Some issues with my code.
Re: Some issues with my code.
Ahh I know what the issue is!! rmode is our random number in the array... not the actual mode.
Try this:
Try this:
if (modes[rmode]==Else) {
OK. I'll try it tonight or tomorrow.
I can't seem to log into my laptop remotely right now to make the change.
lnevo wrote:Change this line
toCode: Select all
if (rmode==Else) {
You're the man.
That seemed to do it.
It shows a Pump Mode of constant, but the speed is not I't changing (as it should be).
Thanks Lee.
Thanks Lee.
Speed should be changing as every iteration of loop we are setting the speed to ElseMode(InternalMemory.DCPumpSpeed_read(),20,true)but the speed is not I't changing (as it should be).
There are a few issues though, one is that we would not get any sync/anti-sync functionality there. I think we should revert to using the PWM commands here. Let's try this:
if (rmode==Else) {
ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),20,true ); // ElseMode on sync mode, Portal Speed Setting +/- 20%
if (rmode==Else) {
ReefAngel.PWM.SetDaylight(ElseMode(InternalMemory.DCPumpSpeed_read(),20,true) ); // ElseMode on sync mode, Portal Speed Setting +/- 20%
ReefAngel.PWM.SetActinic(ElseMode(InternalMemory.DCPumpSpeed_read(),20,false) ); // ElseMode on anti-sync mode, Portal Speed Setting +/- 20%
Thanks Lee.
I'm going to put this issue to the side for now until I iron out some hardware issues that Roberto and I have been trying to figure out,
I don't want to introduce anything new into the mix right now.
