problem controlling jebao from portal
psyrob
Post by psyrob »
I'm having a problem with my braces... :?
What I want to do is between the hours of 8 am and 9 pm be able to change my jebao from the portal and from 9 pm to 8 am only have it run what I have in the code, and not be able to switch it...and during that 8 am to 9 pm, have the "custom" switch from the portal run else mode...I keep getting an error about a brace being expected...
What am I doing wrong? am I missing a brace somewhere? Or what am I doing wrong...
Rob
    ReefAngel.WaterChangePorts = Port5Bit;
    ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port7Bit;
    ReefAngel.CustomLabels[0]="Frag Pump";
    ReefAngel.CustomLabels[1]="Actinics";
    ReefAngel.CustomLabels[2]="Daylights";
    ReefAngel.CustomLabels[3]="Frag LED";
    ReefAngel.CustomLabels[4]="ATO Pump";
    ReefAngel.CustomLabels[5]="Reactor";
    ReefAngel.CustomLabels[6]="Heater";
    ReefAngel.CustomLabels[7]="Fan";
    ReefAngel.ActinicLights( Port2 );
    ReefAngel.DayLights( Port3 );
    ReefAngel.ActinicLights( Port4 );
    ReefAngel.SingleATOLow( Port5 );
    ReefAngel.StandardFan( Port8 );
    //ReefAngel.DCPump.UseMemory = false;
        if (hour()>=8 && hour()<21)
        if (ReefAngel.DCPump.Mode==Custom)
         ReefAngel.PWM.SetActinic(ElseMode(60, 20, true));
        } else{
          ReefAngel.DCPump.UseMemory = true;}
         ReefAngel.PWM.SetActinic(LongPulseMode(65,40, 60, true));
    ReefAngel.Portal( "psyrob" );
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
psyrob
Re: problem controlling jebao from portal
Post by psyrob »
anyone? :?:
There was one brace that was misplaced :(
    else{
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
psyrob
Post by psyrob »
Thank you Roberto...that was driving me crazy ... :?
psyrob
Post by psyrob »
Now this uploads, but I can't control it from the portal...
When I first upload it, the jebao sets to "0", it isn't running. Then I pick "custom" from the drop down menu in internal memory on the portal, and it runs in else mode, but then if I change to anything else (long pulse, lagoon, or whatever), nothing happens, it stays in else mode. It did switch to sine mode at the right time, though...
Any thoughts?
Rob
         ReefAngel.PWM.SetActinic(SineMode(60,35, 20, true));
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
Do you have speed and duration set to valid values?
psyrob
Post by psyrob »
You mean when I switch modes on the portal? I think so...I tried reef rest, which I thought didn't use duration, I set speed at 65, I tried long pulse, set speed at 65, duration at 8...
