Cloud and Lightning Code
Re: Cloud and Lightning Code
Also added option for Mega Storm to OP, with lightning throughout the cloud increasing in intensity as the cloud gets darker. Pretty awesome, if I do say so myself!
Colin, any chance you can integrate the "mini" storm (non-fast/responsive drivers) so i have one cloud function to work on? I'm going to add high resolution dimming and potentially turn this into a class for ease of use/configuration.
Oh wow....just got home from work....added ur update last night but haven't checked the relay state yet for the skimmer.....but the mega storm option sounds wicked.....
Sent from my SAMSUNG-SGH-I717 using Tapatalk
We should add an array of storm types you want and randomize between them. sometimes mega, sometimes mini, could even simulate a storm coming in. Where is Jon, time to start talking about the audio out he has again...
OK, added the slow response lightning to the OP. It's selectable via a variable switch in the checkcloud() routine.
I doubt I would want to run anything but Mega-Storm. It's awesome.
I haven't had any issues with overrides with the new code. Even with the Mega-Storm, everything runs smooth with no resets.89delta wrote:Oh wow....just got home from work....added ur update last night but haven't checked the relay state yet for the skimmer.....but the mega storm option sounds wicked.....
God I can't wait to get my LEE's up and running.
No issues with the relays resetting Colin...Thanks.....but am gonna update the new code tonight. Lnevo....great idea about the storm mode being randomized.
Colin,
You left the default as Mega
I added the random selection, you'll just need to set this array to the types of lightning you want:
Once you set that, each cloud should have a unique lightning type. If you just want Slow, or Fast you can put one. If you want one more than the others, you can put it multiple times in the array Need to think a little more how we could combine multiple types of lightning during one cloud episode. I need to actually run the code though too to see how it looks overall
byte LightningModes[] = { Slow, Fast, Mega };
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 10
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(12,00)
// Add Random Lightning modes
#define Slow 0
#define Fast 1
#define Mega 2
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
static byte lightningMode=0;
static time_t DelayCounter=millis(); // Variable for lightning timing.
static int DelayTime=random(1000); // Variable for lightning timimg.
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
randomSeed(millis()); // Seed the random number generator
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
// Check for lightning. When lightning occurs, it will happen for 5 seconds at the middle of a cloud.
// We will have from 1 to 4 consecutive flashes, then a random delay of up to 1000 ms before another set of flashes.
// This first line basically says: Is there supposed to be lightning? Are we within a 5 second window in the middle
// of the cloud when lightning occurs? Are we not in a delay between sets of flashes? If so, do another round of flashes.
if (chooseLightning) { lightningMode=LightningModes[random(100)%sizeof(LightningModes)]; chooseLightning=false; }
switch (lightningMode) {
case Mega:
int a=random(1,5); // Pick a number of consecutive flashes from 1 to 4.
for (int i=0; i<a; i++)
analogWrite(daylightPWMPin, 255); // Flash on
delay(20+random(50)); // Wait from 20 to 69 ms
analogWrite(daylightPWMPin, 0); // Flash off
delay(30+random(20)); // Wait from 30 to 49 ms
DelayCounter=millis(); // If we just had a round of flashes, then lets put in a longer delay
DelayTime=random(1000); // of up to a second for dramatic effect before we do another round.
break;
case Fast:
break;
case Slow:
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
DaylightPWMValue=0;
delay(1);
break;
default:
break;
cloudindex++;
if (cloudindex < numclouds)
int x=0;
ReefAngel.CustomVar[7]=(cloudduration); // Put the duration of the next cloud in a custom var for the portal
if (lightningchance)
int x=0;
ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60; // Write the hour of the next lightning to a custom variable for the Portal
ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60)); // Write the minute of the next lightning to a custom variable for the Portal
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
Once you see them in action you'll know why I like Mega so much. I would never use Slow if I had fast hardware. Fast is OK, but only happens in a 5 second window in the middle of the cloud.
I need to shoot some more videos.
Edit: Actually, the default is Fast in the OP. Mega is added by changing the code as described near the bottom of the post. I've moved the video and edited the description to be more clear.
Colin the instructions you provide to add mega is already implemented in your example...you say its not so i'm even more confused now....
Ooops, fixed.lnevo wrote:Colin the instructions you provide to add mega is already implemented in your example...you say its not so i'm even more confused now....
When you get a chance if you could test my addition and incorporate into the main post. This would ensure we all work on the same source as we add features There will be some big breakage coming so I'd like to keep this as merged as possible
Tested, seems to work fine. I'll update the OP this afternoon. Waiting for new video to processs.
Can we use a memory location to set the mode?
Yup. Give me a couple of days.89delta wrote:Can we use a memory location to set the mode?
Ok So I figured it out how to use the internal memory locations I think. Just not the actual location so am not sure just yet if it will mess with another setting.
But in Globals add:
#define Mem_B_StormMode 112
Then in checkcloud() find
static byte lightningMode=0; and replace with
static byte lightningMode=InternalMemory.read(Mem_B_StormMode);
Will be testing this right now.
But in Globals add:
You can put the #define in your INO directly. Don't modify the Globals.h
The only issue with setting it there is the Random mode will override it...
Sorry....I meant on the top of the sketch Lee and not within the Globals.h or .cpp file. If it'll override it I guess i'm going to have to look into another define statement to either setup random or a static mode then correct.
Yeah, this line is what sets the mode based on what's in the array...
We'll have to do some logic here to set it to what's in InternalMemory... and how do you revert back to the random selections? We could do something like the PWM overrides, where if it's 255 we go back to our regularly scheduled program and if it's not then we hard code to that mode...
Don't do this:89delta wrote:Ok So I figured it out how to use the internal memory locations I think. Just not the actual location so am not sure just yet if it will mess with another setting.
But in Globals add:
Instead, take this line out:static byte lightningMode=0; and replace with
lightningMode=InteralMemory.read(Mem_B_StormMode);
That does it but then we no longer have random cycling
I thought that's what he wanted.lnevo wrote:That does it but then we no longer have random cycling
Cool....you guys rock. Figured i'd take a shot at it Colin that way you're not overloaded...
Oh don't get me wrong guys. Love the random part of it. But enjoying re-learning the code structure on how it all works and trying different things out. Besides the random part wouldn't work with slower drivers unless we can "over-ride" it by being able to select just the "Slow" Mode for the ELN's or other drivers. As the Fast and Mega modes work fine with the LDD's and the CAT4101's i've got laying around.cosmith71 wrote:I thought that's what he wanted.lnevo wrote:That does it but then we no longer have random cycling
No problem!
Lee, how is it done with the DC pumps? Isn't there a way to cycle through them with memory control? I'm not up on them...
Yes, but we should strive to maintain a single code base I'm trying to avoid multiple versions.
With the DCPumps we have a variable UseMemory that we set when we want to use Memory or Override.
We can keep the line in there, but I recommend if Memory is 255 then go with the Array. If it's set than go with the mode that's set.
89, thats the nice thing about the array though, if you have slow drivers, just put Slow Random is useless (for now) with the slow drivers, until someone comes up with a second "slow" method
True Lee....But I was kinda of thinking along your wanting to turn this into another class and just being able to have the end user select which one to use. Nevermind....am having a brain fart. I get what you're saying now. After you get this into another class we just add the coding for it into our INO:lnevo wrote:Yes, but we should strive to maintain a single code base I'm trying to avoid multiple versions.
byte LightningModes[] = { Slow }; or
Yeah when we get to that point we can do something like we do for dcpump. I like how all this is proceeding. Ideas are great, keep em coming!
