Emergency Water Level Routine
Smotz
Post by Smotz »
All,
Got some flawed code here I was hoping I can get some insight on.
// EMERGENCY SUMP WATER LEVEL BELOW 20%
    if ( ReefAngel.WaterLevel.GetLevel(1) <= 20 )
    ReefAngel.Relay.Off(Return);
    ReefAngel.Relay.Off(Skimmer);
    ReefAngel.Relay.Off(UVlight);
    ReefAngel.Relay.Off(Feeder);
    ReefAngel.Relay.On(Fugelight);
This code works by design but what happens is the return turns off and the sump fills up making the condition not true anymore - restarting the system. Is there a flag I can set that says "Stay Off" ?
Re: Emergency Water Level Routine
declare a new variable above setup()
boolean LowSump=false;
then, in loop, check for wl<20 and assign true to LowSump and then check is LowSump is true to turn off stuf
if ( ReefAngel.WaterLevel.GetLevel(1) <= 20 ) LowSump=true;
if (LowSump)
You will need to come up with a solution to put LowSump back to false or reboot the controller.
One other way to do it is to mask the ports off, instead of turning them off.
    ReefAngel.Relay.Override(Return,0);
    ReefAngel.Relay.Override(Skimmer,0);
    ReefAngel.Relay.Override(UVlight,0);
    ReefAngel.Relay.Override(Feeder,0);
    ReefAngel.Relay.Override(Fugelight,1);
Smotz
Post by Smotz »
rimai wrote:declare a new variable above setup()
if (LowSump)
Thanks dude. I think I like the override method.
The nice thing about the override instead of off is that the boolean can return to false (or as in robertos example, eliminated) when the pump shuts off but the pumps stay off until you can intervene.
Smotz
Post by Smotz »
Looks like the override is happening when I do a water change and the level gets low. Can someone help me skip this routine in water change mode?
and this as a condition to your if statement
ReefAngel.DisplayedMenu!=WATERCHANGE_MODE
Smotz
Post by Smotz »
Sorry dude. Can you explain like I'm 5? What do you mean add a condition? am I doing && or something like that?
Yep
    if ( ReefAngel.WaterLevel.GetLevel(1) <= 20 && ReefAngel.DisplayedMenu!=WATERCHANGE_MODE)
Smotz
Post by Smotz »
lnevo wrote:Yep
You rock, as always - thanks!
Smotz
Post by Smotz »
lnevo wrote:Yep
A follow up - After this code, I noticed that these port go in to override when the RA reboots. I think I know why - I read on another post that when booting the water level sensor is set to 0 for a split second.
I adjusted the code like this - what do you think?
// EMERGENCY SUMP WATER LEVEL BELOW 20% AND WATERCHANGE MODE IS NOT ON AND WAIT FOR CONTROLLER TO BE ON FOR 1 SECOND
    if ( ReefAngel.WaterLevel.GetLevel(1) <= 20 && ReefAngel.DisplayedMenu!=WATERCHANGE_MODE && millis() > 1000)
    ReefAngel.Relay.Override (Vacation_Topoff,0);
// END EMERGENCY WATER LEVEL ROUTINE
That's fine. You could still get it if the sensor blinks at all though. This way you're running it a little less frequently and so the chances are greatly reduced...
That's what I was going to recommend, but looks like you got it :)
