LIghting no dimming.
Ademster
Post by Ademster »
my leds are dimming, I am loading the code to internal memory rather written in the code. I wanted the ability to change it on the fly if needed. I did it this way before on my old tank.
Now it isn't dimming. I did set the std light on and off times to what I wanted. not doing it. What am I doing wrong.
here is the code
    ReefAngel.FeedingModePorts = Port1Bit | Port2Bit;
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.DelayedOn( Port2 );
   ReefAngel.WavemakerRandom1(Port5,10,30); // Turn Port5 on/off random cycles that lasts from 15 to 60 secs
    ReefAngel.MoonLights( Port7 );
    ReefAngel.StandardATO( Box1_Port2 );
    ReefAngel.CO2Control( Box1_Port3 );
    ReefAngel.PHControl( Box1_Port4 );
    ReefAngel.PWM.Channel0PWMSlope();
    ReefAngel.PWM.Channel1PWMSlope();
    ReefAngel.PWM.Channel2PWMSlope();
    ReefAngel.PWM.Channel3PWMSlope();
    ReefAngel.Portal( "ademster" );
    int x,y;
    // Dimming Expansion
    x = 15;
    y = 2;
    for ( int a=0;a<6;a++ )
      if ( a>2 ) x = 75;
      if ( a==3 ) y = 2;
      y += 10;
    ReefAngel.LCD.DrawMonitor( 15, 35, ReefAngel.Params,
    ReefAngel.LCD.DrawMonitor( 15, 35, ReefAngel.Params );
    // Salinity
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,49,68, "SAL:" );
    ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.Salinity,COLOR_DARKKHAKI,73,68, 10 );
    // Water Level
    ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,82, "WL:" );
    ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,82, ReefAngel.WaterLevel.GetLevel() );
    ReefAngel.LCD.DrawOutletBox( 12, 95, TempRelay );
Adam
58 Gal
Ademster
Re: LIghting no dimming.
Post by Ademster »
nevermind, the time on the headunit was wrong. working now.
Adam
58 Gal
