You must override those ports instead like this:
ReefAngel.Relay.Override(Port4,1);
If you override either on or off, you must turn it back to auto or they will remain in overridden position forever.
That's why everybody don't even bother with the controller menu. It's much easier to use the Portal or android app.
Also, if you use internal memory, we can't help you figure out why your lights don't turn on. We can't see what's in your internal memory.
