Some issues with my code.
PostPosted: Fri Jun 27, 2014 9:40 am
I'll keep an eye out for something.
PostPosted: Fri Jun 27, 2014 9:47 am
Ahh I know what the issue is!! rmode is our random number in the array... not the actual mode.
Try this:
if (modes[rmode]==Else) {
PostPosted: Fri Jun 27, 2014 10:08 am
OK. I'll try it tonight or tomorrow.
I can't seem to log into my laptop remotely right now to make the change.
lnevo wrote:Change this line
  if (rmode==Else) {
to
PostPosted: Fri Jun 27, 2014 11:07 am
You're the man.
That seemed to do it.
It shows a Pump Mode of constant, but the speed is not I't changing (as it should be).
Thanks Lee.
PostPosted: Fri Jun 27, 2014 11:24 am
Speed should be changing as every iteration of loop we are setting the speed to ElseMode(InternalMemory.DCPumpSpeed_read(),20,true)
There are a few issues though, one is that we would not get any sync/anti-sync functionality there. I think we should revert to using the PWM commands here. Let's try this:
  if (rmode==Else) {
    ReefAngel.DCPump.Mode=Constant;
    ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),20,true );    // ElseMode on sync mode, Portal Speed Setting +/- 20%
  } else {
  if (rmode==Else) {
    ReefAngel.PWM.SetDaylight(ElseMode(InternalMemory.DCPumpSpeed_read(),20,true) );    // ElseMode on sync mode, Portal Speed Setting +/- 20%
    ReefAngel.PWM.SetActinic(ElseMode(InternalMemory.DCPumpSpeed_read(),20,false) );    // ElseMode on anti-sync mode, Portal Speed Setting +/- 20%
  } else {
PostPosted: Fri Jun 27, 2014 11:29 am
I'll do it tonight.
Thanks.
PostPosted: Fri Jun 27, 2014 12:46 pm
Thanks Lee.
I'm going to put this issue to the side for now until I iron out some hardware issues that Roberto and I have been trying to figure out,
I don't want to introduce anything new into the mix right now.
Previous
Return to How do I code ...
