This version is for standard dimming ports (modified if you're using LDD +5 drivers).
The version for the Dimming Expansion Module is HERE.
RANet Dimming Expansion is HERE.
UPDATE: 8/15/2014
New mode: Calm
No lightning at all. Just plain old cloud. Good for putting in a random sequence.
UPDATE: 8/8/2014
Better lightning engine. Flash brightness is randomized between current brightness level and max. Flash fades to current brightness level instead of off.
Slight chance of longer strikes (up to 400 ms vs 70 ms earlier)
New mode added. Mega2. Like Mega, but with lots more lightning. See below for selection instructions.
UPDATE: 8/5/2014
Three built-in lightning modes.
Slow: Slower flash in the middle of the cloud for ELN series drivers.
Fast: Fast lightning in the midddle of the cloud for LDD and similar drivers.
Mega: Fast lightning randomly throughout the cloud, increasing in frequency as the cloud gets darker.
(Mega2 added 8/8/2014)
(Calm added 8/15/2014)
How to choose:
Find this line in the checkcloud() routine:
byte LightningModes[] = { Slow, Fast, Mega };
For example,
byte LightningModes[] = { Slow, Fast, Mega };Code: Select all
byte LightningModes[] = { Mega };Code: Select all
byte LightningModes[] = { Fast, Mega, Mega };[/i]
UPDATE: 8/4/2014
Minimal lightning added for non-rapid response drivers (MeanWell ELN Series, etc).
Adjustments made to timing so it doesn't set off the watchdog timer and doesn't monopolize resources.
Pseudo-random number generator seeding added.
Next cloud time, lightning time, and cloud duration put in custom variables 3-7 for portal reporting. Remove if desired.
Mega Storm!
This is a modified version of Roberto's cloud and lightning code.
The lightning routine is written for fast response LED drivers such as the Mean Well LDD series and the upcoming RANet LED drivers. There is a minimal lightning mode available for slow response drivers such as the Mean Well ELN series.
It uses the standard RA dimming ports.
Up top in the globals section add these lines:
byte ActinicPWMValue=0; // For cloud code
byte DaylightPWMValue=0; // For cloud codeCode: Select all
// Lighting Control
ActinicPWMValue=PWMSlope(10,00,22,30,0,80,60,ActinicPWMValue);
DaylightPWMValue=PWMSlope(10,30,22,00,0,90,60,DaylightPWMValue);
CheckCloud();
ReefAngel.PWM.SetDaylight(DaylightPWMValue);Code: Select all
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 10
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(12,00)
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen results could happen.
// Add Random Lightning modes
#define Calm 0 // No lightning
#define Slow 1 // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2 // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3 // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4 // Like Mega, but with more lightning
// Example: { Slow, Fast, Mega, Mega2 } to randomize all four modes.
// { Mega2 } for just Mega2. { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
byte LightningModes[] = { Mega, Mega, Mega2, Calm, Calm };
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
static byte lightningMode=0;
static time_t DelayCounter=millis(); // Variable for lightning timing.
static int DelayTime=random(1000); // Variable for lightning timimg.
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
randomSeed(millis()); // Seed the random number generator
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
if (chooseLightning)
chooseLightning=false;
switch (lightningMode)
case Calm:
break;
case Mega:
// Lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
int a=random(1,5); // Pick a number of consecutive flashes from 1 to 4.
for (int i=0; i<a; i++)
analogWrite(daylightPWMPin,random(DaylightPWMValue*2.55,255)); // Flash on
int randy=random(20,80); // Random number for a delay
if (randy>71) randy=((randy-70)/2)*100; // Small chance of a longer delay
delay(randy); // Wait from 20 to 69 ms, or 100-400 ms
analogWrite(daylightPWMPin,DaylightPWMValue*2.55); // Flash off
delay(random(30,50)); // Wait from 30 to 49 ms
wdt_reset();
DelayCounter=millis(); // If we just had a round of flashes, then lets put in a longer delay
DelayTime=random(1000); // of up to a second for dramatic effect before we do another round.
break;
case Mega2:
// Higher lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
if (lightningchance && random(ReversePWMSlope(cloudstart,cloudstart+cloudduration,100,0,180))<2 && (millis()-DelayCounter)>DelayTime)
wdt_reset();
break;
case Fast:
wdt_reset();
break;
case Slow:
// Slow lightning for 5 seconds in the middle of the cloud. Suitable for slower ELN style drivers
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
DaylightPWMValue=0;
delay(1);
break;
default:
break;
cloudindex++;
if (cloudindex < numclouds)
int x=0;
else x=17;
else x=35;
ReefAngel.CustomVar[7]=(cloudduration); // Put the duration of the next cloud in a custom var for the portal
if (lightningchance)
int x=0;
else x=57;
ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60; // Write the hour of the next lightning to a custom variable for the Portal
else x=75;
ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60)); // Write the minute of the next lightning to a custom variable for the Portal
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
[youtube]http://www.youtube.com/watch?v=EAgJ_qOJBxc[/youtube]
Mega Storm! Entire 7 minute cloud sequence.
[youtube]http://www.youtube.com/watch?v=m8yQcdocF5E[/youtube]
