New to reef angel
New to reef angel
im sure this kind of thread been done a million times im new to a controller i was told this forum was very friendly and helped ya with anything you need so i was just wondering is there anything i should know about this controller im not good at coding and i beleave the previous owner had his own code in it and wanted to change it out
Re: New to reef angel
You got it used, I take it? Did you get cables, etc with it?
Do you know if it's a Reef Angel or a Reef Angel Plus?
The download section is a good place to start. You'll need the instruction manuals and the installers. Once you have the installer you can use the Wizard to get started with the programming.
