I am hoping that you guys can help me with this.
Here is what I want to try:
#define NUMBERS_8x16
ReefAngel.LCD.DrawText(COLOR_ORANGERED, COLOR_DEEPSKYBLUE,14,8, "Fortney Money Pit");
DrawStatus (20,80);
DrawParams (5,40);
DrawParamsa (0,10);
ReefAngel.FeedingModePorts = Port2Bit | Port6Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port6Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port3Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port7Bit;
//ReefAngel.CustomLabels[0]="ReturnPump";
//ReefAngel.CustomLabels[1]="Skimmer";
//ReefAngel.CustomLabels[2]="Kessil";
//ReefAngel.CustomLabels[3]="Nick Fan";
//ReefAngel.CustomLabels[4]="Steph Fan";
//ReefAngel.CustomLabels[5]="Steph ATO";
//ReefAngel.CustomLabels[6]="Refugium";
//ReefAngel.CustomLabels[7]="Nick ATO";
ReefAngel.Relay.DelayedOn( Port2,20 );
ReefAngel.MHLights( Port3,11,00,21,00,0 );
ReefAngel.StandardFan( Port5,776,781 );
ReefAngel.Relay.Set( Port7, !ReefAngel.Relay.Status( Port3 ) );
ReefAngel.SingleATO( true,Port6,10,0 );
ReefAngel.SingleATO( false,Port8,10,0 );
if (ReefAngel.Params.Temp[T2_PROBE]>800) ReefAngel.Relay.Off(Port4);
if (ReefAngel.Params.Temp[T2_PROBE]<790) ReefAngel.Relay.On(Port4);
if (hour()>=8 && hour()<20)
ReefAngel.PWM.SetDaylight( ElseMode(70,30,true) ); // Else Mode at 70% +/- 30% on sync mode
else if (hour()>=20 && hour()<23)
ReefAngel.PWM.SetDaylight( NutrientTransportMode(40,80,200,true) ); // Nutrient Transport 40%minspeed - 80%maxspeed - 200ms
else if (hour()>=23 || hour()<8)
ReefAngel.PWM.SetDaylight( ElseMode(45,15,true) ); // Else Mode at 45% +/- 15% on sync mode
if (hour()>=11 && hour()<22)
ReefAngel.PWM.SetActinic( ElseMode(70,30,false) ); // Else Mode at 70% +/- 30% on anti-sync mode
else if (hour()>=22 || hour()<1)
ReefAngel.PWM.SetActinic( NutrientTransportMode(40,80,200,false) ); // Nutrient Transport 40%minspeed - 80%maxspeed - 200ms
else if (hour()>=1 && hour()<11)
ReefAngel.PWM.SetActinic( ElseMode(45,15,false) ); // Else Mode at 45% +/- 15% on anti-sync mode
ReefAngel.Portal( "imFortney" );
void DrawParamsa(int x, int y){
char buf[16];
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor,x+40,y+10,"Steph:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, x+78, y+10,1);
ReefAngel.LCD.DrawText(APColor,DefaultBGColor,x+40,y+20,"Nick:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),APColor, x+78, y+20,1);
void DrawParams(int x, int y) {
char buf[16];
ReefAngel.LCD.DrawText(COLOR_INDIGO,DefaultBGColor,x+5,y,"Temp:");
ReefAngel.LCD.DrawText(COLOR_INDIGO,DefaultBGColor,x+80, y, "PH:");
// Temp and PH
y+=10;
y+=5;
void DrawStatus(int x, int y) {
int t=x;
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,15,y,"High",Font8x16);
ReefAngel.LCD.DrawLargeText(COLOR_ORANGERED,DefaultBGColor,85,y,"Low",Font8x16);
ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_INDIGO);
} else {
ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_ORANGERED);
ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_ORANGERED);
} else {
ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_INDIGO);
if (WaveSync)
return NewSpeed;
return AntiSpeed;
Thanks for the help guys
