Re: Wp 25 code
Posted: Mon Sep 22, 2014 12:20 pm
Here's the code converted to use DCPump just to get that out of the way.
The only thing it doesn't do at this moment is allow you to use the portal to change it. We should see the mode and speed change properly and be reflected in the portal (just not in the Internal Memory section).
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 285 );
ReefAngel.DCPump.DaylightChannel=Sync;
ReefAngel.StandardATO( Port1,120 );
ReefAngel.Relay.DelayedOn( Port2,5 );
ReefAngel.StandardHeater( Port3,252,255 );
ReefAngel.StandardLights( Port4,20,0,8,0 );
ReefAngel.StandardLights( Port6,8,10,19,50 );
ReefAngel.StandardLights( Port7,8,5,19,55 );
if (hour()<12)
ReefAngel.StandardLights(Port5, 6, 0, 8, 5);
ReefAngel.StandardLights(Port5, 18, 0, 20, 5);
ReefAngel.DCPump.SetMode( LongPulse,40,10 ); // Long pulse at 40% with 10s pulse on sync mode
if (hour()>=8 && hour()<12)
ReefAngel.DCPump.SetMode( TidalSwell, 60, 0 ); // Tidal Swell at 60% on sync mode
if (hour()>=12 && hour()<16)
ReefAngel.DCPump.SetMode( ReefCrest, 80, 0 ); // ReefCrest at 80% + - 20 on sync mode
if (hour()>=16 && hour()<17)
ReefAngel.DCPump.SetMode( NutrientTransport, 90, 0 ); // Nutrient Transport on sync mode
if (hour()>=17 && hour()<20)
ReefAngel.DCPump.SetMode( ReefCrest, 80, 0 ); // ReefCrest at 75% + - 20 on sync mode
if (hour()>=20)
ReefAngel.Portal( "mask0017" );
