Cloud and Lightning Code
PostPosted: Tue Mar 24, 2015 6:07 am
Roberto, is the address of the standard dimming expansion 0x40? I'm guessing it's the same dimming unit used in the RANet version?
PostPosted: Tue Mar 24, 2015 6:11 am
Yeap.
Exactly same thing
cosmith71 wrote:It's ported to the RANet Dimming Expansion, but that code could be adapted. The issue noted a few posts above has been solved. It's just a matter of putting it all together.
I don't have a standard dimming expansion, so there may be some trial and error. I'll see if I can come up with something over the next week or so.
That awesome. :)
PostPosted: Tue Mar 24, 2015 6:18 am
JTMBTech:
Do you want the Daylight channel, and expansion channels 0-3 to flash? Actinic doesn't flash.
PostPosted: Tue Apr 07, 2015 6:53 am
Anyone have noise to accompany the flash?
PostPosted: Wed Apr 08, 2015 7:16 pm
If the code only effects the white I would want to put my 2700 k white on one chanel, I was thinking 2700k white on relay box and 6300k white either on the same chanel or one of the chanels on the dimming expansion my other led chanels I can put on the remaining dimming expansion chanels, and the actinic chanel. Is the white normally the only chanel that flashes/changes? I just wanted to know if it was possible to use the relay box white output on storm and the expansion dimming ports on standard, however if the code has been ported to the dimming ex pansies I am sure it will work.
PostPosted: Thu Apr 09, 2015 5:18 am
Normally it's just the white that flashes, but that's just personal preference. We can make any channels you like flash.
PostPosted: Sat Jun 20, 2015 11:11 pm
So this code only works from the relay dimming ports, which are 0-10v, but you can only get the quick lightning flashes using LDD type drivers, 0-5v. Am i missing something here?
PostPosted: Sun Jun 21, 2015 4:35 am
If you have a modified relay box you can get 0-5v from the dimming ports. I thought the dimming module version had been sorted out. I'll look into it.
PostPosted: Sun Jun 21, 2015 12:26 pm
Officially adapted for the 6 channel Dimming Expansion Module.
viewtopic.php?f=12&t=5460
Return to How do I code ...
