Watchdog Timer
Version Menu
Relay Expansion Module
Number of Relay Expansion Modules: 1
Standard Menu
Binary sketch size: 27,752 bytes (of a 30,720 byte maximum)
E:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CE:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\\.\COM1 -b57600 -D -V -Uflash:w:C:\Users\ORBITO~1\AppData\Local\Temp\build8438675645450573292.tmp\sketch_aug04b.cpp.hex:i
System wide configuration file is "E:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf"
Using Port : \\.\COM1
Using Programmer : stk500v1
Overriding Baud Rate : 57600
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x0c
avrdude done. Thank you.
it might be restarting. It flashed like it's uploading and then goes black and back to the previous program. Should I avoid programming with the wizard all together with the basic RA?
I thought it was okay since it said the sketch size is 31,200 bytes and the max is 32,256
