Cloud and Lightning Code
Re: Cloud and Lightning Code
I've been working on some upgrades to the lightning engine. Stay tuned!
Update to OP
Improved lightning engine.
New option for increased Mega Lightning.
Cool, but by making the rate a define, we can't modify it on the fly through mem or variable changing. So, let's get away from using #defines for this... :) At some point I'll be making them all properties of the Cloud class.
My recommendation though would be to make it a separate mode... so Mega1 Mega2. This way we maintain one variable to choose which mode we want. Very cool updates though, keep em coming...
lnevo wrote:Cool, but by making the rate a define, we can't modify it on the fly through mem or variable changing. So, let's get away from using #defines for this... :) At some point I'll be making them all properties of the Cloud class.
Done. Went with Mega and Mega2, since Mega1 looks like Megal. :mrgreen:
Did you see that chalice encrusted on the Megaladon tooth? :)
New mode:
Calm
No lightning at all. Good for putting into a random sequence so there isn't lightning every time there is a cloud. OP updated.
jegillis
Post by jegillis »
Is there a version of this code for the dimming expansion?
No. I'm sure it could be adapted, but I don't have a dimming expansion. :(
RANet dimming expansion on the way! :D
Lee, have you done any work on putting this into a library? If not, I may start as a learning experience.
I haven't had time yet.. feel free to give it a try and I can certainly help :)
Awesome! I've always thought that the best way to learn something was to do it. I'm sure I'll have questions.
The lightning will have to be incorporated in the slave side. The cloud should be fine.
The RANet bandwidth is not fast enough.
It sends data every 100ms.
rimai wrote:The lightning will have to be incorporated in the slave side. The cloud should be fine.
Slave side? Esplain please.
Every RANet-Ready Wireless Module has a microcontroller in it to receive and process the wireless data.
The current firmware can only process data for relays and dimming channels.
We will need to create a firmware that can accept commands, so you can trigger remotely.
For example, a command to trigger the lightning effect on the dimming module.
You are not the only one that will want this.
The person using the dimmable LED driver wants this too.
I just need to find some time to put something together, but I'd like to release the next libs first.
The RANet requires some changes on the core libraries released from Arduino, specifically the SoftwareSerial library and I'd like to have at least the base communication working and released before we start adding functionality to it.
We have been getting some help from Sacohen, lnevo, AlanM, binder and others to see if any other minor bug is found.
Hopefully, we get a release soon.
I updated the previous post.
I meant to say RANet-Ready Wireless Module and not RANet-Add On.
Ah, I see. Load the sequence and then trigger when needed. I understand.
jegillis
Post by jegillis »
And I thought that just coding this for the dimming expansion would work. I don't know how to code much of anything but would be happy to test anything you come up with.
TheMikey
Post by TheMikey »
I feel like a bit of an idiot, but I can't seem to find this line:
byte LightningModes[] = { Slow, Fast, Mega };
To even start this programming. Is there an updated full code I need to find somewhere before attempting to customize this?
The updated code is in the first post.
Do a search for this:
 byte LightningModes[] = { Mega, Mega, Mega2, Calm, Calm };
And change it to your liking.
TheMikey
Post by TheMikey »
Found it! Thanks!
TanksNStuff
Post by TanksNStuff »
Has anyone had any luck modifying this code to work on the dimmer expansion module yet?
I'm getting ready to redo my entire coding for my tank upgrade and was hoping to incorporate clouds/lightning.
Not yet
Is there a way to write values directly to the dimming expansion? That's key. Otherwise it won't be fast enough for the right effect.
Actually the wired dimming has a fast enough connection. The wireless one is the one that doesn't.
TanksNStuff
Lee, is that because you haven't had time to try or because you ran into issues/errors that still need to be worked out? If it's simply a matter of changing just the PMWValue variables, maybe I'll try to take a stab at it.
In fact, I'll take a look at it now and see if I can figure it out. I'll report back here if I get it working.
I have wired connection dimmer expansion, so I should be good to go.
The obstacle is here, in the analogWrite statement. That bypasses the RA libraries to write directly to the daylight pin. It's the only way to get fast enough flashes.
 int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
          for (int i=0; i<a; i++)
            analogWrite(daylightPWMPin,random(DaylightPWMValue*2.55,255));    // Flash on
            analogWrite(daylightPWMPin,DaylightPWMValue*2.55);      // Flash off
            wdt_reset();
If you want to convert it, you'd need to find an equivalent way to write to the expansion module.
JTMBTech
Post by JTMBTech »
Sorry if this is a dumb question. Can i use this code to add lightning and cloud to my main white and actinic channels with the output from the relay box dimming ports, and then use the channels 0-3 on dimming expansion (using 4-5 for dc pumps) with the wizard generated code for the my other colored leds, green red uv and 2700k white? i have a diy led with steves led drivers and 6 different color leds over my 180 currently controlled by a typhoon. or would it not get the same effect because the other channels won't have the effect. I was hoping this might work because the main number of leds is white and actinic leds. i didnt realize when i ordered the dimming module and plus upgrade last week that the custom lighting codes had not been written for dimming module because the design had changed. I have very high hopes with the dimming module and just want to use my leds to their full potential! or is the code getting close to be finished for the new dimming module?
From what I understand this code only works on the relay dimming channels, it hasn't be ported over to the dimming hub yet. So I will work on your white and actinic lights only.
The dimming channel 1-3 will be normal dimming only.
Colin has already ported and made it even better when used with the dimming module.
Let's have him pitch in
It's ported to the RANet Dimming Expansion, but that code could be adapted. The issue noted a few posts above has been solved. It's just a matter of putting it all together.
I don't have a standard dimming expansion, so there may be some trial and error. I'll see if I can come up with something over the next week or so.
