it seems doesn't work. the value flash from 45X~57X. in 8pm.
// Define Relay Ports by Name
#define Return 8
#define Skimmer 3
#define LED1 5
#define Wavepump2 4
#define Wavepump1 6
#define SumpLED 2
#define CoolingPump 1
#define LED2 7
byte wpMode;
ReefAngel.FeedingModePorts = Port8Bit | Port4Bit | Port6Bit;
//ReefAngel.OverheatShutoffPorts = Port4Bit; should be redefine to new ports
InternalMemory.OverheatTemp_write( 285 );
ReefAngel.Relay.On(Return);
ReefAngel.Relay.On(Wavepump1);
ReefAngel.Relay.On(Wavepump2);
ReefAngel.Relay.On(LED1);
ReefAngel.Relay.On(SumpLED);
ReefAngel.Relay.On(LED2);
ReefAngel.Relay.On(CoolingPump);
//ReefAngel.StandardATO(ATOPump,60 );
//ReefAngel.StandardHeater(Heater,235,255 );
ReefAngel.Relay.DelayedOn(Skimmer,3 );
ReefAngel.StandardLights(SumpLED,19,0,8,0 );
ReefAngel.StandardLights(LED1,8,29,23,31 );
ReefAngel.StandardLights(LED2,8,29,23,31 );
//ReefAngel.StandardLights(SumpAirPump,6,0,18,0 ); //Try out stage, SumpAirPump always on
static boolean powerOutage=false;
// Power Outage - turn off everything
if (!ReefAngel.Relay.IsRelayPresent(MAIN_RELAY)) // Main Relay NOT present
powerOutage=true;
ReefAngel.Relay.Off(Return);
ReefAngel.Relay.Off(Skimmer);
ReefAngel.Relay.Off(LED1);
//ReefAngel.Relay.Off(Heater);
ReefAngel.Relay.Off(Wavepump1);
ReefAngel.Relay.Off(Wavepump2);
ReefAngel.Relay.Off(SumpLED);
ReefAngel.Relay.Off(LED2);
// Power Restored - Turn things back on
if (powerOutage && ReefAngel.Relay.IsRelayPresent(MAIN_RELAY))
LastStart=now();
powerOutage=false;
ReefAngel.Relay.On(Skimmer);
// Turn off Skimmer if Return pump has been shutoff.
if (!ReefAngel.Relay.Status(Return)) {
}else {
ReefAngel.Relay.DelayedOn(Skimmer);
static time_t feeding;
// LED light setup
ReefAngel.PWM.SetDaylight(PWMSlope(8,30,23,30, 10,60,150,0));
ReefAngel.PWM.SetActinic(PWMSlope(8,30,23,30, 10,75,180,0));
// Time schedule first
if (hour()>=8 && hour()<11) {
pinMode(highATOPin,OUTPUT); //high ATO port
analogWrite(highATOPin,TidalSwellMode(65,true)*2.55); // TidalSwell at 45% on sync mode
pinMode(lowATOPin,OUTPUT); //high ATO port
analogWrite(lowATOPin,TidalSwellMode(65,false)*2.55); // TidalSwell at 45% on anti-sync mode
wpMode=1;
else if (hour()>=15 && hour()<19) {
analogWrite(highATOPin,(millis()%800>400?70:0)*2.55); // W1 Mode
analogWrite(lowATOPin,30*2.55); // TidalSwell at 30% on anti-sync mode
wpMode=6;
else if ( (hour()>=11 && hour()<15) ) {
analogWrite(highATOPin,NutrientTransportMode(40,60,600,true )*2.55); // Nutrient Transport on sync mode
analogWrite(lowATOPin,NutrientTransportMode(40,60,600,false)*2.55); // Nutrient Transport on anti-sync mode
wpMode=3;
else if (hour()>=19 && hour()<21) {
wpMode=3;
else if (hour()>=21 && hour()<23) {
analogWrite(highATOPin,TidalSwellMode(60,true)*2.55); // TidalSwell at 60% on sync mode
analogWrite(lowATOPin,TidalSwellMode(60,false)*2.55); // TidalSwell at 60% on anti-sync mode
wpMode=1;
else {
analogWrite(highATOPin,SineMode(20,30,40,true)*2.55); //SineMode from 30% to 40% for 20 seconds on sync mode
analogWrite(lowATOPin,SineMode(20,30,40,false)*2.55); //SineMode from 30% to 40% for 20 seconds on anti-sync mode
wpMode=4;
// If we are feeding override the schedule
if (ReefAngel.DisplayedMenu==FEEDING_MODE) {
analogWrite(highATOPin,20*2.55);
wpMode=0;
feeding=now();
// If we have finished feeding, start NTM for 3 hours
if (now()-feeding < 3*SECS_PER_HOUR) {
analogWrite(highATOPin,NutrientTransportMode(35,45,600,true )*2.55); // Nutrient Transport on sync mode
analogWrite(lowATOPin,NutrientTransportMode(35,45,600,false)*2.55); // Nutrient Transport on anti-sync mode
wpMode=3;
ReefAngel.Portal( "sesame" );
// Change the 30 to adjust the horizontal position of the text on the screen, max 20-21 chars
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 90, 2, "Sesame");
ReefAngel.LCD.DrawDate(6, 118);
ReefAngel.LCD.DrawMonitor(15, 68, ReefAngel.Params,
ReefAngel.PWM.GetDaylightValue(),
ReefAngel.PWM.GetActinicValue());
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 110, 78, analogRead(highATOPin));
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 110, 88, analogRead(lowATOPin));
// WP40 Mode
int x, y;
ReefAngel.LCD.DrawText(0,255,x,y,"RF:");
ReefAngel.LCD.Clear(DefaultBGColor,x,y,128-x,y+8);
if (wpMode == 0) ReefAngel.LCD.DrawText(COLOR_BLUE,255,x+4,y+2,"Feeding");
else if (wpMode == 1) ReefAngel.LCD.DrawText(COLOR_BLUE,255,x+4,y+2,"Tidal Swell");
else if (wpMode == 2) ReefAngel.LCD.DrawText(COLOR_BLUE,255,x+4,y+2,"Reef Crest");
else if (wpMode == 3) ReefAngel.LCD.DrawText(COLOR_BLUE,255,x+4,y+2,"Nutrient");
else if (wpMode == 4) ReefAngel.LCD.DrawText(COLOR_BLUE,255,x+4,y+2,"Sine Wave");
else if (wpMode == 5) ReefAngel.LCD.DrawText(COLOR_BLUE,255,x+4,y+2,"Long Pluse");
else if (wpMode == 6) ReefAngel.LCD.DrawText(COLOR_BLUE,255,x+4,y+2,"W1 Mode");
ReefAngel.LCD.DrawOutletBox(12, 101, TempRelay);
ReefAngel.LCD.DrawGraph(5, 11);
