Get ATO port Value
PostPosted: Tue Jul 08, 2014 12:37 am
First I'm very happy with RA+, it has a great job with my 100g tank for a year.
I just change WP40 from PWM port to ATO port. (added a dimming-able LED), every thing works fine(high low port working in PWM), but need some programming support.
previous i can check WP40 working level with ReefAngel.PWM.GetDaylightValue() function. but i can't find one for ATO port (High Low).
is there any similar function can check ATO port working condition? thanks :D
PostPosted: Tue Jul 08, 2014 3:56 am
I don't think there is a good way to do it in the libraries as using the ATO ports for output isn't really built in.
What I would do is store the output of your wave maker commands in a variable so you can reference. can you post the code?
PostPosted: Tue Jul 08, 2014 4:32 am
Could you use analogRead(lowATOPin) ?
Or no, because it's set to output?
PostPosted: Wed Jul 09, 2014 5:35 am
cosmith71 wrote:Could you use analogRead(lowATOPin) ?
it seems doesn't work. the value flash from 45X~57X. in 8pm.
here is my code
// Define Relay Ports by Name
#define Return             8
#define Skimmer            3
#define LED1               5
#define Wavepump2          4
#define Wavepump1          6
#define SumpLED            2
#define CoolingPump        1
#define LED2               7
byte wpMode;
    ReefAngel.SetTemperatureUnit( Celsius );  // set to Celsius Temperature
    ReefAngel.FeedingModePorts = Port8Bit | Port4Bit | Port6Bit;
    //ReefAngel.OverheatShutoffPorts = Port4Bit;  should be redefine to new ports
    InternalMemory.OverheatTemp_write( 285 );
    ReefAngel.Relay.On(Return);
    ReefAngel.Relay.On(Wavepump1);
    ReefAngel.Relay.On(Wavepump2);
    ReefAngel.Relay.On(LED1);
    ReefAngel.Relay.On(SumpLED);
    ReefAngel.Relay.On(LED2);
    ReefAngel.Relay.On(CoolingPump);
    //ReefAngel.StandardATO(ATOPump,60 );
    //ReefAngel.StandardHeater(Heater,235,255 );
    ReefAngel.Relay.DelayedOn(Skimmer,3 );
    ReefAngel.StandardLights(SumpLED,19,0,8,0 );
    ReefAngel.StandardLights(LED1,8,29,23,31 );
    ReefAngel.StandardLights(LED2,8,29,23,31 );
   //ReefAngel.StandardLights(SumpAirPump,6,0,18,0 ); //Try out stage, SumpAirPump always on
   static boolean powerOutage=false;
  // Power Outage - turn off everything
  if (!ReefAngel.Relay.IsRelayPresent(MAIN_RELAY)) // Main Relay NOT present
    powerOutage=true;
    ReefAngel.Relay.Off(Return);
    ReefAngel.Relay.Off(Skimmer);
    ReefAngel.Relay.Off(LED1);
    //ReefAngel.Relay.Off(Heater);
    ReefAngel.Relay.Off(Wavepump1);
    ReefAngel.Relay.Off(Wavepump2);
    ReefAngel.Relay.Off(SumpLED);
    ReefAngel.Relay.Off(LED2);
  // Power Restored - Turn things back on
  if (powerOutage && ReefAngel.Relay.IsRelayPresent(MAIN_RELAY))
    LastStart=now();
    powerOutage=false;
    ReefAngel.Relay.On(Skimmer);
     // Turn off Skimmer if Return pump has been shutoff.
  if (!ReefAngel.Relay.Status(Return)) {
  }else {
    ReefAngel.Relay.DelayedOn(Skimmer);
static time_t feeding;
// LED light setup
  ReefAngel.PWM.SetDaylight(PWMSlope(8,30,23,30, 10,60,150,0));
  ReefAngel.PWM.SetActinic(PWMSlope(8,30,23,30, 10,75,180,0));
// Time schedule first
  if (hour()>=8 && hour()<11) {
    pinMode(highATOPin,OUTPUT); //high ATO port
    analogWrite(highATOPin,TidalSwellMode(65,true)*2.55); // TidalSwell at 45% on sync mode
    pinMode(lowATOPin,OUTPUT); //high ATO port
    analogWrite(lowATOPin,TidalSwellMode(65,false)*2.55);  // TidalSwell at 45% on anti-sync mode
    wpMode=1;
    else if (hour()>=15 && hour()<19) {
    analogWrite(highATOPin,(millis()%800>400?70:0)*2.55); // W1 Mode
    analogWrite(lowATOPin,30*2.55); // TidalSwell at 30% on anti-sync mode
    wpMode=6;
    else if ( (hour()>=11 && hour()<15) ) {
    analogWrite(highATOPin,NutrientTransportMode(40,60,600,true )*2.55); // Nutrient Transport on sync mode
    analogWrite(lowATOPin,NutrientTransportMode(40,60,600,false)*2.55); // Nutrient Transport on anti-sync mode
    wpMode=3;
    else if (hour()>=19 && hour()<21) {
    wpMode=3;
    else if (hour()>=21 && hour()<23) {
    analogWrite(highATOPin,TidalSwellMode(60,true)*2.55); // TidalSwell at 60% on sync mode
    analogWrite(lowATOPin,TidalSwellMode(60,false)*2.55);  // TidalSwell at 60% on anti-sync mode
    wpMode=1;
    else {
    analogWrite(highATOPin,SineMode(20,30,40,true)*2.55); //SineMode from 30% to 40% for 20 seconds on sync mode
    analogWrite(lowATOPin,SineMode(20,30,40,false)*2.55); //SineMode from 30% to 40% for 20 seconds on anti-sync mode
    wpMode=4;
// If we are feeding override the schedule
if (ReefAngel.DisplayedMenu==FEEDING_MODE) {
  analogWrite(highATOPin,20*2.55);
  wpMode=0;
  feeding=now();
// If we have finished feeding, start NTM for 3 hours
if (now()-feeding < 3*SECS_PER_HOUR) {
    analogWrite(highATOPin,NutrientTransportMode(35,45,600,true )*2.55); // Nutrient Transport on sync mode
    analogWrite(lowATOPin,NutrientTransportMode(35,45,600,false)*2.55); // Nutrient Transport on anti-sync mode
    wpMode=3;
    ReefAngel.Portal( "sesame" );
  // Change the 30 to adjust the horizontal position of the text on the screen, max 20-21 chars
  ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 90, 2, "Sesame");
  ReefAngel.LCD.DrawMonitor(15, 68, ReefAngel.Params,
                            ReefAngel.PWM.GetDaylightValue(),
                            ReefAngel.PWM.GetActinicValue());
  ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 110, 78, analogRead(highATOPin));
  ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 110, 88, analogRead(lowATOPin));
  // WP40 Mode
  int x, y;
  ReefAngel.LCD.DrawText(0,255,x,y,"RF:");
  ReefAngel.LCD.Clear(DefaultBGColor,x,y,128-x,y+8);
  if (wpMode == 0) ReefAngel.LCD.DrawText(COLOR_BLUE,255,x+4,y+2,"Feeding");
  else if (wpMode == 1) ReefAngel.LCD.DrawText(COLOR_BLUE,255,x+4,y+2,"Tidal Swell");
  else if (wpMode == 2) ReefAngel.LCD.DrawText(COLOR_BLUE,255,x+4,y+2,"Reef Crest");
  else if (wpMode == 3) ReefAngel.LCD.DrawText(COLOR_BLUE,255,x+4,y+2,"Nutrient");
  else if (wpMode == 4) ReefAngel.LCD.DrawText(COLOR_BLUE,255,x+4,y+2,"Sine Wave");
  else if (wpMode == 5) ReefAngel.LCD.DrawText(COLOR_BLUE,255,x+4,y+2,"Long Pluse");
  else if (wpMode == 6) ReefAngel.LCD.DrawText(COLOR_BLUE,255,x+4,y+2,"W1 Mode");
  ReefAngel.LCD.DrawOutletBox(12, 101, TempRelay);
  ReefAngel.LCD.DrawGraph(5, 11);
PostPosted: Wed Jul 09, 2014 6:25 am
Yeah, the more I think about it, I realize that would never work.
The best thing to do is like Lee suggested and just put whatever value you're setting it to in a variable. Looking back, that's what I did when I was using an ATO port for a Jaebo pump.
PostPosted: Wed Jul 09, 2014 6:42 am
Its what the libraries are doing for the daylight/actinic port anyway, they dont read the port to get it, just returns the value you set.
PostPosted: Thu Jul 10, 2014 11:55 pm
lnevo wrote:Its what the libraries are doing for the daylight/actinic port anyway, they dont read the port to get it, just returns the value you set.
understand. highly suggest to put these libraries in next gen of RA+. :D :D
PostPosted: Fri Jul 11, 2014 4:25 am
Open an issue :)
Return to How do I code ...
