Add ELSE mode for WP40
symon_say
Post by symon_say »
Hi
I have a WP40 pump and i want set it in ELSE mode, I make a code with the wizard for the things i need, but i'll to use ELSE mode instead of the ones provided in the wizard i found a code in the Addons section that will work for what i want, but i don't how to add it to the code and how to set the intervals i want, this is my code:
#include <Globals.h>
#include <RA_Wifi.h>
#include <[color=#CC6600]Wire[/color].h>
#include <[color=#CC6600]OneWire[/color].h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <[color=#006699]LED[/color].h>
#include <RA_TempSensor.h>
#include <[color=#006699]Relay[/color].h>
#include <RA_PWM.h>
#include <[color=#006699]Timer[/color].h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <[color=#006699]Salinity[/color].h>
#include <[color=#006699]RF[/color].h>
#include <[color=#006699]IO[/color].h>
#include <[color=#006699]ORP[/color].h>
#include <[color=#006699]AI[/color].h>
#include <[color=#006699]PH[/color].h>
#include <[color=#006699]WaterLevel[/color].h>
#include <[color=#006699]Humidity[/color].h>
#include <[color=#006699]DCPump[/color].h>
#include <[color=#CC6600]ReefAngel[/color].h>
[color=#7E7E7E]////// Place global variable code below here[/color]
[color=#7E7E7E]////// Place global variable code above here[/color]
[color=#CC6600]void[/color] [color=#CC6600][b]setup[/b][/color]()
    [color=#7E7E7E]// This must be the first line[/color]
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]Init[/color]();  [color=#7E7E7E]//Initialize controller[/color]
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]SetTemperatureUnit[/color]( [color=#006699]Celsius[/color] );  [color=#7E7E7E]// set to Celsius Temperature[/color]
    [color=#7E7E7E]// Ports toggled in Feeding Mode[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]FeedingModePorts[/color] = [color=#006699]Port8Bit[/color];
    [color=#7E7E7E]// Ports toggled in Water Change Mode[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]WaterChangePorts[/color] = [color=#006699]Port1Bit[/color] | [color=#006699]Port7Bit[/color] | [color=#006699]Port8Bit[/color];
    [color=#7E7E7E]// Ports toggled when Lights On / Off menu entry selected[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]LightsOnPorts[/color] = 0;
    [color=#7E7E7E]// Ports turned off when Overheat temperature exceeded[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]OverheatShutoffPorts[/color] = [color=#006699]Port8Bit[/color];
    [color=#7E7E7E]// Use T1 probe as temperature and overheat functions[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]TempProbe[/color] = [color=#006699]T1_PROBE[/color];
    [color=#CC6600]ReefAngel[/color].[color=#006699]OverheatProbe[/color] = [color=#006699]T1_PROBE[/color];
    [color=#7E7E7E]// Set the Overheat temperature setting[/color]
    [color=#CC6600]InternalMemory[/color].[color=#CC6600]OverheatTemp_write[/color]( 300 );
    [color=#7E7E7E]// Feeeding and Water Change mode speed[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]DCPump[/color].[color=#006699]FeedingSpeed[/color]=0;
    [color=#CC6600]ReefAngel[/color].[color=#006699]DCPump[/color].[color=#006699]WaterChangeSpeed[/color]=0;
    [color=#7E7E7E]// Ports that are always on[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]On[/color]( [color=#006699]Port7[/color] );
    [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]On[/color]( [color=#006699]Port8[/color] );
    [color=#7E7E7E]////// Place additional initialization code below here[/color]
    [color=#7E7E7E]////// Place additional initialization code above here[/color]
[color=#CC6600]void[/color] [color=#CC6600][b]loop[/b][/color]()
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]StandardATO[/color]( [color=#006699]Port1[/color],600 );
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]StandardLights[/color]( [color=#006699]Port2[/color],15,0,22,30 );
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]StandardLights[/color]( [color=#006699]Port3[/color],15,30,22,0 );
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]MHLights[/color]( [color=#006699]Port4[/color],16,0,21,30,1 );
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]StandardLights[/color]( [color=#006699]Port5[/color],10,29,23,0 );
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]StandardLights[/color]( [color=#006699]Port6[/color],23,0,11,0 );
    [color=#CC6600]ReefAngel[/color].[color=#006699]DCPump[/color].[color=#006699]UseMemory[/color] = [color=#CC6600]false[/color];
    [color=#CC6600]ReefAngel[/color].[color=#006699]DCPump[/color].[color=#CC6600]SetMode[/color]( TidalSwell,80,10 );
    [color=#CC6600]ReefAngel[/color].[color=#006699]DCPump[/color].[color=#006699]DaylightChannel[/color] = [color=#006699]Sync[/color];
    [color=#CC6600]ReefAngel[/color].[color=#006699]DCPump[/color].[color=#006699]ActinicChannel[/color] = [color=#006699]None[/color];
    [color=#7E7E7E]////// Place your custom code below here[/color]
    [color=#7E7E7E]////// Place your custom code above here[/color]
    [color=#7E7E7E]// This should always be the last line[/color]
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]Portal[/color]( [color=#006699]"symon_say"[/color] );
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]ShowInterface[/color]();
This is the code i find in the addons, made by Cosmith71:
  static unsigned long LastChange=millis();        // Set the inital time that the last change occurred
  static int Delay = random( 500, 3000);           // Set the initial delay
  static int NewSpeed = MidPoint;                  // Set the initial speed
  static int AntiSpeed = MidPoint;                 // Set the initial anti sync speed
  if ((millis()-LastChange) > Delay)               // Check if the delay has elapsed
    Delay=random(500,5000);                        // If so, come up with a new delay
    int ChangeUp = random(Offset);                 // Amount to go up or down
    if (random(100)<50)                            // 50/50 chance of speed going up or going down
    LastChange=millis();                           // Reset the time of the last change
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
Could some one add that to my code so i can just uploaded to the RA, thanks a lot.
Re: Add ELSE mode for WP40
Elsemode isnt in the libraries yet. That wont work quite like that...
However the OP added the code perfectly in his post...you just add the function to the end of your INO file the same as you did in the post :)
Then get rid of the setmode line altogether. Replace it with this
ReefAngel.PWM.SetDaylight( ElseMode(80,10,true) );
symon_say
Post by symon_say »
lnevo wrote:Elsemode isnt in the libraries yet. That wont work quite like that...
Thanks, that's what I want to know, cause I could find a relation between setmode and the one you post, that I seen in most post.
