Emergency shut off ATO pump in case of high water level
Posted: Sat Sep 20, 2014 3:33 am
Hi guys,
I'm using the water level expansion at the moment to run my ATO. I was wondering if there is some code i can put in that will instantly shut off the ATO port in case the water level gets too high. Say the reef angel gets rebooted and the pump automatically runs for a while, if it goes over say 100% is there a way to override all other rules and shut it off?
This is my ATO code right now:
ReefAngel.WaterLevelATO( Port6,30,90,100 )
However it seems to stop pumping as soon as it hits 90, I thought hitting 90 was when it would turn on and it would then pump until it hit 100? Say the 30 seconds runs out and it still hasn't hit that level, is there a way for it to keep on pumping without manually clearing? Even when i manually clear it seems to not turn back on again once it's over 90.
ANy tips are appreciated guys!
