#define Return 1
#define Pwm_Exp 2
#define Unused 3
#define ATI 4
#define Jebao1_Rhs 5
#define Jebao2_Rhs 6
#define Jebao1_Lhs 7
#define Jebao2_Lhs 8
#define ATO Box1_Port1
#define Fuge_Led Box1_Port2
#define Heater1 Box1_Port3
#define Skimmer Box1_Port4
#define Heater2 Box1_Port5
#define Unused Box1_Port6
#define Swabby Box1_Port7
#define Unused Box1_Port8
ReefAngel.OverheatShutoffPortsE[0] = Port3Bit | Port5Bit;
ReefAngel.Relay.On( Pwm_Exp );
ReefAngel.Relay.On( Return );
ReefAngel.Relay.On( ATI );
ReefAngel.Relay.On( Fuge_Led );
ReefAngel.Relay.On( Heater1 );
ReefAngel.Relay.On( Heater2 );
ReefAngel.Relay.On( Skimmer );
ReefAngel.WaterLevelATO( ATO,180,70,90 );
if (ReefAngel.LowATO.IsActive() && ReefAngel.HighATO.IsActive())
ReefAngel.Relay.On(Skimmer);
ReefAngel.Relay.Off(Skimmer);
ReefAngel.DosingPumpRepeat( Swabby,0,360,120 );
if (hour()>=6 && hour()<12)
ReefAngel.PWM.SetDaylight( ReefCrestMode(70,20,true) ); // ReefCrest at 60% +/- 20% on sync mode
ReefAngel.PWM.SetActinic( ReefCrestMode(70,20,true) ); // ReefCrest at 60% +/- 20% on anti-sync mode
ReefAngel.Relay.Off( Jebao1_Lhs );
ReefAngel.Relay.Off( Jebao2_Lhs );
ReefAngel.Relay.On( Jebao1_Rhs );
ReefAngel.Relay.On( Jebao2_Rhs );
else if (hour()>=12 && hour()<18)
ReefAngel.PWM.SetChannel( 0, ReefCrestMode(70,20,true) ); // ReefCrest at 60% +/- 20% on sync mode
ReefAngel.PWM.SetChannel( 1, ReefCrestMode(70,20,true) ); // ReefCrest at 60% +/- 20% on anti-sync mode
ReefAngel.Relay.Off( Jebao1_Rhs );
ReefAngel.Relay.Off( Jebao2_Rhs );
ReefAngel.Relay.On( Jebao1_Lhs );
ReefAngel.Relay.On( Jebao2_Lhs );
else if (hour()>=18 && hour()<24)
ReefAngel.PWM.SetChannel( 0, ReefCrestMode(50,20,true) ); // ReefCrest at 60% +/- 20% on sync mode
ReefAngel.PWM.SetChannel( 1, ReefCrestMode(50,20,true) ); // ReefCrest at 60% +/- 20% on anti-sync mode
ReefAngel.PWM.SetDaylight( ReefCrestMode(50,20,true) ); // ReefCrest at 60% +/- 20% on sync mode
ReefAngel.PWM.SetActinic( ReefCrestMode(50,20,true) ); // ReefCrest at 60% +/- 20% on anti-sync mode
ReefAngel.Portal( "sabo" );
