 );
    ReefAngel.StandardLights( Port3,1,0,24,0 );   ////gfo
    ReefAngel.StandardLights( Port4,11,0,21,0 );  ////UV
    ReefAngel.DosingPumpRepeat( Port6,0,240,600 ); /////ato powerhead 240min = 4hrs
    ReefAngel.DosingPumpRepeat( Port7,0,360,20 );  /////alk 360min = 6hrs
    ReefAngel.DosingPumpRepeat( Port8,0,420,35 );  ////cal 420min = 7hrs
    ReefAngel.DCPump.SetMode( LongPulse,40,10 );
    if (hour()<8)
ReefAngel.PWM.SetActinic(0);
ReefAngel.PWM.SetDaylight(0);
else if (hour()>=8 && hour()<10)
ReefAngel.DCPump.SetMode( ShortPulse,80,20 );
else if (hour()>=10 && hour()<12)
ReefAngel.DCPump.SetMode( LongPulse,65,5 );
else if (hour()>=12 && hour()<14)
ReefAngel.DCPump.SetMode( ShortPulse,70,15);
else if (hour()>=14 && hour()<16)
ReefAngel.DCPump.SetMode( ReefCrest,50,20 );
else if (hour()>=16 && hour()<22)
ReefAngel.DCPump.SetMode( ShortPulse,75,20 );
    ReefAngel.Portal( "davidinga" );
    int x,y;
    // pH Expansion
    ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.PHExp,COLOR_MEDIUMSEAGREEN,39,66, 100 );
ReeferBee
Re: Can I code my 2 jebao wp40's to run at different speeds?
Post by ReeferBee »
 if (hour()<8)
The values 80, 65, 70, 50, and 75 are the speeds. Adjust that number on the modes accordingly
Barry
Current tank info: 150g mixed reef
"Some of the worst mistakes of my life were hair cuts" -Jim Morrison
ReeferBee
Post by ReeferBee »
I'm on the older library, my code looks different. I'm sure someone else can chime in and help you.
Barry
DavidinGA
Post by DavidinGA »
ReeferBee wrote:
 if (hour()<8)
Right but I only want to increase the speed of one of the pumps; not both of them.
Take the pump apart and clean the impeller shaft and inside of the housing it will run like new once you do that.
Just twist the top cover counter clockwise and it pops right off.
At some point i will add a way to add an AntiSync speed offset. So there is more control. Especially when you may have different types of pumps.
DavidinGA
Post by DavidinGA »
Sacohen wrote:Take the pump apart and clean the impeller shaft and inside of the housing it will run like new once you do that.
I actually did do that. It improves the performance a little but the new WP40 still outperforms this older one (6 months old now).
In a couple of months the new one will probably slow down a bit too and be somewhat equal to the old one.
DavidinGA
Post by DavidinGA »
So there really isn't a way to code them for separate speed levels???
Sent from my SCH-I605 using Tapatalk 4
Not right now if you are using the DCPump Class.
If you want to use the older method then yes it is possible.
I had it set up on my WP-40 and WP-25.
ReefAngel.PWM.SetDaylight( LongPulseMode(45,70,10,true));
ReefAngel.PWM.SetActinic( LongPulseMode(65,70,10,true));
PulseMinSpeed - % for minimal speed
PulseMaxSpeed - % for maximum speed
PulseDuration - Duration (seconds) in which each pulse will be held. The pump will stay at minimal speed for PulseDuration and will stay at maximum speed for PulseDuration.
PulseSync - true if you want to sync pumps to same cycle. one false and one true if you want to anti-sync pumps.
Here is a link to the different pump modes and their settings.
http://forum.reefangel.com/viewtopic.php?f=7&t=2844
