good evening since Arduino takes a shorter code ho.problema to alternate the pumps every 6 hours, using the wizard mi.da or random or constant in seconds, but I have to do 6 hours and a stop and then the next 6 hours and a stop and so on
Inviato dal mio GT-I9300 utilizzando Tapatalk
Problem wavemaker
marco3020
Re: Problem wavemaker
Up
marco3020
Help me
marco3020
Help me please
johniii
How long does it need to stop for. You want 6hrs on 6hrs off
marco3020
Thanks for taking my call I do not know how to get them to say to the reef angel do go a pump 6 hours and then stop her and go do the other 6 hours and stop her and then resumes
- lnevo
ReefAngel.Relay.Set(Port5, now()%(12*SECS_PER_HOUR)<(6*SECS_PER_HOUR) );
ReefAngel.Relay.Set(Port6, now()%(12*SECS_PER_HOUR)>(6*SECS_PER_HOUR) );
now % (12 * SECS_PER_HOUR) means to divide the time by 12 hours and look at the remainder.. If it's less than 6 hours then one port will be on (Port 5). If it's greater than 6 hours the other port (Port 6)will be on.
marco3020
ReefAngel.AddDateTimeMenu();
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit;
InternalMemory.OverheatTemp_write( 273 );
ReefAngel.Relay.On( Port5 );
ReefAngel.SingleATO( true,Port1,60,0 );
ReefAngel.StandardLights( Port2,8,0,17,0 );
ReefAngel.StandardHeater( Port3,251,261 );
ReefAngel.StandardFan( Port4,265,271 );
ReefAngel.Relay.DelayedOn( Port7,5 );
ReefAngel.PWM.SetDaylight( PWMSlope(8,0,17,0,5,15,60,5) );
ReefAngel.PWM.SetActinic( PWMSlope(8,0,17,0,5,70,60,5) );
not fuction error uploading
- lnevo
