Cloud and Lightning Code
PostPosted: Fri Apr 22, 2016 1:04 am
Has any one been able to override the dc pump setting for when a storm chance is going to happen?
PostPosted: Wed Nov 23, 2016 12:49 pm
any idea on how to not allow the lights to dim to X amount during cloud/strike?
i got my fuge light on oppisite of daylights and daylights are off when dimming is 1% or less and storm code is causing daylights to dim below that level from time to time when actived
i use update led set to Mem_B_LightsOffPerc,1
void UpdateLED() {
  ReefAngel.PWM.SetChannelRaw(0,DaylightPWMValue0);
  ReefAngel.PWM.SetChannelRaw(1,ActinicPWMValue1);
  ReefAngel.PWM.SetChannelRaw(2,DaylightPWMValue2);
  ReefAngel.PWM.SetChannelRaw(3,ActinicPWMValue3);
  ReefAngel.PWM.SetDaylightRaw(DaylightPWMValue);
  ReefAngel.PWM.SetActinicRaw(ActinicPWMValue);
  byte LightsOffPerc=40.95*InternalMemory.read(Mem_B_LightsOffPerc);
  if (ReefAngel.PWM.GetChannelValueRaw(0)>=LightsOffPerc) ReefAngel.Relay.On(WhiteLeft); else ReefAngel.Relay.Off(WhiteLeft);
  if (ReefAngel.PWM.GetChannelValueRaw(1)>=LightsOffPerc) ReefAngel.Relay.On(BlueLeft); else ReefAngel.Relay.Off(BlueLeft);
here is my store code
#define Clouds_Every_X_Days InternalMemory.read(Mem_B_CloudsEveryXDays)
#define Cloud_Chance_per_Day InternalMemory.read(Mem_B_CloudChancePerDay)
// Minimum number of minutes for cloud duration.  Don't use min duration of less than 6
#define Min_Cloud_Duration InternalMemory.read(Mem_B_MinCloudDuration)
#define Max_Cloud_Duration InternalMemory.read(Mem_B_MaxCloudDuration)
#define Min_Clouds_per_Day InternalMemory.read(Mem_B_MinCloudsPerDay)
#define Max_Clouds_per_Day InternalMemory.read(Mem_B_MaxCloudsPerDay)
#define Start_Cloud_After NumMins(InternalMemory.read(Mem_B_StartCloudAfterHour),InternalMemory.read(Mem_B_StartCloudAfterMin))
#define End_Cloud_Before NumMins(InternalMemory.read(Mem_B_EndCloudBeforeHour),InternalMemory.read(Mem_B_EndCloudBeforeMin))
#define Lightning_Chance_per_Cloud InternalMemory.read(Mem_B_LightningChance)
// Add Random Lightning modes
#define Calm 0    // No lightning
#define Slow 1    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3    // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4   // Like Mega, but with more lightning
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static byte lightningMode=0;
void CheckCloud()
  // Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
  // { Mega2 } for just Mega2.  { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
  byte LightningModes[] = {Slow};
  static time_t DelayCounter=millis();    // Variable for lightning timing.
  static int DelayTime=random(1000);      // Variable for lightning timimg.
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      // Commenting out to see if it's interfering with our other seed.
      // randomSeed(millis());    // Seed the random number generator
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
        // if picked number is greater than Lightning_Chance_per_Cloud, we will not have lightning today
        if (lightningchance>Lightning_Chance_per_Cloud) lightningchance=0;
  if (ReefAngel.Relay.isMaskOn(LED_STORM)) {
    InternalMemory.write(Mem_B_EnableStorm,false);
  if (ReefAngel.Relay.isMaskOff(LED_STORM)) {
    InternalMemory.write(Mem_B_EnableStorm,true);
  if (InternalMemory.read(Mem_B_EnableStorm)) return;
  if (cloudchance)
    if (ReefAngel.Relay.isMaskOff(TRIGGER_STORM))      // Change this to whatever port you want to use as a trigger.
      cloudstart = NumMins(hour(), minute());
      ReefAngel.Relay.Auto(TRIGGER_STORM);    // Here, too.
    //is it time for cloud yet?
      // Increase Blue channel first for better effect and to compensate for drop in Whites
      ActinicPWMValue1=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,ActinicPWMValue1,ActinicPWMValue1+DaylightPWMValue0,180);
      ActinicPWMValue3=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,ActinicPWMValue3,ActinicPWMValue3+DaylightPWMValue2,180);
      DaylightPWMValue0=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,DaylightPWMValue0,0,180);
      DaylightPWMValue2=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,DaylightPWMValue2,0,180);
      if (chooseLightning)
        chooseLightning=false;
      switch (lightningMode)
      case Calm:
        break;
      case Mega:
        // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
          // Send the trigger
          Strike();
          DelayCounter=millis();    // If we just had a round of flashes, then lets put in a longer delay
          DelayTime=random(1000);   // of up to a second for dramatic effect before we do another round.
        break;
      case Mega2:
        // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
          Strike();
        break;
      case Fast:
          Strike();
        break;
      case Slow:
        // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
        if (lightningchance && second()%40<8)
          SlowStrike();
        break;
      default:
        break;
      cloudindex++;
      if (cloudindex < numclouds)
  // Cloud ON option - Clouds every minute
  if (ReefAngel.Relay.isMaskOn(TRIGGER_STORM) && now()%60<10)
    SlowStrike();
void SlowStrike()
    int r = random(100);
    if (r<20) lightningstatus=1;
    else lightningstatus=0;
    if (lightningstatus)
      // Let's separate left and right both.
      if (r<14) {
        DaylightPWMValue0=4095;
        DaylightPWMValue2=4095;
        ActinicPWMValue1=4095;
        ActinicPWMValue3=4095;
      } else if (r<17) {
        DaylightPWMValue0=100;
        DaylightPWMValue2=100;
    delay(1);
void DrawClouds(int x, int y)
    ReefAngel.LCD.DrawText(0,255,x,y,"C"); x+=6;
    ReefAngel.LCD.DrawText(0,255,x,y,"00:00"); x+=34;
    ReefAngel.LCD.DrawText(0,255,x,y,"L"); x+=6;
    ReefAngel.LCD.DrawText(0,255,x,y,"00:00"); x=5;
      int x=0;
      else x=17;
      ReefAngel.LCD.DrawText(0,255,x,y,(cloudstart/60));
      ReefAngel.CustomVar[0]=cloudstart/60; // Write the hour of the next cloud to custom variable for Portal reporting
      else x=35;
      ReefAngel.LCD.DrawText(0,255,x,y,(cloudstart%60));
      ReefAngel.CustomVar[1]=cloudstart%60; // Write the minute of the next cloud to custom variable for Portal reporting
    ReefAngel.LCD.DrawText(0,255,x+85,y,cloudduration);
    ReefAngel.CustomVar[2]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
    if (lightningchance)
      int x=0;
      if (((cloudstart+(cloudduration/3))/60)>=10) x=51;
      else x=57;
      ReefAngel.LCD.DrawText(0,255,x,y,((cloudstart+(cloudduration/3))/60));
      ReefAngel.CustomVar[6]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
      if (((cloudstart+(cloudduration/3))%60)>=10) x=69;
      else x=75;
        ReefAngel.LCD.DrawText(0,255,x,y,((cloudstart+(cloudduration/3))%60)); // Write the minute of the next lightning to a custom variable for the Portal
        ReefAngel.CustomVar[7]=(cloudstart+(cloudduration/2))%60;
void Strike()
  int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
  for (int i=0; i<a; i++)
    // Flash on
    int newdata=4095;
    Wire.beginTransmission(0x40);      // Address of the dimming expansion module
    Wire.write(0x8+(4*0));             // 0x8 is channel 0, 0x12 is channel 1, etc.  This is channel 0.
    Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
    Wire.write(newdata>>8);            // This sends the MSB
    Wire.endTransmission();
    Wire.write(0x8+(4*2));             // 0x8 is channel 0, 0x12 is channel 1, etc.  This is channel 2.
    int randy=random(20,80);    // Random number for a delay
    if (randy>71) randy=((randy-70)/2)*100;    // Small chance of a longer delay
    delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
    // Flash off.  Return to baseline.
    newdata=ReefAngel.PWM.GetChannelValueRaw(0);   // Use the channel number you're flashing here
    Wire.beginTransmission(0x40);    // Same as above
    newdata=ReefAngel.PWM.GetChannelValueRaw(2);   // Use the channel number you're flashing here
    delay(random(30,50));                // Wait from 30 to 49 ms
    wdt_reset();    // Reset watchdog timer to avoid re-boots
  cstart*=60;
  cend*=60;
int ReversePWMSlopeHighRes(long cstart,long cend,int PWMStart,int PWMEnd, byte clength)
  cstart*=60;
  cend*=60;
PostPosted: Fri Apr 06, 2018 2:19 pm
any way to use this with the new star?
PostPosted: Sun Apr 07, 2019 3:03 pm
Any chance someone can look at this part of my storm coding and let me know why my fluorescents stay on during storm? Is there a better way of doing this?
Thanks much!
  if (cloudchance)
    if (ReefAngel.Relay.isMaskOn(Port7))      // Change this to whatever port you want to use as a trigger to start a storm.
      ReefAngel.Relay.Auto(Port7);    // Here, too.
     ReefAngel.Relay.Off(Box1_Port7);                // Turn off Fluorescents
     ReefAngel.Relay.Auto(Box1_Port7);               //  Fluorescents back to auto.
      // Increase Blue channel first, for better effect and to compensate for drop in Whites
    ActinicPWMValue0=ReversePWMSlope(cloudstart,cloudstart+cloudduration,ActinicPWMValue0,ActinicPWMValue0+DaylightPWMValue1*1.1,180);
    ActinicPWMValue2=ReversePWMSlope(cloudstart,cloudstart+cloudduration,ActinicPWMValue2,ActinicPWMValue2+DaylightPWMValue3*1.1,180);
    ActinicPWMValue4=ReversePWMSlope(cloudstart,cloudstart+cloudduration,ActinicPWMValue4,ActinicPWMValue4+DaylightPWMValue5*1.1,180);
         // Daylight dimming from cloud
    DaylightPWMValue1=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue1/40.95,2,180)*40.95;
    DaylightPWMValue3=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue3/40.95,2,180)*40.95;
    DaylightPWMValue5=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue5/40.95,2,180)*40.95;
PostPosted: Mon Apr 08, 2019 3:00 pm
I don't think this the piece of code that is having problems.
You may have something further down in the code that is overriding this.
Can you post the entire code?
PostPosted: Mon Apr 08, 2019 4:22 pm
As it is now, if I try to manually turn fluorescents on outside of their normal 2pm-6pm time frame, they flash on, then turn right back off, so I think the auto is overriding my manual on attempts as well.
Also while you are looking, my storms always happen at 3:30pm, even though I have the random time portion in my code.
Thanks Roberto!
#include <SunLocation.h>
#include <Tide.h>
#include <Moon.h>
#include <WiFiAlert.h>
  SunLocation sl;
  int avgph[10];
    unsigned long totalavgph=0;
    byte avgindex=0;
      byte x;
      byte y = 2;
      char text[7];
      // *********** CHANGE TEMP READOUT COLOR DEPENDENT ON FAN AND HEATER STATUS ***********
      int TempColor;                                    // Color for drawing temperature
      boolean HeatOn = ReefAngel.Relay.Status(Port2);   // Get the status of the heater relay
      if (HeatOn)
        TempColor = COLOR_NAVY;                         // Blue text, too cold, heater is on
      if (!HeatOn)
          TempColor = COLOR_GREEN;                      // Green text, no fan or heater on
             int pHColor;                                 // Color for drawing pH
      boolean LowpH = (ReefAngel.Params.PH < 780) ;     // Check for Low pH Value
      boolean HighpH = (ReefAngel.Params.PH > 850);     // Check for High pH Value
      if (LowpH)
        pHColor = COLOR_NAVY;                          // Blue text, Low pH value
      if (HighpH)
        pHColor = COLOR_RED;                           // Red text, High pH value
      if (!LowpH && !HighpH)
        pHColor = COLOR_GREEN;                         // Green text, pH acceptable
      ReefAngel.LCD.DrawLargeText(COLOR_DARKSLATEBLUE,DefaultBGColor, 6, 3, " Thunder Reef",Font8x8);   // Put a banner at the top
      ReefAngel.LCD.DrawDate(6, 119);        // Put the date and time at the bottom
      ReefAngel.LCD.Clear(COLOR_BLACK, 1, 12, 132, 12);                                                 // Draw a black line under the banner
      x = 6;
      y += MENU_START_ROW*1.4;        // MENU_START_ROW is 10, according to globals.h, so y=2+10+1=13
      ReefAngel.LCD.DrawLargeText(COLOR_BLUE, COLOR_WHITE, x, y+1, " Temp      pH");
      ConvertNumToString(text, ReefAngel.Params.Temp[T1_PROBE], 10);                                    // Get T1 temp and convert
      x = 2;
      y += MENU_START_ROW*1.6;
      ReefAngel.LCD.DrawHugeNumbers(COLOR_BLACK, TempColor, x, y, text);                                // Draw the temperature, white numbers on a colored background
      ConvertNumToString(text, ReefAngel.Params.PH, 100);                                               // Get pH reading and convert
      x = 2;
      y = MENU_START_ROW*2.6;
      ReefAngel.LCD.DrawHugeNumbers(COLOR_YELLOW, pHColor, x+65, y+6, text);                            // Put pH on the screen
      x += 6;
      y += MENU_START_ROW*3.3;
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,25,y,"Sump Level",Font8x8);      // Draw the Sump Float switch status
  {ReefAngel.LCD.FillCircle(15,y+3,7,COLOR_RED);
  ReefAngel.LCD.FillCircle(15,y+3,7,COLOR_GREEN);
  x += 6;
  y += MENU_START_ROW*2.0;
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,25,y,"Skimmer Cup",Font8x8);     // Draw the Skimmer Cup Float switch status
  if (ReefAngel.HighATO.IsActive()) {ReefAngel.LCD.FillCircle(15,y+3,7,COLOR_GREEN);
      byte TempRelay = ReefAngel.Relay.RelayData;                                          // Code for drawing the relay box
      ReefAngel.LCD.DrawOutletBox(12, 100, TempRelay);
    int ActinicPWMValue0=1;        // For cloud code, channel 0, left blue
    int ActinicPWMValue2=1;        // For cloud code, chennel 2, center blue
    int ActinicPWMValue4=1;        // For cloud code, chennel 4, right blue
    int DaylightPWMValue1=1;        // For cloud code, channel 1, left white
    int DaylightPWMValue3=1;        // For cloud code, chennel 3, center white
    int DaylightPWMValue5=1;        // For cloud code, chennel 5, right white
    ReefAngel.Init();        // Initialize controller
    ReefAngel.Use2014Screen();                                                               // Let's use 2014 Screen
    ReefAngel.Timer[FEEDING_TIMER].SetInterval(1200);                                        // Feeding timer at 20 minutes (in seconds)
    ReefAngel.FeedingModePorts = Port1Bit | Port6Bit | Port7Bit | Port8Bit;                  // Ports toggled in Feeding Mode
    ReefAngel.WaterChangePorts = Port1Bit | Port6Bit | Port7Bit | Port8Bit;                  // Ports toggled in Water Change Mode
    ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit;                     // Ports toggled when Lights On / Off menu entry selected
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit;                         // Ports turned off when Overheat temperature exceeded
    ReefAngel.TempProbe = T1_PROBE;                                                          // Use T1 probe as temperature and overheat functions
    InternalMemory.OverheatTemp_write( 820 );                                                // Set the Overheat temperature setting
    CustomOverheatClear(T1_PROBE);
    ReefAngel.Relay.On( Port1 );  // Return
    // Ports that are always off
    ReefAngel.Relay.Off( Port7 );
    // Delayed start for skimmer to allow sump level to return to normal after water change
    ReefAngel.Relay.DelayedOn( Port5,5 );
    sl.Init(28.5700, -81.6800);    // Lat/long for Clermont, FL
    sl.SetOffset(-2,0,-2,0);       // rise_hour, rise_seconds, set_hour, set_seconds (set 2 hrs later for better viewing time (-4 offset = actual time))
    randomSeed(now()%SECS_PER_DAY);
      //Custom Variable [0] =  Month/Season
    ReefAngel.CustomLabels[0]="Return";
    ReefAngel.CustomLabels[1]="Heaters";
    ReefAngel.CustomLabels[2]="Cooling Fan";
    ReefAngel.CustomLabels[3]="ATO/Swabbie";
    ReefAngel.CustomLabels[4]="Skimmer";
    ReefAngel.CustomLabels[5]="Kalk Stirrer";
    ReefAngel.CustomLabels[6]="Storm Mode";
    ReefAngel.CustomLabels[7]="Fuge Light";
    ReefAngel.CustomLabels[8]="Left Whites";
    ReefAngel.CustomLabels[9]="Left Blues";
    ReefAngel.CustomLabels[10]="Center Whites";
    ReefAngel.CustomLabels[11]="Center Blues";
    ReefAngel.CustomLabels[12]="Right Whites";
    ReefAngel.CustomLabels[13]="Right Blues";
    ReefAngel.CustomLabels[14]="ATI Coral+";
    ReefAngel.CustomLabels[15]="Moonlights";
    // seasonal temperatures
    SeasonalTemps();
// Default lights program
ActinicPWMValue0=PWMSlopeHighRes(10,00,21,30,1,72,180,41);  // Default for blues
ActinicPWMValue2=PWMSlopeHighRes(10,15,21,45,1,72,180,41);
ActinicPWMValue4=PWMSlopeHighRes(10,30,22,00,1,72,180,41);
DaylightPWMValue1=PWMSlopeHighRes(12,45,18,45,1,22,105,41);    //  Default for whites
DaylightPWMValue3=PWMSlopeHighRes(13,00,19,00,1,22,105,41);
DaylightPWMValue5=PWMSlopeHighRes(13,15,19,15,1,22,105,41);
CheckCloud();    //  Check for cloud and slow lightning.
ReefAngel.PWM.SetChannelRaw(0,ActinicPWMValue0);  //  Write values for either default or cloud/slow
ReefAngel.PWM.SetChannelRaw(2,ActinicPWMValue2);  //  lightning if it's time.
ReefAngel.PWM.SetChannelRaw(4,ActinicPWMValue4);  //  lightning if it's time.
ReefAngel.PWM.SetChannelRaw(1,DaylightPWMValue1);  //  Write values for either default or cloud/slow
ReefAngel.PWM.SetChannelRaw(3,DaylightPWMValue3);  //  lightning if it's time.
ReefAngel.PWM.SetChannelRaw(5,DaylightPWMValue5);  //  lightning if it's time.
// Turn Actinic outlets on if any % is >= 2
(ReefAngel.PWM.GetChannelValue(0)>=2) ?  ReefAngel.Relay.On( Box1_Port2 ) :  ReefAngel.Relay.Off( Box1_Port2 );
(ReefAngel.PWM.GetChannelValue(2)>=2) ?  ReefAngel.Relay.On( Box1_Port4 ) :  ReefAngel.Relay.Off( Box1_Port4 );
(ReefAngel.PWM.GetChannelValue(4)>=2) ?  ReefAngel.Relay.On( Box1_Port6 ) :  ReefAngel.Relay.Off( Box1_Port6 );
//Turn Daylight outlet on if any % is >=2
(ReefAngel.PWM.GetChannelValue(1)>=2) ?  ReefAngel.Relay.On( Box1_Port1 ) :  ReefAngel.Relay.Off( Box1_Port1 );
(ReefAngel.PWM.GetChannelValue(3)>=2) ?  ReefAngel.Relay.On( Box1_Port3 ) :  ReefAngel.Relay.Off( Box1_Port3 );
(ReefAngel.PWM.GetChannelValue(5)>=2) ?  ReefAngel.Relay.On( Box1_Port5 ) :  ReefAngel.Relay.Off( Box1_Port5 );
// ATI Coral+ Flourescents
if (hour()>=14 && hour()<18)
ReefAngel.Relay.Off( Box1_Port7 );
// Refugium Light: sPar38-Fuge
if (hour()<18 || hour() >=20)
ReefAngel.Relay.Off( Port8 );
//  Moonlight Strip
if (hour()>=8 && hour()<23)
 ReefAngel.Relay.Off( Box1_Port8 );
 //Enclosure cooling fan control with T2 probe
 if (ReefAngel.Params.Temp[T2_PROBE]>=820) ReefAngel.Relay.On( Port3 );
 if (ReefAngel.Params.Temp[T2_PROBE]<800) ReefAngel.Relay.Off( Port3 );
// pp-15 powerheads schedule
if (hour()>=8 && hour()<10)
 ReefAngel.PWM.SetDaylight( ReefCrestMode(40,5,true) ); // reefcrest at 40% +/- 5% on sync mode       (Morning Mode)
 ReefAngel.PWM.SetActinic( ReefCrestMode(40,5,false) ); // reefcrest at 40% +/- 5% on Anti-sync mode  (Morning mode)
else if (hour()>=10 && hour()<13)
 //byte random_speed=random(35,50);
 //byte random_duration=random(3,7);
 ReefAngel.PWM.SetDaylight( GyreMode(25,70,15,true) ); // Ramping  25%-70% for 15 min on sync mode (Gyre)
 ReefAngel.PWM.SetActinic( GyreMode(25,70,15,false) ); // Ramping  25%-70% for 15 min on anti-sync mode (Gyre)
else if (hour()>=13 && hour()<15)
 byte random_speed=random(40,60);
 byte random_duration=random(3,5);
 ReefAngel.PWM.SetDaylight( LongPulseMode(25,random_speed,random_duration,true) ); // Long Pulse 25% ramping up to 40%-60% for 3-5 seconds on sync mode (Medium swells)
 ReefAngel.PWM.SetActinic( LongPulseMode(25,random_speed,random_duration,false) ); // Long Pulse 25% ramping up to 40%-60% for 3-5 seconds on Anti-sync mode (Medium swells)
else if (hour()>=15 && hour()<17)
 byte random_speed=random(40,50);
 ReefAngel.PWM.SetDaylight( ShortPulseMode(1,random_speed,408,true) ); // Short pulse at 45%-60% with 408ms pulse on sync mode (surface wave 1/2"-3/4")
 ReefAngel.PWM.SetActinic( ShortPulseMode(1,random_speed,408,false) ); // Short pulse at 45%-60%% with 408ms pulse on Anti-sync mode (surface wave 1/2"-3/4")
else if (hour()>=17 && hour()<19)
 byte random_duration=random(2,5);
 ReefAngel.PWM.SetDaylight( LongPulseMode(1,random_speed,random_duration,true) ); // Long Pulse 1% ramping up to 40%-50% for 2-5 seconds on sync mode (Feeding hour)
 ReefAngel.PWM.SetActinic( LongPulseMode(1,random_speed,random_duration,false) ); // Long Pulse 1% ramping up to 40%-50% for 2-5 seconds on Anti-sync mode  (Feeding hour)
else if (hour()>=19 && hour()<20)
 byte random_min=random(35,45);
 byte random_speed=random(50,65);
 byte random_duration=random(2,6);
 ReefAngel.PWM.SetDaylight( LongPulseMode(random_min,random_speed,random_duration,true) ); // Long Pulse 35%-45% ramping up to 50%-65% for 2-5 seconds on sync mode (nutrient transport)
 ReefAngel.PWM.SetActinic( LongPulseMode(random_min,random_speed,random_duration,false) ); // Long Pulse 35%-45% ramping up to 50%-65% for 2-5 seconds on Anti-sync mode  (nutrient transport)
else if (hour()>=20 && hour()<21)
 ReefAngel.PWM.SetDaylight( ReefCrestMode(40,10,true) ); // reefcrest at 40% +/- 10% on sync mode       (Evening Mode)
 ReefAngel.PWM.SetActinic( ReefCrestMode(40,10,false) ); // reefcrest at 40% +/- 10% on Anti-sync mode  (Evening mode)
 ReefAngel.PWM.SetDaylight( ReefCrestMode(35,10,true) ); // reefcrest at 35% +/- 10% on sync mode       (night Mode)
 ReefAngel.PWM.SetActinic( ReefCrestMode(35,10,false) ); // reefcrest at 35% +/- 10% on Anti-sync mode  (night mode)
if( ReefAngel.DisplayedMenu==FEEDING_MODE )
 ReefAngel.PWM.SetActinic(20);
 ReefAngel.PWM.SetDaylight(20);
if( ReefAngel.DisplayedMenu==WATERCHANGE_MODE )
 ReefAngel.PWM.SetActinic(1);
 ReefAngel.PWM.SetDaylight(1);
// enter feeding mode at 6:15pm
//if ( (hour()==18 && minute()==15 && second()==0))
//ReefAngel.FeedingModeStart(); // turn on feeding mode
if(ReefAngel.HighATO.IsActive())           //  Float switch in Skimmer Locker
 ReefAngel.Relay.Off(Port5);               //  Turn off Skimmer when locker full.
// ATO, Port 8 is ATO using Clear RoDi
 ReefAngel.SingleATO(true,Port4,400,0);   //  Sump switch.  If ATO/RoDi runs for 400 seconds, then shut off and send alert.
    sl.CheckAndUpdate();  // handle updating sunrise and sunset values
    ReefAngel.Portal( "DmnYnkee" );
 void SeasonalTemps ()
  static int heatArray[][2] = { {786,790},                  // default in case of error in month=0 (June)
                    {786,790},//January (winter)            // 77.6
                    {786,790},//February (winter)           // 77.8
                    {786,790},//March (early spring)        // 78.0
                    {786,790},//April (spring)              // 78.2
                    {786,790},//May (spring)                // 78.4
                    {786,790},//June (early summer)         // 78.8
                    {786,790},//July (summer)               // 79.2
                    {786,790},//August (summer)             // 79.6
                    {786,790},//September (early fall)      // 79.2
                    {786,790},//October (fall)              // 78.8
                    {786,790},//November (fall)             // 78.4
                    {786,790} };//December (early winter)   // 78.0
  ReefAngel.StandardHeater( Port2,heatArray[month()][0],heatArray[month()][1]);
 }//end seasonalTemps
// ------------------------------------ Auto overheat clear
void CustomOverheatClear(byte probe)
if((bitRead(ReefAngel.AlertFlags, OverheatFlag)) && (ReefAngel.Params.Temp[probe] <= InternalMemory.OverheatTemp_read()-30))
ReefAngel.OverheatClear();
// ------------------------------------------------------------  Weather section
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 8
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 2
  // In this example, start cloud after 1:30pm
#define Start_Cloud_After NumMins(13,30)
  // In this example, end cloud before 6:30pm
  byte LightningModes[] = { Mega };        // <---- set Storm modes here
#else
#endif
      if (cloudchance)
  if (cloudchance)
    //if (NumMins(hour(),minute())>=cloudstart && NumMins(hour(),minute())<(cloudstart+cloudduration))
     //ReefAngel.Relay.Off(Box1_Port7);                // Turn off Flourescents
     //else
     //ReefAngel.Relay.Auto(Box1_Port7);               //  Flourescents back to auto.
      case Calm:
        break;
      case Mega:
          // Send the trigger
          int r=random(34);
          if (r<20) {
          Strike1();                // All 3 lights
        } else if (r<22) {
          Strike2();                // Left only
        } else if (r<24) {
          Strike3();                // Center only
        } else if (r<28) {
          Strike4();                // Right only
        } else if (r<30) {
          Strike5();                // Left & Center
        } else if (r<34)
          Strike6();                // Center & Right
          DelayTime=random(1800);   // of up to a second for dramatic effect before we do another round.
        break;
      case Mega2:
          Strike();
        break;
      case Fast:
          Strike();
        break;
      case Slow:
          SlowStrike();
        break;
      default:
        break;
      cloudindex++;
  if (ReefAngel.Relay.isMaskOff(Port7) && now()%60<10)
    SlowStrike();
    void SlowStrike()
    int r = random(80);
      // Let's separate left, center, right, or All.
      if (r<10  ) {               // All 3
        DaylightPWMValue1=4095;
        DaylightPWMValue3=4095;
        DaylightPWMValue5=4095;
      } else if (r<12) {          // Left only
        DaylightPWMValue3=100;
        DaylightPWMValue5=100;
      } else if (r<14) {          // Center only
        DaylightPWMValue1=100;
      } else if (r<16) {          // Right only
      } else if (r<18) {          // Left & Center only
      } else {                    // Center & Right only
        delay(1);
      int x=0;
      else x=17;
      //ReefAngel.CustomVar[3]=cloudstart/60; // Write the hour of the next cloud to custom variable for Portal reporting
      else x=35;
      //ReefAngel.CustomVar[4]=cloudstart%60; // Write the minute of the next cloud to custom variable for Portal reporting
    ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
      int x=0;
      else x=57;
      ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
      else x=75;
void Strike1()          //  All 3 lights
    // Flash on
    int newdata=4095;
    Wire.write(0x8+(4*1));             // 0x8 is channel 0, 0x12 is channel 1, etc.  This is channel 1.
    Wire.write(0x8+(4*3));             // 0x8 is channel 0, 0x12 is channel 1, etc.  This is channel 3.
    Wire.write(0x8+(4*5));             // 0x8 is channel 0, 0x12 is channel 1, etc.  This is channel 5.
    newdata=ReefAngel.PWM.GetChannelValueRaw(1);   // Use the channel number you're flashing here
    newdata=ReefAngel.PWM.GetChannelValueRaw(3);   // Use the channel number you're flashing here
    newdata=ReefAngel.PWM.GetChannelValueRaw(5);   // Use the channel number you're flashing here
void Strike2()          // Left only
  int a=random(1,4);    // Pick a number of consecutive flashes from 1 to 3.
    // Flash on
    int newdata=4095;
void Strike3()          // Center only
    // Flash on
    int newdata=4095;
void Strike4()          // Right only
    // Flash on
    int newdata=4095;
void Strike5()          //  Left & Center
    // Flash on
    int newdata=4095;
void Strike6()          // Center & Right
    // Flash on
    int newdata=4095;
void Strike()
    // Flash on
    int newdata=4095;
  cstart*=60;
  cend*=60;
int ReversePWMSlope(long cstart,long cend,int PWMStart,int PWMEnd, byte clength)
  cstart*=60;
  cend*=60;
Previous
Return to How do I code ...
