Emergency shutoff when water rises
I’m looking for a bit of code that will turn my return pump off (port1) if…… float switch (connected to ATO high) triggers. Then, if for whatever reason port1 shuts off also turn off port3
Earlier today I was working on the tank and turned off the return pump, without realizing it the water dropped enough to cause the circulation pumps (port3 and their sole purpose is to stir up the surface so I don’t get so much stagnant water) to spit water all inside the hood shorting out one of the lights. Needless to say I’ve adjusted it so it will not happen again but still, if my return pump cuts off I need to cut those ports as well. If the float switch activates then I’m about a half inch from disaster
Any ideas?
Any ideas?
Re: Emergency shutoff when water rises
if (ReefAngel.ATOHigh.IsActive()) ReefAngel.Relay.Override(Port1,0);
if (!ReefAngel.Relay.Status(Port1)) ReefAngel.Relay.Override(Port3,0);
And that'd look like this correct?
ReefAngel.LightsOnPorts = Port2Bit | Port4Bit | Port6Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 815 );
ReefAngel.Relay.On( Port3 );
ReefAngel.StandardLights( Port2,8,0,20,30 );
ReefAngel.StandardLights( Port4,7,30,20,0 );
ReefAngel.StandardHeater( Port5,790,795 );
ReefAngel.StandardLights( Port6,7,0,2,0 );
ReefAngel.StandardLights( Port7,11,0,6,0 );
ReefAngel.StandardLights( Port8,2,0,21,0 );
hmmm doesn't like that??
"Class reefangelclass" has no member named "atohigh"
Do I need to remove this?
And changing it to highato got me passed the checks
lol that worked in reverse
second test and it's working as expected, Excellent! Thanks buddy
Not sure why it cut off the first time
