It's beyond what I know how to do.mrwlf wrote:5 seconds was just for example
Inviato dal mio GT-I9505 utilizzando Tapatalk
Because every time i put my hands in the sump it keep triggering on and off The ATO...rimai wrote:What I'm not understanding is the reason why every 30 minutes?
Why not just let the ATO do its job on demand with a max run time of x seconds?
lnevo wrote:Here's exactly what you want. Only diff is the example the timeout is 300 seconds and i set the runtime to 305 seconds to make sure the timeout could get triggered in case the reservoir went dry or pump issue. So i would just make sure the runtime parameter is equal to or higher then the ato timeout arg.
http://forum.reefangel.com/viewtopic.ph ... 14b#p39364
