i adjusted to this. and it seems like its working.
if (hour()>=6 && hour()<10) ReefAngel.PWM.SetDaylight( PWMParabola(6,0,10,0,9,100,9) ); // Moonlight Between 5-10am turn the relay on
if (hour()>=20 && hour()<=23) ReefAngel.PWM.SetDaylight( PWMParabola(20,0,23,0,100,0,100) ); // From 8pm-Midnight turn the relay on
else ReefAngel.PWM.SetDaylight(0);
Coding Moonlights
Re: Coding Moonlights
Hey Lee can you check out my other thread on the myrf question. its regarding duration.
Thanks bud
Thanks bud
Thats not going to work at all...i'm still not sure why you had an issue with the prior function unless there was other code overwriting it. What you posted will go from 9%-100% from 6am to 8am then 100%-9% from 8-10 and similar in the evening. I'll take a look at the other thread but really wasnt sure the question...
I think your in the wrong thread, but that would probably work.
Sorry...
I edited the post above and posted again in the correct one.
Here is my complete code. Its working now. but the percentages are showing up as 255% - 100%. (shutting off at 100%). How can i get the variable to scale between 0 to 100?
#include <DS1307RTC.h>fafa
#include <RF.h>fa
byte myRFMode=0;
byte myRFDuration=0;
byte myRFSpeed=0;
// Ports toggled
ReefAngel.WaterChangePorts = Port3Bit | Port7Bit| Port8Bit| Box1_Port1| Box1_Port4| Box1_Port6; // Turn off Return, UV, Skimmer, Heater, Sump Equipment, ATO
ReefAngel.FeedingModePorts = Port3Bit | Port8Bit; // Turn off Return and Skimmer
ReefAngel.LightsOnPorts = Port2Bit | Port4Bit | Port5Bit| Port6Bit; //Turn on ATI lights, Fan and Fuge Light
ReefAngel.OverheatShutoffPorts = Port4Bit |Port5Bit | Box1_Port1; // ATI Lights and Heaters
ReefAngel.Relay.On( Port3); //RETURN
ReefAngel.Relay.On( Port7 );
ReefAngel.Relay.On( Box1_Port2 ); // Razor Led
ReefAngel.Relay.On( Box1_Port4 ); // Sump Equipment - UV, Pump
ReefAngel.Relay.On( Box1_Port5 ); // MP40s
ReefAngel.Relay.On( Box1_Port6 ); // JBJ
ReefAngel.Relay.On( Box1_Port3);
ReefAngel.Relay.Off( Port1); // Port1 aCROPOWER DOSING... on all the time!!!
ReefAngel.Relay.Set( Port2, !ReefAngel.Relay.Status( Port4 ) ); //Refuge opposite of Actinic
// Port3 ... pORT 3 return always on
ReefAngel.StandardLights( Port4,10,0,20,0 ); //ATI Actinic
ReefAngel.StandardLights( Port5,11,0,19,0 ); //ATI Daylight
ReefAngel.StandardLights( Port6,10,0,21,0 ); //ATI Fanfa
// ReefAngel.Relay.On( Port7 ); UV
ReefAngel.Relay.DelayedOn( Port8,5 ); //Skimmer
//box 2
//ReefAngel.Relay.Off( ); // Lunar Hub Not used
ReefAngel.StandardHeater( Box1_Port1,778,790 ); //Heater Port #9
// Box1_Port2 Razor_LED (Sump)... on all the time!!! Port #10
// ReefAngel.Relay.Off( Box1_Port3); // Start with the relay off Port #11 Moonlight
// if (hour()>=5 && hour()<10) ReefAngel.Relay.On(Box1_Port3); // Moonlight Between 5-10am turn the relay on
// if (hour()>=20 && hour()<=23) ReefAngel.Relay.On(Box1_Port3); // From 8pm-Midnight turn the relay on
// Box1_Port4 Sump Equipment on all the time!!! Port #12
// Box1_Port5 Ecotech MP_40 Pumps on all the time!!! Port #13
// Box1_Port6 JBJ ATO ... on all the time!!! Port #14
ReefAngel.Relay.Off( Box1_Port7); // ALK Doser ... Port #15
ReefAngel.Relay.Off( Box1_Port8); // Calc Doser ... Port #16
///moonlight dimming
// ReefAngel.PWM.SetDaylight( PWMSlope(20,0,23,0,100,0,180,100) );
// ReefAngel.PWM.SetDaylight( PWMSlope(6,0,10,0,9,100,240,9) );
//ReefAngel.Relay.off(Box1_Port3);
// if (hour()>=10 || hour()<20) ReefAngel.PWM.SetDaylight(0);
// ReefAngel.PWM.SetDaylight( MoonPhase()+10 );
// ReefAngel.PWM.SetDaylight(PWMParabola(20,0,23,0,0, MoonPhase(),0 ));
// ReefAngel.PWM.SetDaylight(PWMSlope(6,0,23,0,0,100,240,0));
// if (hour()>=5 && hour()<20) ReefAngel.PWM.SetDaylight(0);
// ReefAngel.PWM.SetDaylight( PWMParabola(20,0,23,0,100,0,100) );
// ReefAngel.PWM.SetDaylight( PWMParabola(6,0,10,0,9,100,9) );
if (hour()>=6 && hour()<11)
myRFSetMode(ReefCrest,85,10);
else if (hour()>=11 && hour()<13)
else if (hour()>=13 && hour()<16)
myRFSetMode(Smart_NTM,85,15);
else if (hour()>=16 && hour()<19)
myRFSetMode(ReefCrest,65,10);
myRFSetMode(Lagoon,40,10);
// Hardcode PH calibrations
//ReefAngel.PHMin=544; // PH7.0
//ReefAngel.PHMax=830; // PH10.0
RunDosingPumps();
LogDosingPumps();
ReefAngel.Portal( "ecam" );
ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params );
strcat(text," ");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,15,93,"Salinity:");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,75,93,text);
ReefAngel.LCD.DrawOutletBox( 12, 94, TempRelay );
// Define Your dosing pumps
#define numDPumps 3
byte pumpRelays[numDPumps]={ Box1_Port7, Box1_Port8,Port1Bit };
int DPVolume[numDPumps]={ 17, 17, 7} ; // 1ml for each alk and calcium - total volume for the day
int DPRepeat[numDPumps]={ 360, 360, 360 } ; // Repeat every 4 hrs 6x a day --- in mins
// Define Calibration here
int CalTime[numDPumps]={ 600, 600, 600 }; // 10 minutes / 10 minutes
int CalVol[numDPumps]={ 350, 300,384 }; // 350ml / 300ml... .58 / .5/.64
// Function: RunDosingPumps()
void RunDosingPumps() {
float rate;
int calcTime[numDPumps];
for (int i=0;i < numDPumps; i++) {
rate=(float)CalVol[i]/CalTime[i];
calcTime[i]=DPVolume[i]/rate/(1440/DPRepeat[i]);
// Run the pumps
ReefAngel.DosingPumpRepeat(pumpRelays[i], i*5, DPRepeat[i], calcTime[i]); // Offset between each pump is 5 minutes
// Display Time calculated in portal
ReefAngel.CustomVar[0]=calcTime[0];
ReefAngel.CustomVar[1]=calcTime[1];
ReefAngel.CustomVar[2]=calcTime[2];
// Function: LogDosingPumps()
void LogDosingPumps() {
static time_t pumpTimer[numDPumps];
static boolean pumpStatus[numDPumps];
float rate;
for (int i=0;i< numDPumps;i++) {
if (ReefAngel.Relay.Status(pumpRelays[i])) {
if (!pumpStatus[i]) {
pumpTimer[i]=now()-pumpTimer[i]; // Pump was off, timer is now a time
pumpStatus[i]=true;
if (pumpStatus[i]) {
pumpTimer[i]=now()-pumpTimer[i]; // Pump was on, timer is now a timer
pumpStatus[i]=false;
// Report How much volume has been dosed per day.
// Could make this in minutes... excercise for the reader..
ReefAngel.CustomVar[3]=pumpTimer[0]*rate;
ReefAngel.CustomVar[4]=pumpTimer[1]*rate;
ReefAngel.CustomVar[5]=pumpTimer[2]*rate;
// Clear timer at end of day
if (now()%SECS_PER_DAY==SECS_PER_DAY-1) pumpTimer[i]=0;
void myRFSetMode(byte m, byte s, byte d)
if (m!=myRFMode || s!=myRFSpeed || d!=myRFDuration || millis()<5000)
myRFMode=m;
myRFSpeed=s;
myRFDuration=d;
ReefAngel.RF.SetMode(m,s,d);
[code]
#include <RF.h>fa
byte myRFMode=0;
byte myRFSpeed=0;
// Ports toggled
//box 2
RunDosingPumps();
LogDosingPumps();
strcat(text," ");
#define numDPumps 3
float rate;
// Run the pumps
float rate;
pumpStatus[i]=true;
myRFMode=m;
myRFSpeed=s;
myRFDuration=d;
