-Turn wavemaker on nutrient transport mode after feeding is over for 4 hours.
-Turn DC pump off for 2 hours after entering feeding mode.
-I also want my protein skimmer to remain off for 4 hours after pressing the feeding button.
could anyone point me in the right direction with a example of that?
Im mostly confused on where do i place the custom code in my current code. Also could someone explain to me how do i get my code to show up in a scroll box in a post? I cant seem to figure it out. I press the CODE button and insert my code.
Thanks for all the help.
ReefAngel.FeedingModePortsE[0] = Port1Bit | Port2Bit | Port4Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port4Bit;
ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port3Bit | Port4Bit | Port5Bit;
InternalMemory.OverheatTemp_write( 829 );
ReefAngel.DCPump.WaterChangeSpeed=100;
ReefAngel.StandardLights( Port1,14,30,20,00 ); ////// White t5
ReefAngel.StandardLights( Port2,13,00,22,00 ); ////// blue t5
ReefAngel.StandardLights( Port3,12,00,23,00 ); ////// reefblok blue
ReefAngel.StandardLights( Port4,14,00,21,00 ); ////// reefblok white
ReefAngel.StandardLights( Port5,14,30,21,00 ); ////// custom led
ReefAngel.StandardLights( Port6,14,0,23,0 ); ////// uv
ReefAngel.StandardLights( Port7,22,0,13,0 ); ////// night light
ReefAngel.StandardHeater( Port8,800,820 );
ReefAngel.StandardLights ( Box1_Port4, 12,0,22,00 ); ////// protein skimmer
ReefAngel.SingleATO( true,Box1_Port6,66,0 );
ReefAngel.PWM.SetChannel( 0, PWMSlope(13,30,22,0,5,40,60,5) ); ////// whites
ReefAngel.PWM.SetChannel( 1, PWMSlope(12,0,23,0,5,100,60,20) ); ////// blue reefblok
ReefAngel.PWM.SetChannel( 2, PWMSlope(14,0,22,0,5,100,60,5) ); ////// blue
ReefAngel.PWM.SetChannel( 3, MoonPhase() );
ReefAngel.PWM.SetDaylight (62); ////// Dc pump
ReefAngel.DCPump.SetMode( NutrientTransport,90,100 ); ////// wavemaker
ReefAngel.Portal( "Dctrojan" );
