Using wizard i generated this code that is almost ready for my needs except for the Ato.
I would like to use the two floating switches like this:
First as Ato that activate port 3 (and i did it with the wizard)
Second switch to Activate port 4 ti fill my water reservoir
How do i code it?
Here is my actual code
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit;
ReefAngel.LightsOnPorts = Port2Bit;
InternalMemory.OverheatTemp_write( 300 );
ReefAngel.StandardHeater( Port1,245,255 );
ReefAngel.StandardLights( Port2,9,0,19,0 );
ReefAngel.SingleATO( true,Port3,60,0 );
ReefAngel.Relay.DelayedOn( Port8,1 );
