Progressive sunphase
Deckoz2302
Post by Deckoz2302 »
Ok so I have been working on creating a progressive sunphase dependant on date and preset variables. So far the function is about 100 lines of code. still have a little way to go.
void season()
	#define forceseasoncalculation
	#define longitude = ;
	static int ndays = 0;
	static byte ledch0base = 0;
	static byte ledch1base = 0;
	static byte ledch2base = 0;
	static byte ledch3base = 0;
	static byte ssnp = 0;
	static byte ssnpt = 0;
	byte rtime = 0;
	byte rhour = 0;
	byte rmin = 0;
	byte rsec = 0;
	byte stime = 0;
	byte shour = 0;
	byte smin = 0;
	byte ssec = 0;
	static int iDiffrise = 0;
	static int iDiffset = 0;
	int risediffperday = 0;
	int setdiffperday = 0;
	int totalrise = 0;
	int totalset = 0
	int atoi ( const char * str );
	int risehour[8]= {07,07,07,06,06,05,06,06};
	int riseminute[8]={00,30,00,30,00,30,00,30};
	int sethour[8] = {05,06,06,07,07,07,07,06};
	int setminute[8] = {30,00,30,00,00,30,00,00};
	if (hour()==0 && minute()==0 && second()==0) ssnp=0;
		#ifdef forceseasoncalculation
			If (ssnp==0)
	#else
		if (hour()==0 && minute()==0 && second()==1 && ssnp==0)
	#endif
		//leapyear or not?
		if (year()%4 == 0 && !(year()%100 == 0 && year()%400 != 0)) DaysPerMonth = {31, 29, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31};
		//every other year
		else DaysPerMonth = {31, 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31};
		//adding up past months days
		for (i=0; i<month() - 1; i++) ndays += DaysPerMonth[i];
			//adding current months days, julian day number is output ex: nday = 192
			ndays += day();
		//define days between begin and middle season
		int seasons[8] ={0,45,96,135,187,238,283,328}
		//define season
		for (s=0; seasons[s]<ndays; s++);
		//define which sunrise/set array value to pull, if nday = 46, 46
		if (ndays < seasons[s]) ssnpt = s, ssnp = s-1;
		if (ssnpt >= 7) ssnpt = 1;
//calculate sunrise difference in time between array pulled days
char tm1[9] = "risehour[ssnp]:riseminute[ssnp]:00";
char tm2[9] = "risehour[ssnpt]:riseminute[ssnpt]:00";
tm1[2]=tm1[5]=tm2[2]=tm2[5]=0;
iDiffrise = (atoi(tm1)-atoi(tm2))*3600 + (atoi(tm1+3)-atoi(tm2+3))*60 + (atoi(tm1+6)-atoi(tm2+6));
char tm3[9] = "sethour[ssnp]:setminute[ssnp]:00";
char tm4[9] = "sethour[ssnpt]:setminute[ssnpt]:00";
tm3[2]=tm3[5]=tm4[2]=tm4[5]=0;
iDiffset = (atoi(tm3)-atoi(tm4))*3600 + (atoi(tm3+3)-atoi(tm4+3))*60 + (atoi(tm3+6)-atoi(tm4+6));
//calculate new sunrise/set difference from array value
risediffperday = idiffrise/(season[ssnp]-season[ssnpt]);
totalrise = risediffperday*(nday - season[ssnp]);
setdiffperday = idiffset/(season[ssnp]-season[ssnpt]);
totalset = setdiffperday*(nday - season[ssnp]);
//creating time in seconds
rtime=(risehour[ssnp]*3600)+(riseminute[ssnp]*60)+(risesecond[ssnp])
if (ssnp = 0 || ssnp = 2 || ssnp = 4 || ssnp = 6) rtime += totalrise;
else rtime -= totalrise;
stime=(sethour[ssnp]*3600)+(setminute[ssnp]*60)+(setsecond[ssnp])
if (ssnp = 1 || ssnp = 3 || ssnp = 5 || ssnp = 7) stime += totalset;
else stime -= totalset;
//turning seconds back to h m s
rhour=rtime/3600;
rtime=rtime%3600;
rmin=rtime/60;
rtime=rtime%60;
rsec=rtime;
if(rsec > 30) rmin++;
shour=stime/3600;
stime=stime%3600;
smin=stime/60;
stime=stime%60;
ssec=stime;
if(ssec > 30) smin++;
//time for each active led channel to pull for sunrise
int Sunrise[2]={rhour,rmin};
int Sunset[2]={shour,smin};
//set LED channel PWM intensity values
ledch0int = random(25+(3*ssn),30+(3*ssn));
ledch1int = random(65+(3*ssn),70+(3*ssn));
ledch2int = random(65+(3*ssn),70+(3*ssn));
ledch3int = random(50+(3*ssn),55+(3*ssn));
anyway back to thinking lol
Deckoz2302
Re: Progressive sunphase
Be advised that buckpucks have a very strange configuration that does not isolate the output side to the dimming circuitry, which leads to a lot of noise that causes RA to crash. We had to create a special circuitry board to isolate the signal to make it work.
hmm...I just saw this post, I use buckpucks. What exactly does this circuit contain? got a parts list?
Humm...
Buckpucks... We had to create a special board with opto-isolators to eliminate the noise generated by the buckpucks. The other benefit of having this circuit was to invert the signal so the pucks repond to the same way that RA PWM signals are generated, which is 0%=off and 100%=on. For some reason buckpucks use inverted signals.
The opto chip used was LTV827.
http://search.digikey.com/us/en/product ... -ND/385838
Deckoz2302
Just ordered my RA. got any input on this code or if I'm close? See anything wrong with what's posted already?
Deckoz2302
Alright here is what I got so far. However couple of problems trying to think of how to fix this error "initializer-string for array of chars is too long" for these lines
		char tm2[9] = "risehour[ssn]:riseminute[ssn]:00";
		char tm4[9] = "sethour[ssn]:setminute[ssn]:00";
Also Im not sure if I returned the values Sunrise & Sunset from Seasons to Loop properlly, my brain hurts >.<. Help would be appreciated.
#include <ReefAngel_Colors.h>
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
//Start of PWM Expansion Code Header
// This is just how we are going to reference the PWM expansion ports within the code.
// You can change the labels if you would like, just as long as they are changed all throughout the code too.
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
// Initial values to all 6 channels at startup. They will always be 0.
byte PWMChannel[]={
  0,0,0,0,0,0};
byte cloudchance=0;
byte cloudduration=0;
int cloudstart=0;
//End of PWM Expansion Code Header
//Custom mainscreen copied from the custom main thread - constantly getting errors about LCD?
    //WifiAuthentication("Brad:Blank");
    ReefAngel.FeedingModePorts = B10100000;
    ReefAngel.WaterChangePorts = B10101000;
    ReefAngel.OverheatShutoffPorts = B01000000;
    ReefAngel.LightsOnPorts = B00000010;
    ReefAngel.Relay.On(Port1);
    ReefAngel.Relay.On(Port2);
    ReefAngel.Relay.On(Port3);
    ReefAngel.Relay.On(Port4);
    ReefAngel.Relay.On(Port5);
    ReefAngel.Relay.On(Port6);
	int Sunrise[2];
        int Sunset[2];
        int whSunrise[2];
        int whSunset[2];
        int vSunrise[2];
        int vSunset[2];
  	//Heater on&off
    	ReefAngel.StandardHeater(Port7,780,792);
		//Delay Skimmer
		ReefAngel.Relay.DelayedOn(Port8, 5);
		//call moonphase
		if ( hour() <= 6 || hour () >= 19 ) // Moonlights on from 7PM to 7AM
				ReefAngel.PWM.SetActinic(0);
				ReefAngel.PWM.SetDaylight(0);
                Seasons();
		PWMChannel[LEDPWM0]=PWMSlope(whSunrise[1],whSunrise[2],whSunset[1],whSunset[2],0,100,180,PWMChannel[LEDPWM0]);
		PWMChannel[LEDPWM1]=PWMSlope(vSunrise[1],vSunrise[2],vSunset[1],vSunset[2],0,100,180,PWMChannel[LEDPWM1]);
		PWMChannel[LEDPWM2]=PWMSlope(Sunrise[1],Sunrise[2],Sunset[1],Sunset[2],0,100,180,PWMChannel[LEDPWM2]);
		PWMChannel[LEDPWM3]=PWMSlope(Sunrise[1],Sunrise[2],whSunset[1],whSunset[2],0,100,180,PWMChannel[LEDPWM3]);
		//Call Cloud Check
		CheckCloud();
		//Draw PWM value
		//ReefAngel.LCD.DrawText(0,255,5,120,PWMChannel[LEDPWM0]);
		//ReefAngel.LCD.DrawText(0,255,35,120,PWMChannel[LEDPWM1]);
		//ReefAngel.LCD.DrawText(0,255,65,120,PWMChannel[LEDPWM2]);
		//ReefAngel.LCD.DrawText(0,255,95,120,PWMChannel[LEDPWM3]);
//Start of PWM slope function code designed for the PWM Expansion module
void PWMExpansion(byte cmd, byte data)
Wire.beginTransmission(8); // transmit to device #2
Wire.send('$'); // sends $
Wire.send(cmd); // sends a value
Wire.send(data); // sends 255
Wire.endTransmission(); // stop transmitting
//End of PWM slope function code designed for the PWM Expansion module
void CheckCloud()
#define Clouds_Every_X_Days 3
#define Cloud_Chance_per_Day 30
#define Min_Cloud_Duration 6
#define Max_Cloud_Duration 20
#define Min_Clouds_per_Day 2
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(11,00)
#define End_Cloud_Before NumMins(17,00)
#define Lightning_Change_per_Cloud 65
#define Actinic_Channels B001110
#define Daylight_Channels B000001
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
#ifdef forcecloudcalculation
    if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
      for (int a=0;a<6;a++)
          PWMChannel[a]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[a],0,180);
        for (int b=0;b<6;b++)
            else lightningstatus=0;
            if (lightningstatus) PWMChannel[b]=100;
            else PWMChannel[b]=0;
            //delay(10);
            PWMChannel[b]=20;
      cloudindex++;
      if (cloudindex < numclouds)
      int x=0;
    if (lightningchance)
      int x=0;
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
void Seasons()
	static short ndays = 0;
	static byte ssn = 0, ssnp = 0, ssnpt = 0;
	int wrtime = 0;
	int wstime = 0;
	int rtime = 0;
	int stime = 0;
	int vrtime = 0;
	int vstime = 0;
	byte wrhour = 0, wrrmin = 0, wrsec = 0,wshour = 0,wsmin = 0, wssec = 0, rhour = 0, rmin = 0, rsec = 0, shour = 0, smin = 0, ssec = 0, vrhour = 0, vrmin = 0, vrsec = 0, vshour = 0, vsmin = 0, vssec = 0;
	static byte iDiffrise = 0;
	static byte iDiffset = 0;
	short risediffperday = 0;
	short setdiffperday = 0;
	short totalrise = 0;
	short totalset = 0;
        byte i = 0, tyd=0, s=0;
        int DaysPerMonth[12];
        byte DaysPerYear = 0;
	//rise and set times set by hour and minute.
	int sethour[8] = {17,18,18,19,19,19,19,18};
			if (ssnp==0)
	#else
	#endif
		//leapyear or not?
		if (year()%4 == 0 && !(year()%100 == 0 && year()%400 != 0)) int DaysPerMonth[] = {31, 29, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31};
		//every other year
		else int DaysPerMonth[] = {31, 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31};
			ndays += day();
		//output total days in year for final season day count later in code
		for(tyd=0;tyd<11;tyd++)DaysPerYear += DaysPerMonth[tyd];
		int seasons[9] ={0,45,96,135,187,238,283,328,DaysPerYear};
		//define season and array pulling variable
		for (s=0; seasons[s] < ndays; s++) ssn = s, ssnpt = s, ssnp = s-1;
		//set loop on array time pulling variable to go back to beginning instead of increasing array size
		if (ssn > 7) ssn = 0;
		//calculate sunrise difference in time between array pulled days, in other words if seasons rise start is 730, and mid season rise start is 30 minutes
		//here we take the difference in day and get a difference in seconds per day. So if the time difference is 30 minutes from the last equation we divide that by the start day of season subtracted by the end day of season to get the number of days in the season
		//example: 30 minutes/(day 45 – day 0) = 30/45 = 0.66666
		//0.66666 is the difference of minutes each day throughout the season for sunrise
		risediffperday = idiffrise/(season[ssnpt]-season[ssnp]);
		setdiffperday = idiffset/(season[ssnpt]-season[ssnp]);
		//here are three different times offset by half hour to have different colors rise and set at different times
		//standard times
		rhour=rtime/3600;
			rtime=rtime%3600;
				rmin=rtime/60;
					rtime=rtime%60;
						rsec=rtime;
		shour=stime/3600;
			stime=stime%3600;
				smin=stime/60;
					stime=stime%60;
						ssec=stime;
		//to change the offset change the number 1200 in seconds added or subtracted to rtime
		//half hour shorter
		wrtime = rtime + 1200;
			wrhour = wrtime/3600;
				wrtime=wrtime%3600;
					wrmin=wrtime/60;
						wrtime=wrtime%60;
							wrsec=wrtime;
								if(wrsec>30) wrmin++;
		wstime = stime - 1200;
			wshour = wstime/3600;
				wstime=wstime%3600;
					wsmin=wstime/60;
						wstime=wstime%60;
							wssec=wstime;
								if(wssec>30) wsmin++;
		//half hour longer
		vrtime = rtime - 1200;
			vrhour = vrtime/3600;
				vrtime=vrtime%3600;
					vrmin=vrtime/60;
						vrtime=vrtime%60;
							vrsec=vrtime;
								if(vrsec>30) vrmin++;
		vstime = stime + 1200;
			vshour = vstime/3600;
				vstime=vstime%3600;
					vsmin=vstime/60;
						vstime=vstime%60;
							vssec=vstime;
								if(vssec>30) vsmin++;
return int Sunrise[2]={rhour,rmin};
return int Sunset[2]={shour,smin};
return int whSunrise[2]={wrhour,wrmin};
return int whSunset [2]={wshour,wsmin};
return int vSunrise[2]={vrhour,vrmin};
return int vSunset [2]={vshour,vsmin};
When you declare char tm1[9], you are declaring the variable tm1 is an array of char.
We can say that the variable char is one single ascii character to make it easier.
So, you variable tm1[9] is an array of characters, which is the same as a string.
In other words, the way to look a char [] is to look them as a string.
If you declare the char[9], the actual size of the string is 8, because the last character has to be always null. It's called null termination and the code knows that it has to look for a null when reading the memory.
http://www.arduino.cc/en/Reference/String
I'm confused as to what the code is trying to do.
If I look at the code, even though it is wrong, I can see that what you are trying to do is fill the variable tm1 with a human readable time string.
Let assign number for sake of example. risehour is 10 and riseminute is 15.
The tm1 variable would look like something like this "10:15:00"
Then this line throws me completely off.
It's replacing the ":" on the tm1 string with null characters. So, the string would terminate right after 10.
The string would look like this "10\015\000", where \0 is the null character.
If that wasn't confusing enough, the next line just makes no sense.
The function atoi(tm1) is turning the string tm1 back to integer for some math calculation. It doesn't make sense to turn risehour and riseminute from integer into a string, just to turn it back to integer again to do some math.
Maybe we can optmize this piece so you don't have to go from int to string and back to int again.
Could you explain a little what the intention of this piece of code is?
Deckoz2302
yea....I couldnt figure out why I wrote it like that a month ago haha...I just rewrote it, although still unsure if its right. that peice of code was basically taking two different times say 730 and 700 and finding the difference between them in minutes. and the next block takes the number of days in the partial season say 45 days and divides the minutes by that to find the difference in sunrise/set per day. so 30/45 = 0.66666 or 41 seconds...ugh now im confusing myself lol
int rise1 = calcSec(risehour[ssnp],riseminute[ssnp]);
                int rise2 = calcSec(risehour[ssn],riseminute[ssn]);
                iDiffrise = calcTime(rise1, rise2);
                int set1 = calcSec(sethour[ssnp],setminute[ssnp]);
                int set2 = calcSec(sethour[ssn],setminute[ssn]);
                iDiffset = calcTime(set1,set2);
they reference these two ints
int calcSec(int hr, int minu)
    int hour = hr * 3600;
    int min = minu * 60;
    int totalseconds=hour+min;
    return totalseconds;
int calculateTime(int seconds1, int seconds2)
    int timediff=seconds1-seconds2;
    return timediff;
now im having a problem figuring this out now haha...man writing this stuff a month ago and coming back to it thinking wtf did i do this for...lol
		rtime=(risehour[ssnp]*3600)+(riseminute[ssnp]*60);
		if (ssnp = 0 || ssnp = 2 || ssnp = 4 || ssnp = 6) rtime =+ totalrise;
			else rtime =- totalrise;
		stime=(sethour[ssnp]*3600)+(setminute[ssnp]*60);
on both if statements I get the error lvalue required as left opperand of assignment. Man now I remember why my teachers always said don't ever stop coding, cause you'll forget stuff...ugh
and for the last bit of code I posted the reason it is an if/else statement declaring whether to subtract the time or add the time is to account for whether the rise/set time is increasing or lowering in these four arrays
Much better :)
But, instead of reinventing the wheel, why not use the built-in time funtions we currently have?
We already have these:
Number of minutes from midnight:
int NumMins(uint8_t ScheduleHour, uint8_t ScheduleMinute)
Leap year:
bool IsLeapYear(int year)
Unix time, for more info, look in the Time.h and Time.cpp files:
time_t makeTime(tmElements_t &tm){
// assemble time elements into time_t
// note year argument is offset from 1970 (see macros in time.h to convert to other formats)
// previous version used full four digit year (or digits since 2000),i.e. 2009 was 2009 or 9
Where the tm structure is like this:
typedef struct  {
  uint8_t Second;
  uint8_t Minute;
  uint8_t Hour;
  uint8_t Wday;   // day of week, sunday is day 1
  uint8_t Day;
  uint8_t Month;
  uint8_t Year;   // offset from 1970;
} 	tmElements_t, TimeElements, *tmElementsPtr_t;
BTW, the compile error is on the comparison sign.
In C, one "=" is assigning and "==" is comparison.
So your code has to look like this:
      if (ssnp == 0 || ssnp == 2 || ssnp == 4 || ssnp == 6) rtime =+ totalrise;
Deckoz2302
oh wow ...lol im simple lol and i dont know why im reinventing the wheel....probably cause I didnt look at what the wheel already had >.< or how to implement it...haha
Here is a cut down pde of just the seasons function and how it should work...took all the other stuff out to make it easier to look at for help
i think its close now...just trying to remember how to return the values at the end to the integer arrays in Loop for pwmslope to pull. The last quations will round up 1 minute if remaining seconds are above 30.
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
byte PWMChannel[]={
  0,0,0,0,0,0};
byte cloudchance=0;
int cloudstart=0;
int calcSec(int,int);
int calcTime(int,int);
    ReefAngel.Init();
	int Sunrise[2];
        int Sunset[2];
        int whSunrise[2];
        int whSunset[2];
        int vSunrise[2];
        int vSunset[2];
        Seasons();
void Seasons()
	short ndays = 0;
	int wrtime = 0;
	int wstime = 0;
	int rtime = 0;
	int stime = 0;
	int vrtime = 0;
	int vstime = 0;
	int wrhour = 0, wrmin = 0, wrsec = 0,wshour = 0,wsmin = 0, wssec = 0, rhour = 0, rmin = 0, rsec = 0, shour = 0, smin = 0, ssec = 0, vrhour = 0, vrmin = 0, vrsec = 0, vshour = 0, vsmin = 0, vssec = 0;
	int totalrise = 0;
	int totalset = 0;
	//rise and set times set by hour and minute. there are 4 seasons however there are 8 highs & lows in rise and set throughout the year first spot is second half of winter starting jan 1st
			if (ssnp==0)
	#else
	#endif
		//leapyear or not?
		//every other year
			ndays += day();
                //differece in seconds between season array times
		risediffperday = iDiffrise/(seasons[ssnpt]-seasons[ssnp]);
		totalrise = risediffperday*(ndays - seasons[ssnp]);
		setdiffperday = iDiffset/(seasons[ssnpt]-seasons[ssnp]);
		totalset = setdiffperday*(ndays - seasons[ssnp]);
		if (ssnp == 1 || ssnp == 3 || ssnp == 5 || ssnp == 7) stime += totalset;
		//standard times
		rhour=rtime/3600;
			rtime=rtime%3600;
				rmin=rtime/60;
					rtime=rtime%60;
						rsec=rtime;
		shour=stime/3600;
			stime=stime%3600;
				smin=stime/60;
					stime=stime%60;
						ssec=stime;
		//half hour shorter
				wrtime=wrtime%3600;
					wrmin=wrtime/60;
						wrtime=wrtime%60;
							wrsec=wrtime;
				wstime=wstime%3600;
					wsmin=wstime/60;
						wstime=wstime%60;
							wssec=wstime;
		//half hour longer
				vrtime=vrtime%3600;
					vrmin=vrtime/60;
						vrtime=vrtime%60;
							vrsec=vrtime;
				vstime=vstime%3600;
					vsmin=vstime/60;
						vstime=vstime%60;
							vssec=vstime;
    return timediff;
Deckoz2302
ok...I remembered you cant return arrays in c soo i finished the code however the sketch is 2000bytes to big...ugh which leaves no room for wifi, vortech, custom main ato ect ect...its all lights :(
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
byte PWMChannel[]={
  0,0,0,0,0,0};
byte cloudchance=0;
int cloudstart=0;
  	//Heater on&off
		//Delay Skimmer
		//call moonphase
                //Seasons
                Seasons();
		//Call Cloud Check
		CheckCloud();
		//Draw PWM value
void CheckCloud()
#else
#endif
      if (cloudchance)
  if (cloudchance)
            //delay(10);
            PWMChannel[b]=20;
      cloudindex++;
      int x=0;
      int x=0;
  cstart*=60;
  cend*=60;
void Seasons()
	short ndays = 0;
	int wrtime = 0;
	int wstime = 0;
	int rtime = 0;
	int stime = 0;
	int vrtime = 0;
	int vstime = 0;
	int totalrise = 0;
	int totalset = 0;
			if (ssnp==0)
	#else
	#endif
		//leapyear or not?
		//every other year
			ndays += day();
		//standard times
		rhour=rtime/3600;
			rtime=rtime%3600;
				rmin=rtime/60;
					rtime=rtime%60;
						rsec=rtime;
		shour=stime/3600;
			stime=stime%3600;
				smin=stime/60;
					stime=stime%60;
						ssec=stime;
		//half hour shorter
				wrtime=wrtime%3600;
					wrmin=wrtime/60;
						wrtime=wrtime%60;
							wrsec=wrtime;
				wstime=wstime%3600;
					wsmin=wstime/60;
						wstime=wstime%60;
							wssec=wstime;
		//half hour longer
				vrtime=vrtime%3600;
					vrmin=vrtime/60;
						vrtime=vrtime%60;
							vrsec=vrtime;
				vstime=vstime%3600;
					vsmin=vstime/60;
						vstime=vstime%60;
							vssec=vstime;
//return Sunrise, Sunset, whSunrise,whSunset,vSunrise,vSunset;
int calcTime(int seconds1, int seconds2)
    return timediff;
Custom main actually may even decrease the code size if you remove the graph.
Try using simple menu to decrease the size.
Using custom menu will reduce even more.
Deckoz2302
You asked me to post what I had so far so here it is. Since we will be moving the lighting code to the pwm module I would like to be able to still access the following info - sunrise/set time for standard non offset time(there are 3 sets of times), cloud & lightning times for main screen, the ability to send lightning times to controller to change RF module to storm mode(where is rf documentation for programming?).
#include <avr/pgmspace.h>
#include <ReefAngel_Salinity.h>
#include <ReefAngel_RF.h>
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
byte PWMChannel[]={
  0,0,0,0,0,0};
byte cloudchance=0;
int cloudstart=0;
//Define Relay Ports
#define PowerCenter         1
#define LEDPSU              2
#define Refugium            3
#define Reactors            4
#define Vortechs            5
#define Return              6
#define Heater              7
#define Skimmer             8
//Seasons Seconds Calculator integers
//Custom Main, Graph & Menu
void ConvertNumToString(char* string, int num, byte decimal)
  char temptxt[3];
  int Temp = num;
  if (Temp==0xFFFF) Temp=0;
  itoa(Temp/decimal,string,10);
  if (decimal>1)
      itoa(Temp%decimal,temptxt,10);
      strcat(string, ".");
      if (Temp%decimal<10 && decimal==100) strcat(string, "0");
      strcat(string, temptxt);
  byte x = 6;
  byte y = 2;
  byte t;
  ReefAngel.LCD.DrawDate(6, 2);
  x = 12;
  y += MENU_START_ROW+1;
  ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Display         pH");
  char text[7];
  ReefAngel.LCD.Clear(DefaultBGColor, x+16, y+65, x+65, y+16);
  ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+75, y+18, text,
Font8x16);
  y += MENU_START_ROW*2;
  x = 10;
  x += (16*4) + 8;
  ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,8,y+25,"Sump:");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp2, T2TempColor,
24, y+35, 10);
  ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,x+8,y+25,"Room:");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp3, T3TempColor,
x+24, y+35, 10);
  ConvertNumToString(SALtxt, ReefAngel.Params.Salinity, 10);
ReefAngel.LCD.DrawHugeNumbers(COLOR_LIMEGREEN, DefaultBGColor, 5, 55, SALtxt);
  //y += 39*2;
// x = 13;
  ReefAngel.LCD.DrawOutletBox(12, 92, TempRelay);
   // #ifdef RelayExp
  // draw 1st expansion relay
// TempRelay = ReefAngel.Relay.RelayDataE[0];
// TempRelay &= ReefAngel.Relay.RelayMaskOffE[0];
//  TempRelay |= ReefAngel.Relay.RelayMaskOnE[0];
// ReefAngel.LCD.DrawOutletBox(12, 105, TempRelay);
//#endif   RelayExp
//End Custom
    //WifiAuthentication("Brad:");
    ReefAngel.Relay.On(PowerCenter);
    ReefAngel.Relay.On(Return);
    ReefAngel.Relay.On(Reactors);
    ReefAngel.Relay.On(Vortechs);
	ReefAngel.Relay.On(Refugium);
	    //Heater on&off
    	ReefAngel.StandardHeater(Heater,780,792);
		//Delay Skimmer
		ReefAngel.Relay.DelayedOn(Skimmer, 5);
		//call moonphase
        //Seasons
        Seasons();
		//Call Cloud Check
		CheckCloud();
		//Draw PWM value
void CheckCloud()
#else
#endif
      if (cloudchance)
  if (cloudchance)
            //delay(10);
            PWMChannel[b]=20;
      cloudindex++;
      int x=0;
      int x=0;
//End Cloud Function
//Reverse PWM slope from cloud function
  cstart*=60;
  cend*=60;
//End Reverse PWM function
//Calculate Sunrise/set by date & predefined season & rise/set times
void Seasons()
	short ndays = 0;
	int wrtime = 0;
	int wstime = 0;
	int rtime = 0;
	int stime = 0;
	int vrtime = 0;
	int vstime = 0;
	int totalrise = 0;
	int totalset = 0;
			if (ssnp==0)
	#else
	#endif
		//leapyear or not?
		//every other year
			ndays += day();
		//standard times
		rhour=rtime/3600;
			rtime=rtime%3600;
				rmin=rtime/60;
					rtime=rtime%60;
						rsec=rtime;
		shour=stime/3600;
			stime=stime%3600;
				smin=stime/60;
					stime=stime%60;
						ssec=stime;
		//half hour shorter
				wrtime=wrtime%3600;
					wrmin=wrtime/60;
						wrtime=wrtime%60;
							wrsec=wrtime;
				wstime=wstime%3600;
					wsmin=wstime/60;
						wstime=wstime%60;
							wssec=wstime;
		//half hour longer
				vrtime=vrtime%3600;
					vrmin=vrtime/60;
						vrtime=vrtime%60;
							vrsec=vrtime;
				vstime=vstime%3600;
					vsmin=vstime/60;
						vstime=vstime%60;
							vssec=vstime;
//End Seasons Calculation
//Seconds Calculator for Seasons function
    return timediff;
//End Seconds calculator
Ok, after a quick glance of your code, the only time RA needs to pass any values to the PWM module is for forced clouds, right?
Also, here is what I beleive are the values RA needs to pull from the PWM module to be displayed in your Custom Main Screen:
* All 6 PWM channels values
* Sunrise
* Sunset
* whSunrise
* whSunset
* vSunrise
* vSunset
* cloudstart
* cloudduration
Am I in the right path?
Deckoz2302
Yea, your on the right path. However we could narrow the values sent to few. All 6 channels run at 100%. So Id use one channel for pwm% on. Really just need the main values Sunrise & Sunset, the offset variations will clutter the screen. And cloudstart cloudduration. So 1 channel pwm percentage, sunrise time & sunset time using (Sunrise/Sunset) excluding wh/v variants, and cloud/lightning stuff. Don't wanna clutter the main screen to much.
Here is what I come up so far.
For the sake of getting it started, we will start with just pulling data and not pushing.
This is the test RA code:
  ReefAngel.Init();
  Wire.requestFrom(8,8);
  Serial.println("Start");
  for (int a=0;a<8;a++)
    if (Wire.available()) Serial.println(Wire.receive(),DEC);
It will read 8 bytes from the PWM expansion module and send to the serial port.
You can use the Serial Monitor on Arduino IDE to view the data being printed.
Here is the PWM Expansion Custom Seasons code:
#include "ReefAngel_Globals.h"
#include "ReefAngel_Features.h"
#include <avr/wdt.h>
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
int cloudstart=0;
int rhour = 0, rmin = 0, shour = 0, smin = 0;
byte PWMports[] ={
  3,5,6,9,10,11};
byte ChannelValue[] = {
  0,0,0,0,0,0};
// PWM, sunrisehour, sunriseminute, sunsethour, sunsetminute, cloudstarthout, cloudstartminute, cloudduration
byte SeasonsVar[]={
  0,0,0,0,0,0,0,0};
byte cmdnum=255;
byte datanum=255;
  Serial.begin(57600);
  Wire.begin(8);
  Wire.onReceive(receiveEvent);
  Wire.onRequest(requestEvent);
  randomSeed(analogRead(0));
  pinMode(3,OUTPUT);
  pinMode(5,OUTPUT);
  pinMode(6,OUTPUT);
  pinMode(9,OUTPUT);
  pinMode(10,OUTPUT);
  pinMode(11,OUTPUT);
  //wdt_enable(WDTO_1S);
  setSyncProvider(RTC.get);   // the function to get the time from the RTC
  setSyncInterval(SECS_PER_HOUR);  // Changed to sync every hour.
  now();
  wdt_reset();
  //Serial.println(ChannelValue[0],DEC);
  if (cmdnum!=255)
    ProcessCMD(cmdnum,datanum);
    cmdnum=255;
    datanum=255;
  Seasons();
  CheckCloud();
//  Serial.println("Start");
//  Serial.println(ChannelValue[0],DEC);
//  Serial.println(rhour,DEC);
//  Serial.println(rmin,DEC);
//  Serial.println(shour,DEC);
//  Serial.println(smin,DEC);
//  Serial.println(cloudstart/60,DEC);
//  Serial.println(cloudstart%60,DEC);
//  Serial.println(cloudduration,DEC);
    analogWrite(PWMports[a],ChannelValue[a]);
  wdt_reset();
  if (howMany==5)
    cmd1=Wire.receive();
    cmd2=Wire.receive();
    cmd3=Wire.receive();
    cmd4=Wire.receive();
    cmd5=Wire.receive();
    if (cmd1=='$' && cmd2=='$' && cmd3=='$')
      cmdnum=cmd4;
      datanum=cmd5;
      //Serial.println(cmd4,DEC);
      //Serial.println(cmd5,DEC);
    for (int a=0;a<howMany;a++)
      Wire.receive();
void ProcessCMD(byte cmd, byte data)
  wdt_reset();
  // Individual Channel
  if (cmd>=0 && cmd<=5)
    ChannelValue[cmd]=data;
    analogWrite(PWMports[cmd],data);
void requestEvent() {
  SeasonsVar[0]=ChannelValue[0];
  SeasonsVar[1]=rhour;
  SeasonsVar[2]=rmin;
  SeasonsVar[3]=shour;
  SeasonsVar[4]=smin;
  SeasonsVar[5]=cloudstart/60;
  SeasonsVar[6]=cloudstart%60;
  SeasonsVar[7]=cloudduration;
  Wire.send(SeasonsVar,8);
void CheckCloud()
#define Clouds_Every_X_Days 1
  // results could happen.
  //fit in that 510 minutes window.
#else
#endif
      if (cloudchance)
  if (cloudchance)
          ChannelValue[a]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,ChannelValue[a],0,180);
            if (lightningstatus) ChannelValue[b]=100;
            else ChannelValue[b]=0;
            //delay(10);
            ChannelValue[b]=20;
      cloudindex++;
  cstart*=60;
  cend*=60;
void Seasons()
  short ndays = 0;
  int wrtime = 0;
  int wstime = 0;
  int rtime = 0;
  int stime = 0;
  int vrtime = 0;
  int vstime = 0;
  int wrhour = 0, wrmin = 0, wrsec = 0,wshour = 0,wsmin = 0, wssec = 0, rsec = 0, ssec = 0, vrhour = 0, vrmin = 0, vrsec = 0, vshour = 0, vsmin = 0, vssec = 0;
  int totalrise = 0;
  int totalset = 0;
  //first spot is second half of winter starting jan 1st
    int risehour[8]= {
    07,07,07,06,06,05,06,06    };
  int riseminute[8]={
    00,30,00,30,00,30,00,30    };
  int sethour[8] = {
    17,18,18,19,19,19,19,18    };
    30,00,30,00,00,30,00,00    };
  if (ssnp==0)
#else
#endif
      //leapyear or not?
        31, 29, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31            };
      //every other year
        31, 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31            };
      ndays += day();
      int seasons[9] ={
        0,45,96,135,187,238,283,328,DaysPerYear            };
      //uation we divide that by the start day of season subtracted by the end day of season to get the number of days in the season
      //standard times
      rhour=rtime/3600;
      rtime=rtime%3600;
      rmin=rtime/60;
      rtime=rtime%60;
      rsec=rtime;
      shour=stime/3600;
      stime=stime%3600;
      smin=stime/60;
      stime=stime%60;
      ssec=stime;
      //half hour shorter
      wrtime=wrtime%3600;
      wrmin=wrtime/60;
      wrtime=wrtime%60;
      wrsec=wrtime;
      wstime=wstime%3600;
      wsmin=wstime/60;
      wstime=wstime%60;
      wssec=wstime;
      //half hour longer
      vrtime=vrtime%3600;
      vrmin=vrtime/60;
      vrtime=vrtime%60;
      vrsec=vrtime;
      vstime=vstime%3600;
      vsmin=vstime/60;
      vstime=vstime%60;
      vssec=vstime;
      int Sunrise[2]={
        rhour,rmin            };
      int Sunset[2]={
        shour,smin            };
      int whSunrise[2]={
        wrhour,wrmin            };
      int whSunset [2]={
        wshour,wsmin            };
      int vSunrise[2]={
        vrhour,vrmin            };
      int vSunset [2]={
        vshour,vsmin            };
      ChannelValue[LEDPWM0]=PWMSlope(whSunrise[1],whSunrise[2],whSunset[1],whSunset[2],0,100,180,ChannelValue[LEDPWM0]);
      ChannelValue[LEDPWM1]=PWMSlope(vSunrise[1],vSunrise[2],vSunset[1],vSunset[2],0,100,180,ChannelValue[LEDPWM1]);
      ChannelValue[LEDPWM2]=PWMSlope(Sunrise[1],Sunrise[2],Sunset[1],Sunset[2],0,100,180,ChannelValue[LEDPWM2]);
      ChannelValue[LEDPWM3]=PWMSlope(Sunrise[1],Sunrise[2],whSunset[1],whSunset[2],0,100,180,ChannelValue[LEDPWM3]);
  return timediff;
Let me know if you have problems getting it together.
Deckoz2302
If im not mistaken by your code this is the output im getting
Start
0 -channel0 PWM%
1 -Rise hour
27 - rise minute
0 - set hour
244 - set minute
11 -cloud start hour
34 - cloud start minute
17 - cloud duration
Hmm I wonder whats wrong, the Rise and set times dont make sense... hmm leme look at what i coulda done wrong in seasons()
Rewriting some things because some values arent coming out properly...
Yes, that is the order and I noticed the wrong numbers too, but those were coming from the Seasons() function. We may need to revisit the function.
Deckoz2302
ok I've been playing with this the better part of the morning. Rewrote some things after going value by value and changing the months on the RA to make sure it was pulling stuff correctly for each month.
All values are referenced and pulled properly now. I have rtime outputting the proper time. but I cannot figure out why I get a negative value on stime or any of the offset values(wrtime, vrtime ect) I always get 0 for hour and a negative for minutes ugh
All previouse values are pulled correctly, and the code is exactly the same as rtime except for using sethour & minute but both the first line stime = comes out negative and way off (like -3495) and the if statement comes out negative also(duh haha) hmmmm my eyeballs hurt
Here is the updated code of where I am at now
//Global integers
short Ndays;   //Returns the number of day in the year
void Seasons()
	static byte ssn , ssnp , ssnpt ;
	int wrtime = 0;
	int wstime = 0;
	int rtime = 0;
	int stime = 0;
	int vrtime = 0;
	int vstime = 0;
	int iDiffrise = 0;
	int iDiffset = 0;
	int totalrise = 0;
	int totalset = 0;
	byte s=0;
        int DaysPerYear;
	int risehour[8]= {7,7,7,6,6,5,6,6};
			if (ssnp==0)
	#else
	#endif
		//leapyear or not - Define days per year
		if (year()%4 == 0 && !(year()%100 == 0 && year()%400 != 0)) {DaysPerYear=366;}
		//every other year
		else {DaysPerYear = 365;}
		//Call Day Number Calc
                DayNumber(year(),month(),day());
                //ReefAngel.LCD.DrawText(0,255,5,100,Ndays);
                //ReefAngel.LCD.DrawText(0,255,5,110,DaysPerYear);
		for (s=0; seasons[s] < Ndays; s++) ssn = s+1, ssnpt = s+1, ssnp = s;
		if (ssn >= 7) ssn = 0;
                int rise1 = calcSec(risehour[ssn],riseminute[ssn]);
                int rise2 = calcSec(risehour[ssnp],riseminute[ssnp]);
                int set1 = calcSec(sethour[ssn],setminute[ssn]);
                int set2 = calcSec(sethour[ssnp],setminute[ssnp]);
		totalrise = risediffperday*(Ndays - seasons[ssnp]);
		totalset = setdiffperday*(Ndays - seasons[ssnp]);
		if (ssnp == 0 || ssnp == 2 || ssnp == 4 || ssnp == 6) rtime -= totalrise;
			else rtime += totalrise;
		//standard times
		rhour=rtime/3600;
			rtime=rtime%3600;
				rmin=rtime/60;
					rtime=rtime%60;
						rsec=rtime;
		shour=stime/3600;
			stime=stime%3600;
				smin=stime/60;
					stime=stime%60;
						ssec=stime;
		//half hour shorter
				wrtime=wrtime%3600;
					wrmin=wrtime/60;
						wrtime=wrtime%60;
							wrsec=wrtime;
				wstime=wstime%3600;
					wsmin=wstime/60;
						wstime=wstime%60;
							wssec=wstime;
		//half hour longer
				vrtime=vrtime%3600;
					vrmin=vrtime/60;
						vrtime=vrtime%60;
							vrsec=vrtime;
				vstime=vstime%3600;
					vsmin=vstime/60;
						vstime=vstime%60;
							vssec=vstime;
ReefAngel.LCD.DrawText(0,255,5,120,rhour);
ReefAngel.LCD.DrawText(0,255,35,120,rmin);
ReefAngel.LCD.DrawText(0,255,65,120,shour);
ReefAngel.LCD.DrawText(0,255,95,120,smin);
//Calculators for Seasons function
    int timediff=abs(seconds1-seconds2);
    abs(timediff);
    return timediff;
void DayNumber(unsigned int y, unsigned int m, unsigned int d)
  int days[]={0,31,59,90,120,151,181,212,243,273,304,334};    // Number of days at the beginning of the month in a not leap year.
//Start to calculate the number of day
  if (m==1 || m==2){
    Ndays = days[(m-1)]+d;			   //for any type of year, it calculate the number of days for January or february
  }				// Now, try to calculate for the other months
  else if ((y % 4 == 0 && y % 100 != 0) ||  y % 400 == 0){  //those are the conditions to have a leap year
    Ndays = days[(m-1)]+d+1;     // if leap year, calculate in the same way but increasing one day
  else {					  //if not a leap year, calculate in the normal way, such as January or February
//End calculators
Deckoz2302
omg this is driving me insane that Im getting negative numbers and that theyre way off
stime=calcSec(sethour[ssnp],setminute[ssnp]);
This line for today is pulling the value 18 for set hour and 00 for set minute and for some ungodly reason im getting the value -736 from this equation. When I should be getting 64800 seconds from it. it references this sub function
    int minut = minu * 60;
    int totalseconds=hour+minut;
so rtime,rhour,rmin are the only ints giving theyre proper values throughout the whole year. and all of the offsets such as wrhour, vrhour ect ect dont work....its as if after that first one it just takes a crap, even though all the values its pulling are correct..and they all use the same code ugh
int numbers are 16bit resolution (15 bit number with a 1 bit for signal), so it ranges from -32768 to +32768.
http://arduino.cc/en/Reference/Int
You are overflowing the variable if hr is anything over 9.
You must use long variables.
Try this:
long calcSec(int hr, int minu)
    long totalseconds;
    totalseconds=(hr*3600)+(minu*60);
I'm not sure if this will work, but give it a shot.
Deckoz2302
yea i figured that out in the past while...it doesnt work. i changed all of the variables that held anything over 32768...still getting -789 output ugh
Uh I need to take a break I've been wasting my day away tinkering and reloading coded a million times lol
Deckoz2302
For anyone that wants it here is the finalized pde...all offsets are working
all thanks goto roberto for the wire transfer protocol. otherwise it wouldt of been possible
to change the hours find this code- change each to match, ie if you change the first one to be a half hour later change them all to be half hour later ect
    int risehour[8]= {
    7,7,7,6,6,5,6,6      };
  int riseminute[8]={
  int sethour[8] = {
if you change the up/down comepletely you will need to rewrite these if statements to match the new up/down variation you create
      rtime=calcSec(risehour[ssnp],riseminute[ssnp]);
      if (ssnp == 0 || ssnp == 2 || ssnp == 4 || ssnp == 6){
        rtime -= totalrise;
      else {
        rtime += totalrise;
      if (ssnp == 1 || ssnp == 3 || ssnp == 5 || ssnp == 7){
        stime -= totalset;
      else {
        stime += totalset;
if you want to change the ammount of time offset for different colors change 1200 to whatever you want in seconds
RA - add to loop this to your loop
PWM MODULE PDE:
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
//Globals integers
long calcSec(long,long);
long calcTime(long,long);
int cloudstart=0;
byte PWMports[] ={
  3,5,6,9,10,11};
  0,0,0,0,0,0};
byte SeasonsVar[]={
  0,0,0,0,0,0,0,0};
byte cmdnum=255;
byte datanum=255;
  Wire.begin(8);
  pinMode(3,OUTPUT);
  pinMode(5,OUTPUT);
  pinMode(6,OUTPUT);
  pinMode(9,OUTPUT);
  pinMode(10,OUTPUT);
  pinMode(11,OUTPUT);
  now();
  wdt_reset();
  if (cmdnum!=255)
    cmdnum=255;
    datanum=255;
  Seasons();
  CheckCloud();
  wdt_reset();
  if (howMany==5)
      cmdnum=cmd4;
      datanum=cmd5;
      Wire.receive();
  wdt_reset();
  SeasonsVar[2]=rmin;
  SeasonsVar[4]=smin;
void CheckCloud()
#else
#endif
      if (cloudchance)
  if (cloudchance)
            //delay(10);
            ChannelValue[b]=20;
      cloudindex++;
  cstart*=60;
  cend*=60;
void Seasons()
  long stime, wstime, vstime, wrtime, rtime, vrtime;
  long wrhour,wrmin,wrsec,wshour,wsmin,wssec,rhour,rmin,rsec,shour,smin,ssec,vrhour,vrmin,vrsec,vshour,vsmin,vssec;
  int iDiffrise = 0;
  int iDiffset = 0;
  int totalrise = 0;
  int totalset = 0;
  byte s=0;
  int DaysPerYear;
    int risehour[8]= {
    7,7,7,6,6,5,6,6      };
  int riseminute[8]={
  int sethour[8] = {
  if (ssnp==0)
#else
#endif
        DaysPerYear=366;
      //every other year
      else {
        DaysPerYear = 365;
      int seasons[9] ={
      long rise1 = calcSec(risehour[ssn],riseminute[ssn]);
      long rise2 = calcSec(risehour[ssnp],riseminute[ssnp]);
      long set1 = calcSec(sethour[ssn],setminute[ssn]);
      long set2 = calcSec(sethour[ssnp],setminute[ssnp]);
        rtime -= totalrise;
      else {
        rtime += totalrise;
        stime -= totalset;
      else {
        stime += totalset;
      //standard times
      rhour=rtime/3600;
      rtime=rtime%3600;
      rmin=rtime/60;
      rtime=rtime%60;
      rsec=rtime;
      shour=stime/3600;
      stime=stime%3600;
      smin=stime/60;
      stime=stime%60;
      ssec=stime;
      //half hour shorter
      wrtime=wrtime%3600;
      wrmin=wrtime/60;
      wrtime=wrtime%60;
      wrsec=wrtime;
      wstime=wstime%3600;
      wsmin=wstime/60;
      wstime=wstime%60;
      wssec=wstime;
      //half hour longer
      vrtime=vrtime%3600;
      vrmin=vrtime/60;
      vrtime=vrtime%60;
      vrsec=vrtime;
      vstime=vstime%3600;
      vsmin=vstime/60;
      vstime=vstime%60;
      vssec=vstime;
      int Sunrise[2]={
        rhour,rmin                  };
      int Sunset[2]={
        shour,smin                  };
      int whSunrise[2]={
        wrhour,wrmin                  };
      int whSunset [2]={
        wshour,wsmin                  };
      int vSunrise[2]={
        vrhour,vrmin                  };
      int vSunset [2]={
        vshour,vsmin                  };
long calcSec(long hr, long minu)
    long totalseconds;
long calcTime(long seconds1, long seconds2)
  long timediff=abs(seconds1-seconds2);
  return timediff;
  int days[]={
    0,31,59,90,120,151,181,212,243,273,304,334      };    // Number of days at the beginning of the month in a not leap year.
  if (m==1 || m==2){
//End calculators
Deckoz2302
Roberto, im trying to call the values to print them on main screen trying to deciefer your code...lol guess im not doing so hot haha
if (Wire.available()) ReefAngel.LCD.DrawText(0,255,5,120,(Wire.receive()); shows a value of 10 and I cant call them by SeasonsVar or a number..hmmuhh
Ok, so for your RA PDE, you need to declare an array above setup()
byte SeasonsVar[]={
  0,0,0,0,0,0,0,0};
Then, on your loop(), add this instead of what you posted above:
    if (Wire.available()) SeasonsVar[a]=Wire.receive();
  ReefAngel.LCD.DrawText(0,255,5,120,SeasonsVar[0]);
This way, you can use the SeasonsVar anywhere within your PDE.
Deckoz2302
nice, thank you roberto!
Deckoz2302
Hmm finally getting around to using the cloud function roberto, The time and length of the cloud changes every 2 seconds and I cant seem to figure out why. Also how would I send data to the pwm to say force a thunderstorm?
How does it change?
Does it change to always to the future?
Or it always stays within a certain time window?
Deckoz2302
ok for example when i posted that, the hour was always 15 and the minutes changed every 2 seconds from 0-59, the duration changed every second or so within the predefined parameters i have which are 6min 30max
so hour stayed the same but minute would change every two seconds, until it rolls into the next hour then it says the current hour and minutes constantly change
it does the same thing over serial.println if turn off autoscroll and look at each set of seasonvars the cloudtime and duration is different each time
Can you post your latest PWM pde?
