PWM Slope Code
PostPosted: Sun Jul 27, 2014 7:11 am
OK so to answer my question.. So this should all take effect today and my lights will turn off at 11:00PM tonight?
cosmith71 wrote:I think this:
ReefAngel.PWM.SetDaylight( PWMSlope(14,0,22,30,15,60,60,0) );
ReefAngel.PWM.SetActinic( PWMSlope(13,30,23,0,15,80,60,0) );
will override memory settings.
PostPosted: Sun Jul 27, 2014 7:13 am
I should think so.
PostPosted: Sun Jul 27, 2014 7:16 am
Ok hopefully this does it. If they don't turn off ill just manually override them to off and see if they take effect in 24 hours.
cosmith71 wrote:I should think so.
PostPosted: Sun Jul 27, 2014 8:11 am
I've never heard of that before.
PostPosted: Sun Jul 27, 2014 8:50 am
Ok I uploaded
Should the percentage values reflect under internal memory within portal? In portal it's showing
Daylights Start 15% End 60% (14,0,22,30,15,60,60,0) );
Actinics Start 15% End 75% (13,30,23,0,15,80,60,0) ); end should be 80%
Do I need to manually change the percent in portal or will it change once it goes through the loop?
PostPosted: Sun Jul 27, 2014 8:57 am
They are separate. The portal values are irrelevant when you've specified times, etc in the code. They won't update, nor will it make any difference what you change them to since you've hard coded the values.
PostPosted: Sun Jul 27, 2014 9:00 am
Ah ok thanks
cosmith71 wrote:They are separate. The portal values are irrelevant when you've specified times, etc in the code. They won't update, nor will it make any difference what you change them to since you've hard coded the values.
Previous
Return to How do I code ...
Users browsing this forum: No registered users and 5 guests
