I've been running around looking for a code that will work for my setup by sadly nothing has worked. In the near future I will have 4 different light channels in my hood and I need... or want... to turn them on and off at certain times according to where they are located on the power strip.
For now however I only have a single power connection running to the tank and therefore can only control 1 of the 4 channels (I ran out off spare extension cables).
At the moment I have a Par38 bulb plugged directly to port8 on the power strip. My problem is, how do I turn this port off every night at 8 and back on at 7? Here is what I have now (new code is at the bottom)
ReefAngel.LightsOnPorts = Port8Bit;
ReefAngel.OverheatShutoffPorts = Port5Bit | Port7Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 815 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port5,790,795 );
if ( ( (hour()==7) && (minute()==30) ))
ReefAngel.Relay.On(Port8);
if ( ( (hour()==20) && (minute()==0) ))
ReefAngel.Relay.off(Port8);
on\off by time
Re: on\off by time
Hey look at that ... Found a good example Will test it out here in a bit
ReefAngel.StandardLights( Port7,11,0,6,0 );
ReefAngel.StandardLights( Port8,7,30,20,0 );
Re: on\off by time
I suppose I was making it too complicated
This alone fixed it
ReefAngel.StandardLights( Port8,7,0,20,0 );
This alone fixed it
