Wizard refugium light
Re: Wizard refugium light
Is there a way I can be able to adjust my lights from the app instead of having to reload a code everytime
Thanks you. Now next question
How can I set the portal to email me if I loose Internet connection between the angel and the portal. And also how do I set it to send me an email if the temp reach 85 or if the ph reaches 8.5 and can it send text messages
In the portal you can setup notifications for temp and ph. Look under the section portal settings. For sms you need to know the email gateway for your phone provider (they all have one...) and use that for the email address.
For losing internet connectivity, the portal won't do that although maybe roberto can add something for that i recommend setting up an account at www.reeftronics.net and they will send you an email if it can't contact your RA within an hour.
The problem is that I did that but I didn't get the text until 5 hours
From reeftronics or portal?
Was your internet down at the same time? Did you have a power outage or something?
From the portal and yes had a power outage
As Lee said, Reeftronics will email you when it can't reach the RA within an hour and then it will text you if it still can't reach the RA after 4 hours.
Also as Colin said the wizard is a great way to generate some code and then past it into your INO and modify it to your likings.
Don't worry about learning the code, you will get hang of it sooner or later until then there are plenty of people to help.
