PH help!!! Emergency
PostPosted: Sun Jun 29, 2014 3:31 pm
Just recently setup a Cal Rx. Im trying to use the probe to control Box1_Port8 to toggle regulator and its not working. Ph is down to 6.29 and the regulator is still on!!!!!! Please help
I can manully toggle it, off and on with my phone.
        byte myRFMode=0;
        byte myRFDuration=0;
        byte myRFSpeed=0;
        // Ports toggled
      ReefAngel.WaterChangePorts = Port1 |Port3 | Port7| Port8| Box1_Port1| Box1_Port3| Box1_Port4| Box1_Port5; // Turn off Return, UV, Skimmer, Heater, Sump Equipment, ATO
      ReefAngel.FeedingModePorts = Port3 | Port8; // Turn off Return and Skimmer
      ReefAngel.LightsOnPorts = Port2|Box1_Port6; //Turn on ATI lights, Fan and Fuge Light
      ReefAngel.OverheatShutoffPorts = Port1 |Port3 | Port7| Port8| Box1_Port1| Box1_Port3| Box1_Port4| Box1_Port5; // ATI Lights and Heaters
                InternalMemory.OverheatTemp_write( 825 );   // Set the Overheat temperature setting
           //Box1
           ReefAngel.StandardHeater(Port1,778,790 );                        // Port1 Heater
           ReefAngel.StandardLights( Port2,23,0,9,0 );                      // Fuge Light
           ReefAngel.Relay.On(Port3);                                       //  Port3 Return Pump -- Always on
           ReefAngel.Relay.Off(Port4);                                      //  Port4 RODI
           ReefAngel.Relay.Off(Port5);                                      //  Port5 Saltwater Change
          ReefAngel.SingleATO( true,Port6,300,0 );                            //Port 6 Auto top off
         // ReefAngel.Relay.Set(Port6, ReefAngel.HighATO.IsActive());          //Turns port 6 off when High ATO is on
           ReefAngel.Relay.On (Port7);                             //  Port7 Frag Tank -- Always on
           ReefAngel.Relay.On( Port8);                            //  Port8 Skimmer -- 5 min delay start
          //box 2 (Box1_Portxx)
          ReefAngel.StandardHeater( Box1_Port1,778,790 );                         //  9 Box1_Port1 Heater
          ReefAngel.Relay.Off(Box1_Port2);                                        //  10 Box1_Port2 Acropower Dosing ...
          ReefAngel.Relay.Off( Box1_Port3);                                      //  11 Box1_Port3 UV - Only turn on UV Sterilizer between 11pm and 4am
                  if ( (hour() >= 4) && (hour() < 23) )
                      ReefAngel.Relay.Off(Box1_Port3);
                      else ReefAngel.Relay.On(Box1_Port3);
          ReefAngel.Relay.On( Box1_Port4);                                      //  12 Box1_Port4 Sump Equipment-- Always on
          ReefAngel.Relay.Off(Box1_Port5);                                       //  13 Box1_Port5 JBJ Auto top off
          ReefAngel.Relay.On(Box1_Port6);                                         //  14 Box1_Port6 Cabinet Light
          ReefAngel.Relay.On( Box1_Port7);                                       // 15 Box1_Port7 Recirc CalRX
          ReefAngel.PHControl( Box1_Port8,650,640);                                  // 16 Box1_Port8 Regulator
//          ReefAngel.Relay.On( Box1_Port8);                                       // 16 Box1_Port8 Regulator
//    ReefAngel.PHControl( Port1,703,822 );
                          // Old Code
                              //moonlight dimming
                                     //    if (hour()>=6 && hour()<10) ReefAngel.PWM.SetDaylight( PWMParabola(6,0,10,0,9,100,9) ); // Moonlight Between 5-10am turn the relay on
                                     //    if (hour()>=20 && hour()<=23) ReefAngel.PWM.SetDaylight( PWMParabola(20,0,23,0,100,0,100) ); // From 8pm-Midnight turn the relay on
                                     //    else ReefAngel.PWM.SetDaylight(0);
                                     //  ReefAngel.Relay.Set( Port2, !ReefAngel.Relay.Status( Port4 ) ); //Refuge opposite of Actinic
                                     //  ReefAngel.Relay.Off( Box1_Port3); // Start with the relay off       Port #11 Moonlight
                                        //if (hour()>=5 && hour()<10) ReefAngel.Relay.On(Box1_Port3); // Moonlight Between 5-10am turn the relay on
                                        //if (hour()>=20 && hour()<=23) ReefAngel.Relay.On(Box1_Port3); // From 8pm-Midnight turn the relay
                                     //    ReefAngel.PWM.SetDaylight( PWMSlope(20,0,23,0,100,0,180,100) );
                                     //   ReefAngel.PWM.SetDaylight( PWMSlope(6,0,10,0,9,100,240,9) );
                                     //ReefAngel.Relay.off(Box1_Port3);
                                     //  if (hour()>=10 || hour()<20) ReefAngel.PWM.SetDaylight(0);
                                     //    ReefAngel.PWM.SetDaylight( MoonPhase()+10 );
                                    // ReefAngel.PWM.SetDaylight(PWMParabola(20,0,23,0,0, MoonPhase(),0 ));
                                    //ReefAngel.PWM.SetDaylight(PWMSlope(6,0,23,0,0,100,240,0));
                                    //if (hour()>=5 && hour()<20) ReefAngel.PWM.SetDaylight(0);
                                    //ReefAngel.PWM.SetDaylight( PWMParabola(20,0,23,0,100,0,100) );
                                    //ReefAngel.PWM.SetDaylight( PWMParabola(6,0,10,0,9,100,9) );
          if (hour()>=6 && hour()<11)
            myRFSetMode(ReefCrest,85,10);
          else if (hour()>=11 && hour()<13)
          else if (hour()>=13 && hour()<16)
            myRFSetMode(Smart_NTM,85,50);
          else if (hour()>=16 && hour()<19)
            myRFSetMode(ReefCrest,65,10);
            myRFSetMode(Lagoon,40,10);
        // Hardcode PH calibrations
         //ReefAngel.PHMin=544; // PH7.0
         //ReefAngel.PHMax=830; // PH10.0
      //   RunDosingPumps();
       //  LogDosingPumps();
        ReefAngel.Portal( "ecam" );
        ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params,
        ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params );
              strcat(text,"  ");
              ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,15,93,"Salinity:");
              ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,75,93,text);
        ReefAngel.LCD.DrawOutletBox( 12, 94, TempRelay );
    // Define Your dosing pumps
    //#define numDPumps 3
// byte pumpRelays[numDPumps]={ Box1_Port2};
  //  int DPVolume[numDPumps]={ 0, 25,28} ; // 1ml for each alk and calcium - total volume for the day
    //int DPRepeat[numDPumps]={ 360, 240, 240 } ; // Repeat every 4 hrs 6x a day --- in mins
    // Define Calibration here
   // int CalTime[numDPumps]={ 600, 600, 600 }; // 10 minutes / 10 minutes
    //int CalVol[numDPumps]={ 350, 300,384 }; // 350ml / 300ml... .58 / .5/.64
    // Function: RunDosingPumps()
    //void RunDosingPumps() {
      //float rate;
      //int calcTime[numDPumps];
//      for (int i=0;i < numDPumps; i++) {
    //    rate=(float)CalVol[i]/CalTime[i];
  //      calcTime[i]=DPVolume[i]/rate/(1440/DPRepeat[i]);
        // Run the pumps
      //  ReefAngel.DosingPumpRepeat(pumpRelays[i], i*5, DPRepeat[i], calcTime[i]); // Offset between each pump is 5 minutes
      // Display Time calculated in portal
     // ReefAngel.CustomVar[0]=calcTime[0];
     // ReefAngel.CustomVar[1]=calcTime[1];
      ///ReefAngel.CustomVar[2]=calcTime[2];
    // Function: LogDosingPumps()
    //void LogDosingPumps() {
      //static time_t pumpTimer[numDPumps];
      //static boolean pumpStatus[numDPumps];
      //float rate;
      //for (int i=0;i< numDPumps;i++) {
       // if (ReefAngel.Relay.Status(pumpRelays[i])) {
        //  if (!pumpStatus[i]) {
          //  pumpTimer[i]=now()-pumpTimer[i]; // Pump was off, timer is now a time
            //pumpStatus[i]=true;
//        } else {
  //        if (pumpStatus[i]) {
    //        pumpTimer[i]=now()-pumpTimer[i]; // Pump was on, timer is now a timer
      //      pumpStatus[i]=false;
            // Report How much volume has been dosed per day.
            // Could make this in minutes... excercise for the reader..
          //  ReefAngel.CustomVar[3]=pumpTimer[0]*rate;
            //ReefAngel.CustomVar[4]=pumpTimer[1]*rate;
            //ReefAngel.CustomVar[5]=pumpTimer[2]*rate;
        // Clear timer at end of day
//        if (now()%SECS_PER_DAY==SECS_PER_DAY-1) pumpTimer[i]=0;
        void myRFSetMode(byte m, byte s, byte d)
          if (m!=myRFMode || s!=myRFSpeed || d!=myRFDuration || millis()<5000)
            myRFMode=m;
            myRFSpeed=s;
            myRFDuration=d;
            ReefAngel.RF.SetMode(m,s,d);
PostPosted: Sun Jun 29, 2014 4:02 pm
The syntax is lowph then highph. I think you have it backwards. Try switching it.
          ReefAngel.PHControl( Box1_Port8,640,650);                                  // 16 Box1_Port8 Regulator
PostPosted: Sun Jun 29, 2014 5:11 pm
Thanks Lnevo. CO2 command worked like a charm
Return to How do I code ...
