Problem wavemaker
Ask in here.
marco3020
Problem wavemaker
Post by marco3020 »
good evening since Arduino takes a shorter code ho.problema to alternate the pumps every 6 hours, using the wizard mi.da or random or constant in seconds, but I have to do 6 hours and a stop and then the next 6 hours and a stop and so on
Inviato dal mio GT-I9300 utilizzando Tapatalk
marco3020
Re: Problem wavemaker
Post by marco3020 »
Up
marco3020
Post by marco3020 »
Help me
marco3020
Post by marco3020 »
Help me please :(
johniii
Post by johniii »
How long does it need to stop for. You want 6hrs on 6hrs off
marco3020
Post by marco3020 »
Thanks for taking my call I do not know how to get them to say to the reef angel do go a pump 6 hours and then stop her and go do the other 6 hours and stop her and then resumes
ReefAngel.Relay.Set(Port5, now()%(12*SECS_PER_HOUR)<(6*SECS_PER_HOUR) );
ReefAngel.Relay.Set(Port6, now()%(12*SECS_PER_HOUR)>(6*SECS_PER_HOUR) );
now % (12 * SECS_PER_HOUR) means to divide the time by 12 hours and look at the remainder.. If it's less than 6 hours then one port will be on (Port 5). If it's greater than 6 hours the other port (Port 6)will be on.
marco3020
Post by marco3020 »
ReefAngel.AddDateTimeMenu();
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit;
InternalMemory.OverheatTemp_write( 273 );
ReefAngel.Relay.On( Port5 );
ReefAngel.SingleATO( true,Port1,60,0 );
ReefAngel.StandardLights( Port2,8,0,17,0 );
ReefAngel.StandardHeater( Port3,251,261 );
ReefAngel.StandardFan( Port4,265,271 );
ReefAngel.Relay.DelayedOn( Port7,5 );
ReefAngel.PWM.SetDaylight( PWMSlope(8,0,17,0,5,15,60,5) );
ReefAngel.PWM.SetActinic( PWMSlope(8,0,17,0,5,70,60,5) );
not fuction error uploading
What is the error you are getting?
