First I want to control my fans in the hood by the T1 probe. I placed the probe close to the heat sink. I am using ReefAngel.Standartfan ( Port8, 850, 770) to turn on and off the fans. Fan control works fine, my problem is it also turns off my heater. How can I use the T2 probe for Heater control?
Second question, i don't have an ATO pump yet, I would like to use my switches as an indicator of the water level. I set one of clips to the bottom and the other to the second setting. How can I see the water level on the portal. I would like to see green when both are all the way to the top and when the water level goes down, the first one will turn red and later if I don't add water the second goes red?
/* #define Lights 1
#define Moonlight 2
#define Heater 3
#define Skimmer 4
#define Circulation1 5
#define Circulation2 6
#define Korelia 7
#define Hood Fan 8
ReefAngel.AddStandardMenu();
ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port4Bit | Port5Bit | Port6Bit;
InternalMemory.OverheatTemp_write( 840 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port7 );
ReefAngel.MoonLights( Port2 );
ReefAngel.WavemakerRandom1( Port5,90,120 );
ReefAngel.Relay.Set( Port6, !ReefAngel.Relay.Status( Port5 ) );
ReefAngel.StandardFan( Port8,850,770 );
ReefAngel.PWM.SetDaylight( PWMSlope(13,0,22,0,20,55,60,0) );
ReefAngel.PWM.SetActinic( PWMSlope(12,0,23,0,20,45,60,0) );
// LOW Switch
// ReefAngel.SingleATOLow(1);
// HIGH Switch
// ReefAngel.SingleATOHigh(1);
if (ReefAngel.DisplayedMenu!=FEEDING_MODE || ReefAngel.DisplayedMenu!=WATERCHANGE_MODE)
if (hour()>=23 || hour()<7)
ReefAngel.RF.UseMemory=false;
ReefAngel.RF.SetMode(Lagoon,10,0);
ReefAngel.RF.UseMemory=true;
ReefAngel.Portal( "Oceanwolf" );
