Control wavemaker at night
Daisyjam
Post by Daisyjam »
Hi All
I need some help with wavemaker code
I currently have:
    if (hour()>=8 && hour()<22){
    ReefAngel.WavemakerRandom( Port6,0,60 );
    ReefAngel.Wavemaker( Port5,120 );
    }else{
    ReefAngel.Relay.Off(Port5);
    ReefAngel.Relay.Off(Port6);
For my night mode both port 5 and 6 are off. What I would like to do is just switch on port 5 for a couple of minutes every hour or so, then port 6 for a couple of minutes the next hour and repeat until the daylight hours kick back in.
Any ideas? I was thinking of using timers but failed to get the code to work.
Re: Control wavemaker at night
I would use the DosingPumpRepeat() function in the else part of your code. Then you can specify how many seconds to run each and the offset.
Daisyjam
Post by Daisyjam »
Thanks for the suggestion.
Next dumb question. Is there any documentation on how to use this function?
www.easte.net/ra/html
Then search for the function it will show you the arguments it takes
Daisyjam
Post by Daisyjam »
That's great, thanks. I will give it a try!
