portalkey
portalkey
I'm trying to set up custom WiFi Alerts. Added WiFiAlert libraries. Also set up the portal key in the portal. My code won't compile. Getting a "WiFiAlert.cpp:32: error: 'class RA_Wifi' has no member named 'portalkey'" error. How do I add this?
Re: portalkey
I think it was added to 1.1.0 but if not then best to download the dev libraries. Go to www.github.com/reefangel/Libraries select the dev branch and download them on the lower right side
