control two jabeo with different speeds
Posted: Tue Sep 16, 2014 7:14 pm
i am trying to use else mode that i stole from another user on here, cant remember who. The two pumps operate at the same speeds as each other or on anti sync just the opposite of each other. I want one tank to have stronger flow than the other as shown below but they wont go at different speeds.
anyone see anything wrong?
Nick
#define NUMBERS_8x16
ReefAngel.LCD.DrawText(COLOR_ORANGERED, COLOR_DEEPSKYBLUE,14,8, "Our Little Oceans");
DrawStatus (20,80);
DrawParams (5,40);
DrawParamsa (0,10);
ReefAngel.FeedingModePorts = Port2Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port6Bit;
ReefAngel.LightsOnPorts = Port3Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port7Bit;
//ReefAngel.CustomLabels[0]="ReturnPump";
//ReefAngel.CustomLabels[1]="Skimmer";
//ReefAngel.CustomLabels[2]="Kessil";
//ReefAngel.CustomLabels[3]="Nick ATO";
//ReefAngel.CustomLabels[4]="Steph Fan";
//ReefAngel.CustomLabels[5]="Steph ATO";
//ReefAngel.CustomLabels[6]="Refugium";
//ReefAngel.CustomLabels[7]="Nick Fan";
ReefAngel.Relay.DelayedOn( Port2,20 );
ReefAngel.MHLights( Port3,12,00,22,00,1 );
ReefAngel.StandardFan( Port5,776,781 );
ReefAngel.Relay.Set( Port7, !ReefAngel.Relay.Status( Port3 ) );
ReefAngel.SingleATO( true,Port6,10,0 );
ReefAngel.SingleATO( false,Port4,10,0 );
if (ReefAngel.Params.Temp[T2_PROBE] >= 781) ReefAngel.Relay.On(Port8); // If sensor 1 temperature >= HighTemp - turn on fan
if (ReefAngel.Params.Temp[T2_PROBE] <= 776) ReefAngel.Relay.Off(Port8); // If sensor 1 temperature <= LowTemp - turn off fan
if (hour()>=12 && hour()<22)
ReefAngel.PWM.SetDaylight( ElseMode(70,30,true) ); // Else Mode at 70% +/- 30% on sync mode
else if (hour()>=22 || hour()<2)
ReefAngel.PWM.SetDaylight( NutrientTransportMode(40,80,200,true) ); // Nutrient Transport 40%minspeed - 80%maxspeed - 200ms
else if (hour()>=2 && hour()<12)
ReefAngel.PWM.SetDaylight( ElseMode(45,15,true) ); // Else Mode at 45% +/- 15% on sync mode
ReefAngel.PWM.SetActinic( ElseMode(45,35,false) ); // Else Mode at 70% +/- 30% on anti-sync mode
ReefAngel.PWM.SetActinic( NutrientTransportMode(25,65,200,false) ); // Nutrient Transport 40%minspeed - 80%maxspeed - 200ms
ReefAngel.PWM.SetActinic( ElseMode(40,15,false) ); // Else Mode at 45% +/- 15% on anti-sync mode
ReefAngel.Portal( "imFortney" );
void DrawParamsa(int x, int y){
char buf[16];
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor,x+40,y+10,"Steph:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, x+78, y+10,1);
ReefAngel.LCD.DrawText(APColor,DefaultBGColor,x+40,y+20,"Nick:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),APColor, x+78, y+20,1);
void DrawParams(int x, int y) {
char buf[16];
ReefAngel.LCD.DrawText(COLOR_INDIGO,DefaultBGColor,x+5,y,"Steph:");
ReefAngel.LCD.DrawText(COLOR_INDIGO,DefaultBGColor,x+80, y, "Nick:");
// Temp and PH
y+=10;
ConvertNumToString(buf, ReefAngel.Params.Temp[T2_PROBE], 10);
ReefAngel.LCD.DrawLargeText(T2TempColor, DefaultBGColor, x+80, y, buf, Num8x16);
y+=5;
void DrawStatus(int x, int y) {
int t=x;
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,15,y,"Nick",Font8x16);
ReefAngel.LCD.DrawLargeText(COLOR_ORANGERED,DefaultBGColor,85,y,"Steph",Font8x16);
ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_ORANGERED);
} else {
ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_INDIGO);
ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_ORANGERED);
} else {
ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_INDIGO);
if (WaveSync)
return NewSpeed;
return AntiSpeed;
}Thanks,
Nick
