Dimmable LED Acclimation for corals
Re: Dimmable LED Acclimation for corals
I believe in the latest code that rufessor added a time limit so that the photoperiod could be constrained to a number of hours. Technically you can modify the percents or you could modify this field and change the range to whatever you want.
One thing I can't do is use ReefAngel.PWM.SetActinic(ActinicPWMValue);ReefAngel.PWM.SetDaylight(DaylightPWMValue) or ReefAngel.PWM.SetChannel( 0, PWMSlope(13,0,21,0,startPercent,endPercentWhite,90,20) ); within my current code as there isn't anything in there like that.
Here's what I have:
Here's what I have:
//By Matthew Hockin 2012.
//SWFLTEK library functions, #includes, and #define were copied directly from the Epherma library
//Epherma (SWFLTEK.com) was written by Michael Rice- thanks Michael it works great.
//If you copy from this (its all open source) please
//acknowledge Michael for SWFLTEK library code (obviously labeled) or Matthew Hockin (for the rest).
#include <avr/wdt.h>
//includes for SWFLTEK functions
#include <stdlib.h>
#include <math.h>
//***********************************ARRAYS YOU MUST MODIFY TO MAKE YOUR TANK SET UP WORK*****************************
//YOU MUST READ EVERY WORD IN THIS SECTION IN ORDER TO APPROPRIATELY CONFIGURE THIS PROGERAM- READ EVERY LINE BELOW///
byte ChMax[]={200,220,200,220,225,0,0,0};//Incremental value (Max-flicker) above flicker you want as max intensity (!!!!!!! Light Set Point is ChMax PLUS Flicker !!!!!!)
byte flicker[]={31,31,31,31,40,0,0,0};//need to input actual values here for flicker point on all channels in PWM expansion box
boolean Wchannel[]={1,0,1,0,0,0,0,0}; //use 1 to designate white channel (i.e. off during storm and used for lightning). Array corresponds to PWM channel 0-5 in order
//Array to give direction to dimming. e.g. DimOrder[]={0,0,1,1,0,0} (cloud chase effects, just group channels you want to dim together during a cloud or storm
//as either a 0 or a 1, i.e. all left side channels are 0 all right are 1 or all front are 0 all back are 1 or whatever
//(which is zero or 1 will change who dims first). set them all to 0 if your tank has no left/right or front/back lights.
byte DimOrder[]={0,0,1,1,1,0,0,0};
//set all channel positions that you would like to use for the lightning strike effect to 1 (0-5 are PWM channels 6,7 are Main PWM outs)- and channels with a 0 are not used in strike
byte StrikeChannel[]={1,1,1,1,1,0,0,0};
byte MoonCh[]={0,0,0,0,1,0,0,0};//place a 1 in the array position of all lighting channels you would like to use a moon lighting (this does not preclude their use in other phases (day, storm etc)
//**********************************DONE CHANGING THINGS HERE BUT YOU MUST CHANGE ChOffset array IN CalcSUN function******
//defines for SWFLTEK functions
// arc-seconds per radian
#define _sec_rad 206264.806247096370813
// axial tilt of earth at epoch, in radians
#define _tilt 0.409092804222329
// tropical year in seconds... rounding error accumulates to 26 seconds by the year 2136
#define _tropical_year 31556925
// 'zenith' of rising (setting) sun in radians (360 - 2 * 90.833 degrees)
#define _zenith 3.11250383272322
//*******************GLOBAL VARIABLE DECLERATIONS FOR MHOCKIN Weather package*************************************
//Unless your planning on editing the program DO NOT CHANGE ANYTHING HERE
long latitude, longitude;
byte TrueIntensity[8];//array used to place hold final write values for PWM intensity setting
long elapsedTime;//used multiple places as elapsed since midnight
long newDay;
unsigned long rise;//time in seconds from the year 2000 (GMT) for sunrise
unsigned long set;//time in seconds from the year 2000 (GMT) for sunrise
long ChRiseSet[16];//times of rise and set for all 8 channels based upon offsets from calc rise and set values
float ChSlope[16];//slopes for 1/2 day calculations based upon time from offset to midday for channel 1-8
long CloudMaster[20];// Set up array to hold start and end times for clouds for the day-
long midDay;// exactly 1/2 way between rise and set, i.e. solar noon for latitudes <60 close enough for us...
byte PWMports[] ={
3,5,6,9,10,11};
byte ChannelValue[8];// Array to store output of insolaiton which may be modified and stored in TrueIntensity which is used to write to the PWM channels
unsigned long StrikeStart;//timer to keep track of strike sequence
int StrikeMaster[20];//Array to hold random strike pattern generated by weather array is sized to MAX needed given strike patter generator (8 strikes=16 positions)
byte StrikeNumber;//place to hold total number of strikes this sequence
boolean StrikeNow;//starts lightning strike sequence in loop state change made in weather/storm loop
byte StrikeCount;//Used to properly sequence strike sequence for delay between strikes
byte cmdnum=255;
byte datanum=255;
byte dow=0;//day of week
byte strikePattern, strikeTime;//used in Lightning() for timing of particular instance of strike
boolean Cloud;// are we in a cloud interval on days that have clouds
boolean CloudToday;//set in CalcSun if randomization yields a day with clouds.
boolean IsStorm;// are we in a storm
byte CloudsTotal;// how many clouds today
long lastmillis;// variable to track millis to enable cloud and insolation loop restriction by time
boolean StormAdvance;//storm timer for light effect advance
boolean InsolationAdvance;//when true we recalculate light intensity during clear sky (every 3 seconds seems more than often enough)
byte counter;//used to track millis advance for insolation,cloud trigger
//END HEADER/Global Variable declaration//
//Setup
void setup(){
Serial.begin(57600);
Wire.begin(8);
//Wire.onReceive(receiveEvent);
//Wire.onRequest(requestEvent);
pinMode(3,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
pinMode(11,OUTPUT);
wdt_enable(WDTO_1S);
unsigned long seed=0, count=32;
while (--count){
seed = (seed<<1) | (analogRead(5)&1);
randomSeed(seed);//start random generator at a different point each time (not perfect but whatever its gonna be pretty damn random)
setSyncProvider(RTC.get); // the function to get the time from the RTC
setSyncInterval(SECS_PER_HOUR); // Changed to sync every hour.
dow=0;//set Day Of Week (dow) to a 0 value which is impossible (day()=1-7)... so we trigger calcSun on restart
StrikeNow=false;//no lightning strike yet
CloudToday=false;//set to no clouds so CalcSun can set correctly if should be true
Cloud=false;//set cloud to false
IsStorm=false;//set storm to false
lastmillis=millis();//start our millis timer now
counter=0;//used in weather for triggering a storm, triggering lightning in a storm.
StrikeCount=0;//Number of lightning strikes in the sequence.. set to zero until initialized in sequence
//End Setup
//Loop
void loop(){
elapsedTime=(now()-newDay);//Elapsed time is seconds from midnight of today- local processor time.
wdt_reset();
if (cmdnum!=255){
ProcessCMD(cmdnum,datanum);
cmdnum=255;
datanum=255;
if (dow!=day()){ //used to see that were in a new day and need to recalculate sunrise and sunset
CalSun();
dow=day();
//Use millis to enable tracking of time interval
if ((millis()-lastmillis)>=100){
counter+=1;
StormAdvance=true;
//now a bunch of stuff that may or may not be true at the same time but that all needs to happen when its true
if (counter==0){
InsolationAdvance=true;//so that it runs on start up to provide light immediately
if (counter%30==0){
if (counter==210) counter=0;
if (InsolationAdvance==true) Insolation();//calculate clear sky solar intensity as the day advances
Weather();//run the weather overlay (cloud, storm)
//check to see if were need to have a lightning strike
if (StrikeNow==true){
if ((millis()-StrikeStart)>=StrikeMaster[(StrikeCount*2)]){//check if time has passed the delay (position 0,2,4,6,8 etc in StrikeMaster)-StrikeCount is indexed up by 1 after each strike so we see positions 0,2,4,6,etc in sequence
byte intensity;
intensity=random(180,256);// this little bit should generate a randomly bright flash variation between the series of flashes in StrikeMaster
for (byte b=0; b<6; b++){
if (StrikeChannel[b]==1) analogWrite(PWMports[b],intensity);// set all strike channels to intensity of strike
delay(StrikeMaster[((StrikeCount*2)+1)]);//index to +1 position in array from 0,2,4, etc to 1,3,5 etc
StrikeCount++;//so that the next time we look at elapsed time were looking at the right array position
if (StrikeCount==(StrikeNumber-1)){
StrikeNow=false;
StrikeCount=0;
for (byte a=0;a<6;a++){//using all prior mods to light intensity (Insolation-->Cloud-->Storm) lets make some light
analogWrite(PWMports[a],TrueIntensity[a]);//dont change this to 8 to refelct array for channels.. we only have 6 here!
//End Loop
//Standard PWM Functions Receive/Process
wdt_reset();
if (howMany==5){
cmd1=Wire.read();
cmd2=Wire.read();
cmd3=Wire.read();
cmd4=Wire.read();
cmd5=Wire.read();
if (cmd1=='$' && cmd2=='$' && cmd3=='$'){
cmdnum=cmd4;
datanum=cmd5;
//Serial.println(cmd4,DEC);
//Serial.println(cmd5,DEC);
else{
for (int a=0;a<howMany;a++){
Wire.read();
void ProcessCMD(byte cmd, byte data){
wdt_reset();
//End Standard Functions
//Start of sunrise, sunset and cloud calculations- runs on reset and once a day thereafter.
void CalSun(){
//Serial.println("CalSun Run Now");
//*********************YOU NEED TO CHANGE THESE VALUES Read instructions in their ENTIRETY and CAREFULLY change to values for your tank and geographical region***************************
//channels 0-5 are PWM expansion board lights 6,7 are ReefAngel Controller PWM outputs
//offsets for rise/set all values in seconds offset from calculated rise or set value (-) am offset=longer day****** (-)pm offset=shorter day)
//array order is ch0 am offset, pm offset, ch1 am offset, pm offset etc..
//THESE values are the number of seconds that a particular channel will be offset from the rise/set time, i.e. negative to rise earlier/set earlier
int Choffset[]={
-600,0,-1800,6000,0,600,-1200,6600,-2200,6600,0,0,0,0,0,0};
// NOW SET YOUR LATIDTUDE AND LONGITUDE COORDINATES as Degrees, Minutes, Seconds of Lat and Lon
//If Your NORTH of the equator your LONGITUDE must START with a NEGATIVE number (the rest are positive) e.g. All of North America, Europe, Russia etc are negative
//If Your EAST of the Prime Meridian your LATITUDE must START with a NEGATIVE number (the rest are positive), e.g. Most of Europe, All of China, India, Austraila, Russia etc are negative
latitude=dmsToSeconds(40,44,00);//United States of America- Salt Lake City, local time is -7 hours GMT
longitude=dmsToSeconds(-111,47,00);
//**********************ok now were done changing things IF YOU CHANGED the Top part of the GLOBAL variable decleration AND this... your FULLY configured and ready to load********************************************
if (dow==0){//if the controller has resarted we need to find midnight
long hours, minutes;//store current elapsed local hours as total seconds from midnight
time_t t=now();//store current clock time to parse
hours=hour(t);
hours=(hours*3600);//current hour number 0-23 as seconds
minutes=minute(t);
minutes=(minutes*60);//minutes of current hour as seconds
newDay=now();
newDay-=(hours+minutes);//Convert current local unix epoch time to local unix epoch time of midnight
else if (dow!=0){//if we did not restart but the day is new then it is midnight and were good to go..
newDay=now();
//#define SECS_YR_2000 (946684800) the time at the start of y2k (need to subtract from unix epoch time to bring to Y2K origin
newDay-=946684800;//convert GMT unix Epoch to seconds elasped since 2000 for GMT midnight of today
rise=newDay;//set value to send to SunRise as midnight GMT in seconds from Y2K
set=newDay;//
//Calculate rise time and set time using Epherma Library functions (see end of code)
SunRise(&rise);//call to Epherma function
SunSet(&set);//Call to Epherma functionunsigned long newDay;
/*Serial.print("rise and set= ");
Serial.println(rise);
Serial.println(set);
Serial.print("newDay as seconds since 2000 to todays midnight= ");
Serial.println(newDay);*/
rise=(rise-newDay);// set to elapsed seconds of day
set=(set-newDay);
/*Serial.print("rise and set as elapsed seconds of day= ");
Serial.println(set);*/
newDay+=946684800;//Convert newDay back to unix epoch GMT midnight today (used in loop to determine how far we are into the day)
/*Serial.print("newDay as seconds since since 1970 to todays midnight= ");
Serial.print("elapsed is");
long elapsed=now()-newDay;
Serial.println(elapsed);*/
//Calculate rise and set times for all channels in equivlants to elapsed seconds from midnight today
//populate array for chRise and Set as well as chSlope for 0.5pi/ half day lenght for each channel from midday (asymmetric days are allowed)
float deltaY=1.570796327;//1/2 * pi as integer by scaling* 10^9 to fill UL
midDay=(((set-rise)/2)+rise);
long HalfDayLength=((set-rise)/2);
for (byte b=0;b<16;b++){//working as of April 5 2012 serial tested
if (b%2==0){
ChRiseSet[b]=rise+(Choffset[b]);
ChSlope[b]=(deltaY/(float)(HalfDayLength-(Choffset[b])));
else if (b%2==1){
ChRiseSet[b]=set+(Choffset[b]);
ChSlope[b]=(deltaY/(float)(HalfDayLength+(Choffset[b])));
//***************** to CHANGE THE chance of Clouds actually occuring on a given day************************
byte CloudChance=100;//% Chance of a Cloud every day
//****************************now were done- did you use a value from 0-100 without a decimal?****************
byte RainMaker=random(1,101);
if (RainMaker<=CloudChance){
CloudToday=true;//used to trigger weather function, can also be used to send flag to controller
else if (RainMaker>CloudChance){
CloudToday=false;//see above comment on CloudToday
return;
long dayLength=0;
for (byte a=1;a<16;a=(a+2)){//determine maximum day length given light on tank that is not moon light, this will yield night clouds and storms (and a storm after dark is severe... always
if (a==0){
if (((set+Choffset[a])-rise)>(set-rise)){
dayLength=((set+Choffset[a])-rise);
else dayLength=(set-rise);
else if (a!=0){
if (dayLength<((set+Choffset[a])-rise)){
// number of clouds possible for the day, max and min
byte CloudsMax=10;//DONT INCREASE BEYOND 10 or it will DIE, or increase array size to handle it (among other things)
byte CloudsMin=4;//use 2 as a minimum
CloudsTotal=random(CloudsMin,(CloudsMax+1));
// Average day is 50,000 secs so if 4 clouds and 10% that gets you 5,000 seconds of clouds (about 1800 seconds length for each of the 4 clouds in independent segments (if 4 is # clouds)
byte OvercastMin=((CloudsTotal*10)/5);//Min cloud length will be about 1000 seconds (15 mins)- 1 hour min of clouds if you have 4, 2 hours if you have 8
byte OvercastMax=((CloudsTotal*10)/2);//max cloud length will be about 2500 seconds (45 mins)- 6 hours max of clouds if you have 8, 3 hours max if you have 4
float Overcast=random(OvercastMin,OvercastMax);
Overcast=(Overcast/100);
// split the total lenght of time for clouds into equal segments and then to randomly chop or add time to the
//segments such that cloud length is variable. Then distribute into random parts of the day and fill array with start,duration pairs for clouds
int CloudLength;
CloudLength=((dayLength*Overcast)/CloudsTotal);//average cloud length
long SunSegment=((dayLength-(dayLength*Overcast))/(CloudsTotal+1));//average sun length between clouds
float CloudFraction=0;
float SunFraction=0;
//start by zero filling CloudMaster array
for (byte a=0; a<20; a++){
CloudMaster[a]=0;
byte b=0;//used to get pairs of fraction for SunFraction in for loop
byte c=0;//used to get pairs of fraction for CloudFraction in for loop
//now randomize cloud length and sunsegment length as pairs to get different looking days-
for (byte a=0; a<(CloudsTotal*2); a++){
if (a%2==0){
if (b==0){
if (a==0){
SunFraction=random(20,181);//vary each pair of SunSegments from 20%-180% of possible length such that every pair =2*SunSegment in length
SunFraction=(SunFraction/100);
CloudMaster[a]=(SunFraction*SunSegment);
else if (a<((CloudsTotal*2)-2)){
b++;
else if (a==((CloudsTotal*2)-2)){
SunFraction=(2-((float)CloudMaster[0]/(float)SunSegment));
else if (b==1){
SunFraction=(2-SunFraction);//were on the second part of a pair
b=0;//reset so next time we start a new fraction
else if (a%2==1){//if were in odd positions we need to determine cloud lengths in random pairs such that each pair =2*CloudLength in length
if (c==0){
CloudFraction=random(20,181);//vary each pair of SunSegments from 20%-180% of possible length such that every pair =2*SunSegment in length
CloudFraction=(CloudFraction/100);
CloudMaster[a]=(CloudFraction*CloudLength);
c++;
else if (c==1){
CloudFraction=(2-CloudFraction);
c=0;//reset so next loop finds a new fraction
/*Serial.println("here is cloud master in is entirety prior to forming start and end pairs");
for (byte a=0;a<20;a++){
Serial.println(CloudMaster[a]);
//reframe array to generate cloud start, cloud end, cloud start, cloud end
if (a==0){// if were starting our first cloud we need to add to rise value to first sun segment
CloudMaster[a]=rise+CloudMaster[a];
else {
CloudMaster[a]=(CloudMaster[a-1]+CloudMaster[a]);//just add prior values together e.g. (second position is cloud end so to find end add rise corrected start time with duration)
// subsequent start would be end of 1st cloud + next sunsegment fraction
/*Serial.println("here is cloud master in is entirety as start and end pairs");
if (a%2==0){
Serial.print("Start time=");
else {
Serial.print("End time=");
}//END SunCalc FUNCTION
void Insolation()
InsolationAdvance=false;//reset this flag now that we have entered function
//define Pi as delta Y for slope since cos 0.5-1.5 Pi goes 0-1-0 in 0.5 pI increments slope of 1/2 day (0-1 intensity) delta Y is 1/2 Pi
float Pi=3.1415926;//scale to 10^8
float PiHalf=1.5707963;//scale to 10^8
float secSoFar;//variable to account for seconds elapsed for each channel 1/2 day period from rise-->midDay and midDay-->set
/* using -cos(pi/2+elapsedTime/slope) calculate fractional intensity of each channel throughout the day
use flicker points to adjust minimum intensity to stable light. Turn off lights after set or before rise etc.
by splitting into half days centered on midday (1/2 ofset-rise) we center exactly the cos function for every channel so color blends are maintained
throughout intensity ramp... more or less ... change intensity every 120 seconds throughout the day*/
if (elapsedTime<=midDay){
byte c=0;//loop counter
for (byte b=0;b<16;b=(b+2)){
if (elapsedTime>=ChRiseSet[b]){
secSoFar=(elapsedTime-ChRiseSet[b]);//just account for length of every channel 1/2 day and switch at midDay
ChannelValue[c]=flicker[c]+ChMax[c]*(-cos(PiHalf+(ChSlope[b]*secSoFar)));
else if (elapsedTime<ChRiseSet[b]){
if (MoonCh[c]==1){
byte MoonToday=MoonPhase()*0.5;//SCALE FACTOR to DIM moon setting for use with HIGH power LED as moon light
if (MoonToday==0) ChannelValue[c]=0;
else if (MoonToday<flicker[c]) ChannelValue[c]=flicker[c];
else ChannelValue[c]=MoonToday;
else if (MoonCh[c]==0){
ChannelValue[c]=0;//its dark and this is not a moon phase channel
c++;//index by one so we count 0-7 as b goes 0-14 by twos
else if (elapsedTime>midDay){
for (byte b=1;b<16;b=b+2){
if (elapsedTime<=ChRiseSet[b]){
secSoFar=(elapsedTime-midDay);
ChannelValue[c]=flicker[c]+ChMax[c]*(-cos(Pi+(ChSlope[b]*secSoFar)));
else if (elapsedTime>ChRiseSet[b]){
if (MoonCh[c]==1){
c++;//index to count 0-7 as b counts 1-15 by twos.
}//END function
//WEATHER FUNCTION BEGIN
void Weather ()
static byte loopCount;
static float CloudCover; // variable to store value in random walk - declared static to accumulate Cloud effect
static float PriorCloudCover; //used to "delay" one side of the tank from the other in cloud passing effects
static long StormStart;
static long StormEnd;
static long CloudEnd;
static boolean wtrigger;//use to track the first run of functions to calculate random times that become fixed, see change from cloud to storm for useage
static byte Counter;//used to trigger storms from cloud you can change its if loop comparison to decrease or increase storm rate see below in cloud==true if loop
static byte Severity;
static byte StormCount;// used to limit X storms per cloud and to choose which cloud can have a storm
static int StepSize;
static int LastStepSize;
//check to see if were having a scheduled cloud
if (Cloud==false){
//Write Insolation values to TrueIntensity so the loop will pick them up and the cloud/storm will get the right data (since intensity changes during the day)
for (byte a=0; a<8; a++){//this must be above the next loop
TrueIntensity[a]=ChannelValue[a];//this is where intensity is set for the PWM channel analog write in the loop... don't mess with this.
for (byte a=0; a<(CloudsTotal*2); a=(a+2)){//if its time for a cloud, run it
if ((elapsedTime>=CloudMaster[a]) && (elapsedTime<=CloudMaster[(a+1)])) {
CloudEnd=CloudMaster[(a+1)];//to avoid this loop running true during the compute cycles at the end of the cloud and before elapsedTime advances a second, actual cloud does not
//Serial.print("We started a cloud and its end is=");
//Serial.println(CloudEnd);
CloudCover=CloudStart(CloudMaster[a]);//CloudStart modifies TrueIntensity to get us to 50% intensity at the start of the cloud effect and also sets cloud=true to bypass this
Counter=0;
StormCount=random(0,3);//the number of storms MAX that may occur in this cloud (remember Random is range= -1 on high end)
loopCount=1;
LastStepSize=0;//zero out cloud random walk variables
StepSize=0;//zero out cloud ranodm walk variables
return;//exit having started a cloud in CLoudStart routine called above
else if ((Cloud==true) && (IsStorm==false)){
if (StormAdvance==false){//use millis tracker to run this loop every 2 seconds
return;
StormAdvance=false;//reset to false when true so we run this once, until time advance is true again
if (elapsedTime>=CloudEnd){
ClearSky(CloudCover, CloudEnd);
return;
/*Use fractional intensity to set minimum value for any channel. Dimming is proportional to actual intensity output
and constrained by flicker point. Random walk uses static variable "CloudCover" constrained to 0-100 to represent fractional intensity (i.e. (1-(CloudCover/100))*Insolation SetPoint
is how the current cloud intensity is set, i.e. cloud cover of 90 gives 10% insolation setpoint unless below flicker in which case = flicker*/
if (loopCount==1){
PriorCloudCover=CloudCover; //e.g. PriorCloudCover=CloudCover with no float math to screw things up
LastStepSize=StepSize;
StepSize=(random(5,21));// in Percent% (0-100) This is how much light intensity will change over the loop count interval (this actual time is dependent upon the call frequency of StromAdvance as set in the loop)
if ((random(0,2)!=1)) StepSize=-(StepSize);
if ((CloudCover+StepSize)>=100){//cannot shut off lights more than 100% so limit here
StepSize=(100-CloudCover);//
Counter++;
else if ((CloudCover+StepSize)<=0){//cannot be brighter than 100% so since were in a cloud dont "limit" it but reflect it back down
if (Counter>=50) Counter-=random(-1,2);//since we got bright... lets further delay and randomize storm occurence
CloudCover=CloudCover+StepSize;
if ((Counter>=60) && ((CloudEnd-elapsedTime)>=300)) {//if Counter (indexes when cloud cover reaches 100) has accumulated and we still have time lets make a storm
//to change the frequency of storms increase or decrease the number comparison for counter in the if statement above (larger #== less storms).
//if you change counter comparison here change it in the next loop as well
if (StormCount>=1){//if we can have storms in this cloud (random- statisticly 1/3 clouds = no storm, 1/3 = 1 possible storm, 1/3 = 2 possible storms)
byte RandomStorm;
RandomStorm=random(0,11);//this randomizes for longer clouds without storm, avg cloud is much longer prior to storm occuring- thus short clouds will not generally have a storm
if (RandomStorm>=4){
StormCount-=1;//count down by 1 the number of storms in this cloud- this will not roll the byte since the loop requires it to be at least 1 to ever subtract here.
Counter=0;//reset this variable since Storm loop uses it as well.
int LongestStorm;//used to pass max possible time to storm if loop from cloud loop within weather function
LongestStorm=(CloudEnd-elapsedTime);
Severity=StartStorm(LongestStorm, IsStorm, StormEnd);
loopCount=1;//reset counting loop for the storm
else if ((Counter>=60) && ((CloudEnd-elapsedTime)<300)){
Counter=0;//just reset the counter (does not really matter in this case but its clean)
for (int a=0;a<8;a++){
if (ChannelValue[a]==0) TrueIntensity[a]=0;// if were in an evening storm dont reset intensity (it would go to flicker point and possibly flicker)
else if (DimOrder[a]==0){
TrueIntensity[a]=(flicker[a]+(((float)(ChannelValue[a]-flicker[a]))*(1-((CloudCover-(StepSize-(StepSize/4)*loopCount))/100))));
else if (DimOrder[a]==1){
TrueIntensity[a]=(flicker[a]+(((float)(ChannelValue[a]-flicker[a]))*(1-((PriorCloudCover-(LastStepSize-(LastStepSize/4)*loopCount))/100))));
loopCount++;
if (loopCount>4) loopCount=1;
//enable a flag sent from controller to triger a storm, i.e. IsStorm=true
// set channel intensities for all but white with random walk continuing from above using static variable so should be seamless
else if (((Cloud==true) && (IsStorm==true)) || ((Cloud==false) && (IsStorm==true))){
//current else statement covers possibility of triggering storm from controller (i.e. not coming out of a cloud) but remember you need to flag wtrigger as TRUE when you do this
if (StormAdvance==false){//Every 1 second duing a storm change intensity, clouds are movin fast baby
return;
StormAdvance=false;//reset so we run again in 1 second.
if (elapsedTime>=StormEnd){ //if were done with the storm we need to stop this loop, but were probably still cloudy so dont mess with that here
IsStorm=false;
Counter=0;
return;
if (loopCount==1){
Counter++;
if (Counter>=2) Counter-=random(0,2);//since we got bright... lets further delay and randomize strike occurence
if (Counter>(Severity+2)) Counter=0;//allow if to accumulate on ocassion to train strike sequences 2-3 in a row but then dump it
if ((Counter>=(Severity+random(-1,4))) && (StrikeNow==false)) {//this is where a storm is triggered. Counter indexes when cloud cover reaches 100 on the random walk
//to change the frequency of lightning strikes increase or decrease the number comparison for counter in the if statement above (larger #== less storms).
byte RandomStriker;
RandomStriker=random(1,11);
if (RandomStriker>4){
StrikeNumber=(random(2,11)); //random high =x-1 so max strike =12 each strike requires a duration and a delay thus StrikeMaster is 18 positions
//ensure the array is zeroed out past the last position required for this strike pattern so each pattern is only as long as generated
//Array is in pairs, position in arry of (0,1) (2,3) etc as strike (delay,duration)
if (a>=(StrikeNumber*2)){
StrikeMaster[a]=0;
if (a%2==0){
if (a==0){
StrikeMaster[a]=random(300,1601);//no need for random here but I am leaving it since I wrote it that way. This must be independent from a=2,4,6 etc...
else {
StrikeMaster[a]=(StrikeMaster[(a-2)]+random(200,1401));//position 0,2,4,6,8.. is strike delay
else if(a%2!=0){
StrikeMaster[a]=random(50,110);//position 1,3,5,7,9... is strike duration (I tried real lightning strike durations and its too short this is adjusted for visual effect
StrikeNow=true; //Trigger to start strike sequence in loop
StrikeStart=millis();//set timer to "zero" now- sequence will start in loop after this function
StrikeCount=0;
Counter=0;
if (Severity>5){
for (int a=0;a<8;a++) {
else if (Wchannel[a]==1){//if were in a storm but not a severe storm constrain whites to 50% of Insolation intensity
TrueIntensity[a]=(flicker[a]+((((float)(ChannelValue[a]-flicker[a])/4))*(1-((CloudCover-(StepSize-(StepSize/3)*loopCount))/100))));
TrueIntensity[a]=(flicker[a]+((((float)(ChannelValue[a]-flicker[a])/4))*(1-((PriorCloudCover-(LastStepSize-(LastStepSize/3)*loopCount))/100))));
else if (Wchannel[a]==0){//if were blue, we chase as for a cloud
TrueIntensity[a]=(flicker[a]+(((float)((ChannelValue[a]-flicker[a])))*(1-((CloudCover-(StepSize-(StepSize/3)*loopCount))/100))));
TrueIntensity[a]=(flicker[a]+((((float)(ChannelValue[a]-flicker[a])))*(1-((PriorCloudCover-(LastStepSize-(LastStepSize/3)*loopCount))/100))));
else if (Severity<=5){// severe storms occur throughout the day, but EVERY storm after sunset is severe...
else if (Wchannel[a]==1){//if were white we need to be off in a storm
TrueIntensity[a]=0;
else if (ChannelValue[a]==0){//if this light channel is dark... e.g. after sunset for this channel- it produces no cloud effect
TrueIntensity[a]=0;
else if (Wchannel[a]==0){//if were not shut off in a strom and not after our daylight period (this channel) then we produce storm light sequences.
if (DimOrder[a]==0){//if we dim first... do it
else if (DimOrder[a]==1){//else we dim second
}//end of CWHchannel==0 being true
}//end of for loop in severity <5 == true loop
}//end severity compairson loop no more else statements
loopCount++;
if (loopCount>3) loopCount=1;
}//end of storm if loop
}//End Weather function
//CloudStart drops light intensity to 50% of whatever daylight setting is to start the cloud at 50
int CloudStart(long StartTime){
byte elapsed;
elapsed=(elapsedTime-StartTime);//counts up since we start this at elapsedTime=StartTime and StartTime is fixed
TrueIntensity[a]=(flicker[a]+(((float)((ChannelValue[a]-flicker[a])))*(1-(elapsed*2.5)/100)));
if (elapsed>=20);
Cloud=true;//start the cloud
return 50;//set CloudCover to 50
}//end CloudStart function
//StartStorm sets up duration and severity of storm. Its currently limited to 90-600 sec in length- it will rarely be lower than 3 minutes
byte StartStorm(int MaxLength, boolean& trigger, long& EndTime){
byte LightningIntensity;
int StormDuration;
MaxLength-=120;//remove 2 mins from longest storm so that we end up with 2 minutes of cloud after the storm before the sky clears to daylight
if (MaxLength>720){
MaxLength=720;//modify local variable
StormDuration=random((MaxLength/3),(MaxLength+1));
EndTime=(elapsedTime+StormDuration);//Set by reference StormEnd static variable in weather
else {
StormDuration=random((MaxLength/2),(MaxLength+1));
if (elapsedTime<midDay){
LightningIntensity=random(3,11);//morning storms are generally less severe
else if (elapsedTime>midDay){//afternoon storms are more likely to be severe (every 10-15 sec or less) to about once in a minute or maybe less
if (elapsedTime>(set-rise)){//Storms after sunset are always severe... it just looks too cool!
LightningIntensity=3;
else {
LightningIntensity=random(3,8);
trigger=true;
return (LightningIntensity);
//End Storm Start Function
//Similar to Cloud start but in reverse... now ramp intensity from wherever we were at the end of the cloud to the value set by Insolation
void ClearSky(int CloudPercent, long TerminationTime)
byte elapsed=(elapsedTime-TerminationTime);//Counts up from the scheduled end of the cloud in seconds
float slope=(CloudPercent/30);//Just calculate how much to increment every second to go from CloudCover to clear sky (CloudCover of zero)
float LightAdvance;
LightAdvance=(CloudPercent-(slope*elapsed));//were reducing CloudCover from start to zero over 10 seconds.
TrueIntensity[a]=(flicker[a]+(((float)(ChannelValue[a]-flicker[a]))*(1-(LightAdvance/100))));
if (elapsed>=30){//at this point lights are back to full Insolation setting so cancel the cloud and start waiting for the next one
Cloud=false;//stop the cloud we are now outside of a true condition in the if loop so it will now stay false and lights are back on
IsStorm=false;//just to be redundant this is not called from a storm...
}//End Clear Sky function
byte MoonPhase()
int m,d,y;
int yy,mm;
long K1,K2,K3,J,V;
byte PWMvalue;
m = month();
d = day();
y = year();
yy = y-((12-m)/10);
mm = m+9;
if (mm>=12) mm -= 12;
K1 = 365.25*(yy+4712);
K2 = 30.6*mm+.5;
K3 = int(int((yy/100)+49)*.75)-38;
J = K1+K2+d+59-K3;
V = (J-2451550.1)/0.29530588853;
V -= int(V/100)*100;
V = abs(V-50);
PWMvalue = 4*abs(50-V); // 5.12=100% 4=~80%
//pinMode(lowATOPin,OUTPUT);
//return (PWMvalue*100)/255; //output is 0-100
return PWMvalue;//output is 0-255
//********************** DO NOT MESS WITH THIS UNLESS YOU KNOW WHAT YOUR DOING****************************
//THE CODE BELOW THIS copied directly from the SWFLTEK Epherma library constructed by Michael Rice.
//this code is being used freely with attribution to Micahel Rice in accord with his request
// A big thank you for these library functions. Its great!
//convert degrees to seconds of arc
// decimal degrees
long ddToSeconds(float dd){
return dd * 3600.0;
//Degrees, minutes, seconds
long dmsToSeconds(int d, unsigned char m, unsigned char s){
long ret;
ret = labs((long)d);
ret = ret * 3600L + 60L * m + s;
ret = (d<0L) ? -ret : ret;
return ret;
'Equation of Time'
We use the 'short form equation, which has a theoretical accuracy of about 40 seconds.
The returned value is in seconds.
int equation_of_time(unsigned long dt){
double t;
dt -= 192540UL; // refer to Jan 3 2000 05:29 (first periapsis)
dt %= _tropical_year;
t = dt;
t /= _tropical_year;
t *= 6.283185307179586;
t = -459.27672 * sin(t) + 575.333472 * sin(2.0 * t + 3.588414);
return t;
'Solar Noon' adjusts the passed time stamp to the time (GMT) of local solar noon.
The accuracy is about 40 seconds (set by the equation of time).
void SolarNoon(unsigned long * dt){
long r;
// Set stamp to noon GMT
*dt /= 86400UL;
*dt *= 86400UL;
*dt += 43200UL;
// adjust for equation of time, at noon GMT
*dt -= equation_of_time(*dt);
// rotate to our longitude
r = longitude / 15L;
*dt -= r;
'Solar Declination'
Returns declination in radians
Accurate to within 50 arc-seconds
double SolarDeclination(unsigned long dt){
double y;
y = dt;
y /= _tropical_year; // fractional year
y *= 6.283185307179586;
y=0.006918-0.399912*cos(y)+0.070257*sin(y)-0.006758*cos(y*2)+0.000907*sin(y*2)-0.002697*cos(y*3)+0.00148*sin(y*3);
return y;
Return the period between sunrise and sunset, in seconds.
At high latitudes around the time of the solstices, this could be zero, or all day.
unsigned long daylightseconds(unsigned long dt){
float l, d, e;
long n;
d = -SolarDeclination(dt); // will be positive in Northern winter
l = latitude / _sec_rad; // latitude in radians
e += 60.0 * l * tan(l + d); // latitudinal error
d = tan(l) * tan(d); //
if(d>1.0) return 86400UL;
if(d < -1.0) return 0UL;
d = acos(d);
d /= _zenith;
n = 86400UL * d;
n += e;
return n;
Modify the passed time stamp to the time of sunrise (or sunset if 'set' is non-zero).
Returns 0 to signal 'normal' completion. If the position is in a polar circle, 1 will be
returned if the sun is above the horizon all day, and -1 if the sun is below the horizon
all day.
char SunRiseSet(unsigned long * dt, char set){
unsigned long daylen;
daylen = daylightseconds(*dt);
if(daylen == 86400UL) return 1; // there is no 'night' today (midnight sun)
if(daylen == 0UL) return -1; // there is no 'day' today
*dt /= 86400UL;
*dt *= 86400UL;
*dt += 43200UL; // set the time stamp to 12:00:00 GMT
*dt -= daylen / 2; // sunrise at the prime meridian
if(set) *dt += daylen; // sunset at the prime meridian
//*dt -= longitude / 15.0; // rotate to our own meridian
return 0;
// 'short' forms of SunRiseSet
char SunRise(unsigned long* when){
return SunRiseSet(when, 0);
char SunSet(unsigned long* when){
return SunRiseSet(when, 1);
So I believe I have figured out how to use the acclimation code with with the dimming expansion module. Since I no longer have a working board I was hoping someone would be willing to look it over and possibly give it a try. Am planning on full-spectrum LED build but still unsure of using 5-6 channels. I will post code tomorrow.
So I used the memory locations that are available through the RA Status app in hopes I can dial in the correct color combination.
#include <WiFiAlert.h>
#include <SunLocation.h>
#define NUMBERS_8x16
// Place global variable code below here
////// Memory Locations used by all formulas
#define Mem_B_AcclDay 100
// Note - 100 represents the hard coded Memory location used for this variable
// not the value for the variable.
// This variable represents the current day in Acclimation Cycle. Set this value to the same
// number of days as your AcclDuration to begin the acclimation cycle or set it to 0 to use
// your normal dimming end% values.
#define Mem_B_AcclDuration 101
// Set this value to how many days you want your acclimation cycle to take.
#define Mem_B_SlopeStart 102
// Set this to your desired starting acclimation end%.
// Place your custom code below here
/////// LED Dimming Acclimation Cycle and your standard LED schedule
////////// Variables used for all channels
byte acclDay = InternalMemory.read(Mem_B_AcclDay);
// What day in the acclimation cycle it is
byte acclDuration = InternalMemory.read(Mem_B_AcclDuration);
// Acclimation Duration in days
byte startPercent = InternalMemory.read(Mem_B_SlopeStart);
// Normal start% being used by all 6 channels
randomSeed(now()/SECS_PER_DAY);
//if (InternalMemory.read(Mem_B_ResetMemory))
//init_memory();
////////// PWM Expansion Channel 0 Variables
byte acclStartEndCh0 = InternalMemory.read(Mem_B_PWMSlopeStart0);
// Starting End% for Acclimation cycle
float acclendPercentCh0 = InternalMemory.read(Mem_B_PWMSlopeEnd0);
// Your target Expansion Channel 0 end% once acclimation is complete
////////// PWM Expansion Channel 0 Formula
float acclPercentPerDayCh0 = (acclendPercentCh0 - acclStartEndCh0) / acclDuration;
// How much your Expansion Channel 0 end% rises per acclimation day
float acclFactorCh0 = acclDay * acclPercentPerDayCh0;
// endPercentCh0 will be offset by this much. If acclDay = 0 then this value will be 0
byte endPercentCh0 = acclendPercentCh0 - acclFactorCh0;
// Your final Expansion Channel 0 end% for the day
////////// PWM Expansion Channel 1 Variables
byte acclStartEndCh1 = InternalMemory.read(Mem_B_PWMSlopeStart1);
float acclendPercentCh1 = InternalMemory.read(Mem_B_PWMSlopeEnd1);
// Your target Blue end% once acclimation is complete
////////// PWM Expansion Channel 1 Formula
float acclPercentPerDayCh1 = (acclendPercentCh1 - acclStartEndCh1) / acclDuration;
// How much your Blue end% rises per acclimation day
float acclFactorCh1 = acclDay * acclPercentPerDayCh1;
// endPercentBlue will be offset by this much. If acclDay = 0 then this value will be 0
byte endPercentCh1 = acclendPercentCh1 - acclFactorCh1;
// Your final Blue end% for the day
////////// PWM Expansion Channel 2 Variables
byte acclStartEndCh2 = InternalMemory.read(Mem_B_PWMSlopeStart2);
float acclendPercentCh2 = InternalMemory.read(Mem_B_PWMSlopeEnd2);
////////// PWM Expansion Channel 2 Formula
float acclPercentPerDayCh2 = (acclendPercentCh2 - acclStartEndCh2) / acclDuration;
float acclFactorCh2 = acclDay * acclPercentPerDayCh2;
byte endPercentCh2 = acclendPercentCh2 - acclFactorCh2;
////////// PWM Expansion Channel 3 Variables
byte acclStartEndCh3 = InternalMemory.read(Mem_B_PWMSlopeStart3);
float acclendPercentCh3 = InternalMemory.read(Mem_B_PWMSlopeEnd3);
////////// PWM Expansion Channel 3 Formula
float acclPercentPerDayCh3 = (acclendPercentCh3 - acclStartEndCh3) / acclDuration;
float acclFactorCh3 = acclDay * acclPercentPerDayCh3;
byte endPercentCh3 = acclendPercentCh3 - acclFactorCh3;
////////// PWM Expansion Channel 4 Variables
byte acclStartEndCh4 = InternalMemory.read(Mem_B_PWMSlopeStart4);
float acclendPercentCh4 = InternalMemory.read(Mem_B_PWMSlopeEnd4);
////////// PWM Expansion Channel 4 Formula
float acclPercentPerDayCh4 = (acclendPercentCh4 - acclStartEndCh4) / acclDuration;
float acclFactorCh4 = acclDay * acclPercentPerDayCh4;
byte endPercentCh4 = acclendPercentCh4 - acclFactorCh4;
////////// PWM Expansion Channel 5 Variables
byte acclStartEndCh5 = InternalMemory.read(Mem_B_PWMSlopeStart5);
float acclEndPercentCh5 = InternalMemory.read(Mem_B_PWMSlopeEnd5);
// Your target White end% once acclimation is complete
////////// PWM Expansion Channel 5 Formula
float acclPercentPerDayCh5= (acclEndPercentCh5 - acclStartEndCh5) / acclDuration;
// How much your White end% rises per acclimation day
float acclFactorCh5 = acclDay * acclPercentPerDayCh5;
// endPercentWhite will be offset by this much. If acclDay = 0 then this value will be 0
byte endPercentCh5 = acclEndPercentCh5 - acclFactorCh5;
// Your standard PWM Dimming code using the variables above to determine start% and end%
ReefAngel.PWM.SetChannel( 0, PWMSlope(13,0,21,0,startPercent,endPercentCh0,90,20) );
ReefAngel.PWM.SetChannel( 1, PWMSlope(12,0,22,0,startPercent,endPercentCh1,90,20) );
ReefAngel.PWM.SetChannel( 2, PWMSlope(12,0,22,0,startPercent,endPercentCh2,90,20) );
ReefAngel.PWM.SetChannel( 3, PWMSlope(12,0,22,0,startPercent,endPercentCh3,90,20) );
ReefAngel.PWM.SetChannel( 4, PWMSlope(12,0,22,0,startPercent,endPercentCh4,90,20) );
ReefAngel.PWM.SetChannel( 5, PWMSlope(12,0,22,0,startPercent,endPercentCh5,90,20) );
// At the end of the day, we need to decrement the acclimation counter.
static boolean acclCounterReady=false; // We need a boolean so we only do this once per day
if (now()%SECS_PER_DAY!=0) acclCounterReady=true; // If it's not midnight we'll get the boolean ready
if (now()%SECS_PER_DAY==0 && acclCounterReady && acclDay>0) { // It's midnight, our bool is true and acclDay is more than 0
acclDay--; // Reduce the counter
acclCounterReady=false; // Reset the boolean flag
InternalMemory.write(Mem_B_AcclDay,acclDay); // Update memory
Just wondering if it has been confirmed that this will work with the dimming expansion?
I just got my servo shield with the pca9685. Once I find free time I will test it.
Sweet, looking forward to your results.
