Turn on relay when WL is at 100% or >?
PostPosted: Sun Aug 03, 2014 12:20 pm
This is probably simple for you guys.
I want to turn port 3 on thee main Relay on for 1 hour when WaterLevel 1 of the multi sensor is at 100% or above.
I think this is the basis for it, but I don't know know how to have it turn off after 1 hour.
if (ReefAngel.WaterLevel.GetLevel(1)>=100) ReefAngel.Relay.On(Port3);
Thanks for your help.
PostPosted: Sun Aug 03, 2014 12:57 pm
That looks about right. Not sure if you would need an Else statement in there or not also. I know from reading analog or digital pins i've added it.
PostPosted: Sun Aug 03, 2014 1:04 pm
What you posted will keep the port on as long as the value is equal or above 100. As soon as it does not meet that criteria, it will not keep turning it on. You would want to put in an else statement to turn it off and also add in a timer to ensure that it shuts off after your specified time frame. You will also want to have a failsafe to prevent it from getting reactivated after the 1 hour time delay occurs.
that should be able to get you going in the right direction and maybe give you some tips for your coding. i'm sure others will be able to help more.
PostPosted: Sun Aug 03, 2014 1:08 pm
What I put will just turn the port on indefinitely, there needs to be something that will turn it off after 1hr.
PostPosted: Sun Aug 03, 2014 1:13 pm
binder wrote:What you posted will keep the port on as long as the value is equal or above 100. As soon as it does not meet that criteria, it will not keep turning it on. You would want to put in an else statement to turn it off and also add in a timer to ensure that it shuts off after your specified time frame. You will also want to have a failsafe to prevent it from getting reactivated after the 1 hour time delay occurs.
Curt;
I agree with you.
I just have no idea how to code it.
Basically what I want to do is one I refill my ATO reservoir (either manually now or automatically in the future) I want the pump inside the reservoir to turn on for 1 hr (may change that later) to stir up and mix the Kalwasser that is either on the bottom of the reservoir that did not dissolve last time because it was above the saturation point or new Kalkwasser that I add to replenish what has been used up.
PostPosted: Sun Aug 03, 2014 1:24 pm
time_t stopTime = 0;
if (ReefAngel.WaterLevel.GetLevel(1)<=100) stopTime=now()+3600;
if (stopTime-now() < 3600) { ReefAngel.Relay.On(Port3); } else ReefAngel.Relay.Off(Port4); }
You just may want a flag to set the stopTime... But essentially above is what you want..i believe
PostPosted: Sun Aug 03, 2014 1:35 pm
Thanks Lee.
I think that is what I want.
Basically the way I read it is if the Water Level is 100% or greater to turn on port 3 and start a 3600 (or 1 hr timer).
The stop time is checking if it is less then 3600 seconds or over and it will either leave port 3 on or turn off what I assume to be Port3 not Port4. Correct?
if (stopTime-now() < 3600) { ReefAngel.Relay.On(Port3); } else ReefAngel.Relay.Off(Port3); }
PostPosted: Sun Aug 03, 2014 2:05 pm
I tried adding that code to the loop section right before my Auto Feeder code and it seems to be conflicting something.
I get the following error...
expected unqualified-id before 'if'
Here is my code...
#include <Wire.h>fF
#include <RA_NokiaLCD.h>f
// Define Relay Ports by Name
#define Actinic_Lights     1
#define Day_Lights         2
#define Unused             3
#define Pumps              4
#define Sump_Fan           5
#define DeNit_Doser        6
#define DeNit_Pump         7
#define ATO_Pump           8
#define Unused             Box1_Port1
#define Feeder             Box1_Port2
#define Unused             Box1_Port3
#define Unused             Box1_Port4
#define Unused             Box1_Port5
#define Unused             Box1_Port6
#define Unused             Box1_Port7
#define Dummy              Box1_Port8
// Does not need to be global.
// unsigned long ATOUpdate=0;
//Set Standard Menu
ReefAngel.AddStandardMenu();
ReefAngel.DCPump.DaylightChannel=AntiSync; // Now you're pump will be affected by the portal settings.
ReefAngel.Relay.On( Pumps );
ReefAngel.Relay.On( Dummy );
  ReefAngel.StandardLights( Actinic_Lights,12,0,22,0 );
  ReefAngel.StandardLights( Day_Lights,13,0,21,0 );
  ReefAngel.StandardLights( Sump_Fan,13,0,21,0 );
  ReefAngel.WaterLevelATO(ATO_Pump,720,28,31);
  if ( hour()>=13 && hour()<21 )
  ReefAngel.PWM.SetChannel( 5, 0 );
  ReefAngel.PWM.SetChannel( 5, PWMSlope(21,0,13,0,0,MoonPhase() ,60,0) );
  //AutoFeeder
static unsigned long autofeeding = 0;
if ((now()%SECS_PER_DAY==64800)) //if it is 6 pm
if ( autofeeding == 0 ) {
autofeeding = now(); //set the time of the start of feeding to variable feeding
if ((now()-autofeeding>=60) && (now()-autofeeding<=61)) //if between 60 and 61 seconds has past
if ( autofeeding > 0 ) {
autofeeding = 0;
  // DeNitrate Routine
int DeNit_Offset=3600;
int DeNit_Repeat=21600;
int DeNit_Doser_Offset=1200;
int DeNit_Doser_Runtime=600;
int DeNit_Pump_Runtime=1200;
int DeNit_ATO_Offtime=1500;
// Pump comes on first
ReefAngel.Relay.Set(DeNit_Pump,(now()-DeNit_Offset)%DeNit_Repeat<DeNit_Pump_Runtime);  // Runs denitrator pump
// Doser comes on second
ReefAngel.Relay.Set(DeNit_Doser,((now()-DeNit_Offset)-DeNit_Doser_Offset)%DeNit_Repeat<DeNit_Doser_Runtime); // Runs denitrator doser
  // Disable ATO
if ( (now()-3600)%21600<DeNit_ATO_Offtime) ReefAngel.WaterLevelATO(ATO_Pump,720,0,1);
  // Delay WL ATO after water change and DeNit_Dosing
  static time_t wcTimer=0;
  // First 10 minutes after WC disable ATO
  if (now()-wcTimer >= 0 && now()-wcTimer < 600)
    // Track Salinity low duration
    static unsigned long lastGoodSal;
    static boolean lowSalFlag;
    // Salinity is good, update counter
    if (ReefAngel.Params.Salinity>=335) lastGoodSal=now();
    // Counter hasn't been updating in 300 seconds..
    if (now()-lastGoodSal>300) {
      lowSalFlag=true; // Salinity is definitely below 33.5
      lowSalFlag=false; // Salinity back to normal
    // Disable ATO if lowSalFlag is true
    if (lowSalFlag) ReefAngel.WaterLevelATO(ATO_Pump,720,0,1);
  // Disable ATO if ATO High IsActive()
static int rmode;
// Add Else Mode definition..
const int Else=16;
byte modes[] = { ReefCrest, Lagoon, Constant, TidalSwell, ShortPulse, LongPulse, Else };
changeMode=false;
static unsigned long feeding;
if (now()-feeding<3600) {
} else if (now()%SECS_PER_DAY<43200 || now()%SECS_PER_DAY>=79200) { // 12pm / 10pm
  // Night mode (go to 30%)
  ReefAngel.DCPump.Speed=30;
  if (modes[rmode]==Else) {
    ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),20,true );    // ElseMode on sync mode, Portal Speed Setting +/- 20%
  ReefAngel.Portal( "Sacohen","xxxxxxxx );
int x,y;
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,57, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,57, ReefAngel.WaterLevel.GetLevel() );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,66,66, "WL 1:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, ReefAngel.WaterLevel.GetLevel(1) );
//Salinity
  strcat(text,"  ");
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,39,75,"Salinity:");
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,99,75,text);
ReefAngel.LCD.DrawOutletBox(12, 104, TempRelay);
  static unsigned long LastChange=millis();        // Set the inital time that the last change occurred
  static int Delay = random( 500, 3000);           // Set the initial delay
  static int NewSpeed = MidPoint;                  // Set the initial speed
  static int AntiSpeed = MidPoint;                 // Set the initial anti sync speed
  if ((millis()-LastChange) > Delay)               // Check if the delay has elapsed
    Delay=random(500,5000);                        // If so, come up with a new delay
    int ChangeUp = random(Offset);                 // Amount to go up or down
    if (random(100)<50)                            // 50/50 chance of speed going up or going down
    LastChange=millis();                           // Reset the time of the last change
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
PostPosted: Sun Aug 03, 2014 2:21 pm
lnevo wrote:time_t stopTime = 0;
Lee;
Is the time_t stop Time function in the 1.1.0 libraries or were they pur into the 1.1 1 libraries?
Next
Return to How do I code ...
Users browsing this forum: Google [Bot] and 2 guests
