Page 1 of 4
Cloud and Lightning Code
Posted: Mon Jul 28, 2014 10:34 am
by cosmith71
UPDATE: 6/21/2015
This version is for standard dimming ports (modified if you're using LDD +5 drivers).
The version for the Dimming Expansion Module is HERE.
RANet Dimming Expansion is HERE.
UPDATE: 8/15/2014
New mode: Calm
No lightning at all. Just plain old cloud. Good for putting in a random sequence.
UPDATE: 8/8/2014
Better lightning engine. Flash brightness is randomized between current brightness level and max. Flash fades to current brightness level instead of off.
Slight chance of longer strikes (up to 400 ms vs 70 ms earlier)
New mode added. Mega2. Like Mega, but with lots more lightning. See below for selection instructions.
UPDATE: 8/5/2014
Three built-in lightning modes.
Slow: Slower flash in the middle of the cloud for ELN series drivers.
Fast: Fast lightning in the midddle of the cloud for LDD and similar drivers.
Mega: Fast lightning randomly throughout the cloud, increasing in frequency as the cloud gets darker.
(Mega2 added 8/8/2014)
(Calm added 8/15/2014)
How to choose:
Find this line in the checkcloud() routine:
byte LightningModes[] = { Slow, Fast, Mega };
Change the terms inside the {} to select which mode(s) you want.
For example,
Will randomly choose from one of the three modes.
byte LightningModes[] = { Mega };
Will only use Mega.
byte LightningModes[] = { Fast, Mega, Mega };
Will randomly choose between Fast and Mega, but be twice as likely to choose Mega.
[/i]
UPDATE: 8/4/2014
Minimal lightning added for non-rapid response drivers (MeanWell ELN Series, etc).
Adjustments made to timing so it doesn't set off the watchdog timer and doesn't monopolize resources.
Pseudo-random number generator seeding added.
Next cloud time, lightning time, and cloud duration put in custom variables 3-7 for portal reporting. Remove if desired.
Mega Storm!
This is a modified version of Roberto's cloud and lightning code.
The lightning routine is written for fast response LED drivers such as the Mean Well LDD series and the upcoming RANet LED drivers. There is a minimal lightning mode available for slow response drivers such as the Mean Well ELN series.
It uses the standard RA dimming ports.
Up top in the globals section add these lines:
byte ActinicPWMValue=0;    // For cloud code
byte DaylightPWMValue=0;   // For cloud code
In loop(), add these. Be sure to remove any other lighting control code. In this example, the actinic channel comes on at 10:00 AM and turns off at 10:30 PM with a 60 minute dimming period, a minimum brightness of 0, and a maximum brightness of 80. Daylight is from 10:30 AM to 10:00 PM with a max of 90%. Change as you see fit.
// Lighting Control
    ActinicPWMValue=PWMSlope(10,00,22,30,0,80,60,ActinicPWMValue);
    DaylightPWMValue=PWMSlope(10,30,22,00,0,90,60,DaylightPWMValue);
    CheckCloud();
At the very end, outside of loop() and past everything else add this. Scroll through the first part of the code and edit to set start and end times, chance of clouds and lightning, frequency, etc.
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 10
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
  // In this example, start cloud after noon
#define Start_Cloud_After NumMins(12,00)
#define End_Cloud_Before NumMins(21,00)
  // Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen results could happen.
    // Add Random Lightning modes
#define Calm 0    // No lightning
#define Slow 1    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3    // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4   // Like Mega, but with more lightning
  // Example:  { Slow, Fast, Mega, Mega2 } to randomize all four modes.
  // { Mega2 } for just Mega2.  { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
  byte LightningModes[] = { Mega, Mega, Mega2, Calm, Calm };
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
  static byte lightningMode=0;
  static time_t DelayCounter=millis();    // Variable for lightning timing.
  static int DelayTime=random(1000);      // Variable for lightning timimg.
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      randomSeed(millis());    // Seed the random number generator
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
      if (chooseLightning)
        chooseLightning=false;
      switch (lightningMode)
      case Calm:
        break;
      case Mega:
        // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
          int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
          for (int i=0; i<a; i++)
            analogWrite(daylightPWMPin,random(DaylightPWMValue*2.55,255));    // Flash on
            int randy=random(20,80);    // Random number for a delay
            if (randy>71) randy=((randy-70)/2)*100;    // Small chance of a longer delay
            delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
            analogWrite(daylightPWMPin,DaylightPWMValue*2.55);      // Flash off
            delay(random(30,50));                // Wait from 30 to 49 ms
            wdt_reset();
          DelayCounter=millis();    // If we just had a round of flashes, then lets put in a longer delay
          DelayTime=random(1000);   // of up to a second for dramatic effect before we do another round.
        break;
      case Mega2:
        // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
        if (lightningchance && random(ReversePWMSlope(cloudstart,cloudstart+cloudduration,100,0,180))<2 && (millis()-DelayCounter)>DelayTime)
            wdt_reset();
        break;
      case Fast:
            wdt_reset();
        break;
      case Slow:
        // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
          else lightningstatus=0;
          if (lightningstatus)
            DaylightPWMValue=100;
            DaylightPWMValue=0;
          delay(1);
        break;
      default:
        break;
      cloudindex++;
      if (cloudindex < numclouds)
      int x=0;
      else x=17;
      ReefAngel.CustomVar[3]=cloudstart/60;    // Write the hour of the next cloud to custom variable for Portal reporting
      else x=35;
      ReefAngel.CustomVar[4]=cloudstart%60;    // Write the minute of the next cloud to custom variable for Portal reporting
    ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
    if (lightningchance)
      int x=0;
      if (((cloudstart+(cloudduration/2))/60)>=10) x=51;
      else x=57;
      ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
      if (((cloudstart+(cloudduration/2))%60)>=10) x=69;
      else x=75;
      ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));    // Write the minute of the next lightning to a custom variable for the Portal
      ReefAngel.CustomVar[6]=(cloudstart+(cloudduration/2))%60;
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
This video is of a standard lightning strike, fast drivers. The video is of the middle portion of the cloud when lightning is active.
[youtube]http://www.youtube.com/watch?v=EAgJ_qOJBxc[/youtube]
Mega Storm! Entire 7 minute cloud sequence.
[youtube]http://www.youtube.com/watch?v=m8yQcdocF5E[/youtube]
Re: Cloud and Lightning Code
Posted: Mon Jul 28, 2014 10:59 am
Ok, cool, we can do a few updates to this, since ReversePWMSlope is no longer required (now build into the normal PWMSlope function)
Also, not sure I see the value of having ActinicPWMValue and DaylightPWMValue in the PWMSlope command.... Roberto can you elaborate on that?
I'll take a stab eventually, but good to have this thread here. I'm going to sticky it. Thanks Colin!
Posted: Mon Jul 28, 2014 11:02 am
lnevo wrote:Also, not sure I see the value of having ActinicPWMValue and DaylightPWMValue in the PWMSlope command.... Roberto can you elaborate on that?
It is because the CheckCloud(); overrides those values if it is time for a new cloud.
Posted: Mon Jul 28, 2014 11:04 am
But wouldn't that only take affect when the lights are off? Or is that so you can get lightning at night? :)
Also, Colin/Roberto, can you post the code that is not for high speed drivers too :)
Posted: Mon Jul 28, 2014 11:07 am
by cosmith71
Here's the original.
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
  // Calculate your regular sunrise/sunset PWM value
  ActinicPWMValue=PWMSlope(10,00,22,15,0,50,40,ActinicPWMValue);
  DaylightPWMValue=PWMSlope(10,00,22,15,0,50,40,DaylightPWMValue);
  CheckCloud();
void CheckCloud()
#define Max_Cloud_Duration 15
#define Start_Cloud_After NumMins(11,30)
#define End_Cloud_Before NumMins(18,30)
#else
#endif
      if (cloudchance)
  if (cloudchance)
          ActinicPWMValue=100;
          DaylightPWMValue=0;
          ActinicPWMValue=0;
        delay(1);
      cloudindex++;
      int x=0;
      if ((cloudstart/60)>=10) x=11; else x=17;
      if ((cloudstart%60)>=10) x=29; else x=35;
      int x=0;
      if (((cloudstart+(cloudduration/2))/60)>=10) x=51; else x=57;
      if (((cloudstart+(cloudduration/2))%60)>=10) x=69; else x=75;
  cstart*=60;
  cend*=60;
Posted: Mon Jul 28, 2014 11:19 am
I think that ReversePWMSlope may be different than what we added to PWMSlope, so perhaps its still required? I think this may actually be an inverse slope not reverse?
Posted: Mon Jul 28, 2014 11:30 am
by Sacohen
Great thread.
I hope to get my LDD Drivers set up in a couple of weeks.
This will work on the Dimming module as well, correct?
Posted: Mon Jul 28, 2014 11:49 am
lnevo wrote:But wouldn't that only take affect when the lights are off? Or is that so you can get lightning at night? :)
No, that code is only assigning the PWMSlope values to the variable.
Then it goes through CheckCloud, which will either set a new value or leave it alone depending on the state of whether we have a cloud or not.
    CheckCloud();
Then the final value (original slope or overridden cloud) is assigned to the channel.
Posted: Mon Jul 28, 2014 11:53 am
I'm referring specially to the last arg passed to PWMSlope. Wouldn't you just want that as 0?
Posted: Mon Jul 28, 2014 12:02 pm
Ahh. now I got it.
Yeah, you can use zero. I don't remember the reason for using the last arg like that. I don't think there was one actually... lol
Posted: Mon Jul 28, 2014 12:16 pm
Maybe you wanted to have lightning affects at night? :)
Posted: Mon Jul 28, 2014 12:48 pm
by cosmith71
Added video to OP.
Posted: Mon Jul 28, 2014 10:16 pm
by 89delta
Loving the update for the lightning.....more responsive on my ldd-l's.....looks like real flashes now.
Posted: Wed Jul 30, 2014 6:28 am
Of course since I'm using InternalMemory for the schedule, start%, end%, etc. I can't just use this code as-is.
I'm going to modify at some point soon to use the PWM Override variables to apply the effect. Does anyone see any issue doing that?
The only thing I can see is that I won't be able to override manually without a flag to disable the effect, but that's easily addressed.
Posted: Wed Jul 30, 2014 6:56 am
by cosmith71
Could you just read the memory locations and use them in the PWMSlope function call?
Posted: Wed Jul 30, 2014 7:13 am
Yes, I could... but I have four different channels that I'm controlling each with a separate offset and it's quite a lot of memory calls. Now imagine someone with the 16 channel custom module :) It's much simpler to call the function like this:
ReefAngel.PWM.Channel0Slope();
ReefAngel.PWM.Channel1Slope(5);
ReefAngel.PWM.Channel2Slope(10);
ReefAngel.PWM.Channel3Slope(15);
This takes care of all the schedulign using the standard memory and the dimmer settings as well.
Plus, I also have my acclimation code that I want to affect the dim % as well. I'm also building into my INO the option to choose different lighting schemes so I can choose Slope, Parabola, SmoothRamp (in dev branch). So it just gets messy.
Posted: Fri Aug 01, 2014 1:54 pm
by 89delta
Collin,
I've been using your update on the lighting effect for a couple of days now.....only issue i've seen so far though is after the lightning gets done any port that I shut off manually turns back on after the lightning.
Posted: Fri Aug 01, 2014 2:48 pm
by cosmith71
89delta wrote:Collin,
Do they switch back to auto, or turn on? That's bizarre. I'll try to replicate.
Posted: Fri Aug 01, 2014 2:56 pm
by 89delta
They switch back to auto.
Posted: Fri Aug 01, 2014 6:16 pm
by cosmith71
Yep, they sure do. My theory is the delays cause the unit to reset.
It may need a different approach.
Posted: Fri Aug 01, 2014 8:41 pm
by 89delta
Am sure if we can do some sort of last state on the relays before the lighting it'd fix it....
Sent from my SAMSUNG-SGH-I717 using Tapatalk
Posted: Sat Aug 02, 2014 5:53 am
by cosmith71
89delta wrote:Am sure if we can do some sort of last state on the relays before the lighting it'd fix it....
I think it would be better if we could prevent the reset to begin with. I have some ideas. I'll work on them Monday when I have some time. :ugeek:
Posted: Sat Aug 02, 2014 6:22 am
by 89delta
Sounds good Colin. Thanks for working on a fix for it. But figured you would want to know about the "bug".
Posted: Sat Aug 02, 2014 6:36 am
by cosmith71
You're welcome!
Posted: Sun Aug 03, 2014 3:03 am
by cosmith71
I have a fix, in theory at least. I haven't had a lot of time to test but it appears to work.
Find this section in cloudcheck()
And add these two lines:
Remove this section:
        int a=random(5);
          analogWrite(daylightPWMPin, 255);
          delay(20+random(50));
          analogWrite(daylightPWMPin, 0);
          delay(30+random(20));
        delay(random(1000));
And replace with this:
        int a=random(5);
This appears to work without setting off the watchdog timer and resetting the unit.
Posted: Sun Aug 03, 2014 7:57 am
by Sacohen
I bit OT, but do the LDD drivers generate enough heat to be concerned about.
I'm putting my 4 up board in a Radio Shack 5x2.5x2 Project Enclosure with openings cut in the sides to gain access to the screw down terminals for wiring.
Do I need another source of ventilation?
Posted: Sun Aug 03, 2014 8:04 am
by cosmith71
I was surprised at how hot mine get. The more LED's on the string, the hotter they get. Some of mine get up to 60C, and they are open air.
Posted: Sun Aug 03, 2014 8:11 am
by Sacohen
Thanks and thanks for the code.
Here is what my enclosure looks like.
I may have to leave it open air or have a fan blowing on it.
Posted: Sun Aug 03, 2014 8:47 am
I think the reboot issue is the watchdog kicking in.
We need to reset it inside the lightning sequence.
I'm pretty sure if you use the original code and just add the code below inside the for loop, it will stop:
wdt_reset();
Posted: Sun Aug 03, 2014 9:35 am
by cosmith71
How often does the watchdog timer need to be reset? I thought it was every second. The big delay is the delay(random(1000)) just outside the loop which might be pushing it over the top.
I'm thinking we may need more lightning. Like a chance during most of the cloud. Might be my day-off project. :mrgreen:
