8th outlet not turning on heater
I am a new reef angel user and I plugged in a heater to outlet 8 and used the wizard for the settings. The 8th port is not powering the heater.
I am a newb so I will post the most recent sketch in its entirety. thanks for any help with coding or hardware trouble shooting. The heater works fine plugged into a regular outlet but not when plugged into the reef angel one.
ReefAngel.FeedingModePorts = Port1Bit | Port6Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardFan( Port2 );
ReefAngel.DayLights( Port3 );
ReefAngel.ActinicLights( Port4 );
ReefAngel.ActinicLights( Port6 );
ReefAngel.Relay.Set( Port7, !ReefAngel.Relay.Status( Port3 ) );
ReefAngel.StandardHeater( Port8 );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
ReefAngel.LCD.DrawMonitor( 15, 39, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 39, ReefAngel.Params );
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,76, "PHE:" );
ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.PHExp,COLOR_MEDIUMSEAGREEN,39,76, 100 );
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// pH Expansion
Re: 8th outlet not turning on heater
Please choose hard coded settings when generating your code with the wizard and post your code again.
You can also try the ControllerTester code to check that port.
Files->Sketchbook->Example Codes
I hope this is what you meant for the hard coded settings?
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// pH Expansion
the test did power on the 8th outlet
I may still be asleep but I do not see a line telling the heater to come on and go off in a certain range of temp. Also it may not matter but I wouldn't have my port 8 in the lights on\off command. hope this helps!
Yeah its not hard coded..
StandardHeater(Port8); looks at memory for the high and low settings which we can't see. I also dont see a portal command so i'm assuming you have no wifi...so best to hard code the values. An example would be
StandardHeater(Port8,778,793);
I do not have the wifi attachment.
I have tried putting the heater on outlet 7 and still the same result it doesn't power on even though the temperature is low enough to where it should be. I have tried the coding internally and hard code. I don't have the wifi attachment. I have no idea what to do next. I tried the hard coding example with no luck as well.
on my display it does say phe error#include <ReefAngel_Features.h>
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit | Port7Bit | Port8Bit;
ReefAngel.StandardFan( Port2,741,761 );
ReefAngel.StandardLights( Port3,13,0,19,0 );
ReefAngel.StandardLights( Port4,11,0,20,0 );
ReefAngel.StandardLights( Port6,9,0,19,0 );
ReefAngel.StandardHeater( Port7,700,780 );
ReefAngel.Relay.Set( Port8, !ReefAngel.Relay.Status( Port3 ) );
ReefAngel.PWM.SetDaylight( PWMSlope(12,0,19,0,1,50,30,1) );
ReefAngel.PWM.SetActinic( PWMSlope(10,0,20,0,1,40,45,1) );
int x,y;
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,66, "PHE:" );
ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.PHExp,COLOR_MEDIUMSEAGREEN,39,66, 100 );
phe is ph expansion, so unless you have a ph expansion module you will not have any numbers in there.
I would suggest you not even picking that expansion module when generating the code.
According to your code, the heater will only turn on when it reaches 70 degrees.
It turns on when it reaches 70 and turns off when reaches 78.
I think you either didn't understand the settings or you mistyped.
Currently the temperature is at 72.5 and the outlet is still not on
I guess i will set it at 72.5 and see if that works. i thought I could put it a say 10 degrees and anywhere from 10-78 it would still be on. I guess it has to be set at the temperature it will actually reach down to.
Ok it fixed the problem. Thanks everyone!
That is a common error...but if that were the logic what would happen if the tank were at 68 degrees?
Edit: based on your initial example 70-78
ok so i tried to lower the on temperature and it won't work again. It seems to only work if I set the heater at the current temperature probes reading as the on temperature.
Ok, so let me try to explain this again....
The heater will only turn on when it hit the low temp setting and turn off when it hits the high temp setting.
So, until the temp goes down to 70 degress, the heater won't turn on. The minute it hits 70, it will turn on and it will not turn off until it hits 78 degrees. The minute it hits 78, it turns off and will remain off until it hits 70 degress again and the cycle repeats.
