Clouds/Lightning/Storms for 16 Channel PWM Expansion
Re: Clouds/Lightning/Storms for 16 Channel PWM Expansion
You already had the code and the idea in place already... :)
You were just missing the same delay for when the cloud starts.
You need to have it offset by the start and duration.
Try something like this:
      //dim down the far east channels
        PWMChannel[0]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[0],0,60);
        PWMChannel[8]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[8],0,60);
        //dim down the near east channels
        PWMChannel[1]=ReversePWMSlope(cloudstart+DelayTiming1,cloudstart+cloudduration+DelayTiming1,PWMChannel[1],0,60);
        PWMChannel[9]=ReversePWMSlope(cloudstart+DelayTiming1,cloudstart+cloudduration+DelayTiming1,PWMChannel[9],0,60);
[code]
dlplunkett44
Post by dlplunkett44 »
Oh duh.... That makes sense.
So this is my code so far. I made that change and added in a random effect for the speed of clouds. The next thing I'm going to work on (if this looks good) is that I would like to have it to where on the fast clouds, there would be no lightning and the cloud would not last long; maybe a minute or two at most.
int PWMChannel[16];
int DaylightPWMValue;
ReefAngel.Init();
//Initialize controller
 ReefAngel.Use2014Screen();
// Let's use 2014 Screen
ReefAngel.AddPHExpansion();
// pH Expansion Module
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.FeedingModePortsE[0] = Port1Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit;
ReefAngel.Relay.On( Port4 );
// Add support for 16 channel PWM board
ReefAngel.Add16ChPWM();
ReefAngel.SingleATO( true,Port1,90,0 );
ReefAngel.StandardHeater( Port2,820,825 );
ReefAngel.StandardHeater( Port3,815,823 );
ReefAngel.WavemakerRandom( Port5,25,45 );
ReefAngel.WavemakerRandom( Port6,25,45 );
ReefAngel.StandardLights( Port7,21,0,7,0 );
ReefAngel.CO2Control( Port8,670,675 );
ReefAngel.DosingPumpRepeat( Box1_Port1,0,60,10 );
//0 = White Far East
PWMChannel[0]=PWMParabola(8,0,20,30,0,80,0);
//1 = White Near East
PWMChannel[1]=PWMParabola(8,5,20,35,0,80,0);
//2 = White Near West
PWMChannel[2]=PWMParabola(8,10,20,40,0,80,0);
//3 = White Far West
PWMChannel[3]=PWMParabola(8,15,20,45,0,80,0);
//4 = Blue Far East
PWMChannel[4]=PWMParabola(7,15,21,15,0,80,0);
//5 = Blue Near East
PWMChannel[5]=PWMParabola(7,20,21,20,0,80,0);
//6 = Blue Near West
PWMChannel[6]=PWMParabola(7,25,21,25,0,80,0);
//7 = Blue Far West
PWMChannel[7]=PWMParabola(7,30,21,30,0,80,0);
//8 = OCW Far East
PWMChannel[8]=PWMParabola(8,15,20,15,0,60,0);
//9 = OCW Near East
PWMChannel[9]=PWMParabola(8,20,20,20,0,60,0);
//10 = OCW Near West
PWMChannel[10]=PWMParabola(8,25,20,25,0,60,0);
//11 = OCW Far West
PWMChannel[11]=PWMParabola(8,30,20,30,0,60,0);
//12 = Violets
PWMChannel[12]=PWMParabola(8,15,20,30,0,65,0);
//13 = Moonlight Far East
PWMChannel[13]=PWMParabola(20,15,8,30,0,15,0);
//14 = Moonlight Near East and West
PWMChannel[14]=PWMParabola(20,20,8,35,0,15,0);
//15 = Moonlight Far West
PWMChannel[15]=PWMParabola(20,25,8,40,0,15,0);
CheckCloud();
ReefAngel.PWM.Set16Channel(0,PWMChannel[0]);
ReefAngel.PWM.Set16Channel(1,PWMChannel[1]);
ReefAngel.PWM.Set16Channel(2,PWMChannel[2]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[3]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[4]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[5]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[6]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[7]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[8]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[9]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[10]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[11]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[12]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[13]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[14]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[15]);
ReefAngel.AddWifi();
void CheckCloud()
#define Clouds_Every_X_Days 1
 // Minimum number of minutes for cloud duration. Don't use min duration of less than 6
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 7
 // In this example, start could after 8:30am
#define Start_Cloud_After 510
 // In this example, end could before 7:00pm
#define End_Cloud_Before 1140
#define Lightning_Change_per_Cloud 70
 // Channels used by the actinic LEDs on the PWM Expansion module
 // These channels will not be dimmed when the cloud effect is triggered
 // Number is a binary form. B001100 means channel 2 and 3 are used for actinics
 // 0000111100000000
#define Actinic_Channels 384
 // Channels used by the daylight LEDs on the PWM Expansion module
 // These channels will be used for the spike when lightning effect is triggered
 // Number is a binary form. B000011 means channel 0 and 1 are used for daylights
 // 1111000000000000
#define Daylight_Channels 61440
    // Add Random Lightning modes
#define Calm 0    // No lightning
#define Slow 1    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3    // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4   // Like Mega, but with more lightning
  // Example:  { Slow, Fast, Mega, Mega2 } to randomize all four modes.
  // { Mega2 } for just Mega2.  { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
  byte LightningModes[] = { Mega, Mega, Mega2, Calm, Calm, Fast };
   // Add Random Cloud modes
#define FastEast 0  //Short cloud coming from the east
#define FastWest 1  //Short cloud coming from the west
#define SlowEast 2  //Long cloud coming from the east
#define SlowWest 3  //Long cloud coming from the west
  //Example:  {FastEast, FastWest, SlowEast, SlowWest } to randomize all four modes
  byte CloudModes[] = { FastEast, FastWest, FastEast, FastWest, SlowEast, SlowWest };
 static byte cloudchance=255;
 static byte cloudduration=0;
 static int cloudstart=0;
 static byte numclouds=0;
 static byte cloudindex=0;
 static int LastNumMins=0;
 static byte lightningMode=0;
 static boolean chooseCloud=true;
 static byte cloudMode=0;
 static time_t DelayCounter=millis();    // Variable for lightning timing.
 static int DelayTime=random(1000);      // Variable for lightning timimg.
 static time_t DelayCount=millis();
 static int DelayTiming1=2000;
 static int DelayTiming2=4000;
 static int DelayTiming3=6000;
#ifdef forcecloudcalculation
 if (cloudchance==255)
#else
#endif
 randomSeed(millis());    // Seed the random number generator
 cloudchance=random(100);
 // If we have cloud today
 if (cloudchance)
 lightningchance=random(100);
 if (cloudchance)
    //is it time for cloud yet?
	if (chooseCloud)
		cloudMode=CloudModes[random(100)%sizeof(CloudModes)];
		chooseCloud=false;
	switch (cloudMode)
	case FastEast;
        PWMChannel[0]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[0],0,20);
        PWMChannel[8]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[8],0,20);
        PWMChannel[1]=ReversePWMSlope(cloudstart+DelayTiming1,cloudstart+cloudduration+DelayTiming1,PWMChannel[1],0,20);
        PWMChannel[9]=ReversePWMSlope(cloudstart+DelayTiming1,cloudstart+cloudduration+DelayTiming1,PWMChannel[9],0,20);
        //dim down the near west channels
        PWMChannel[2]=ReversePWMSlope(cloudstart+DelayTiming2,cloudstart+cloudduration+DelayTiming2,PWMChannel[2],0,20);
        PWMChannel[10]=ReversePWMSlope(cloudstartDelayTiming2,cloudstart+cloudduration+DelayTiming2,PWMChannel[10],0,20);
        //dim down the far west channels
        PWMChannel[3]=ReversePWMSlope(cloudstart+DelayTiming3,cloudstart+cloudduration+DelayTiming3,PWMChannel[3],0,20);
        PWMChannel[11]=ReversePWMSlope(cloudstart+DelayTiming3,cloudstart+cloudduration+DelayTiming3,PWMChannel[11],0,20);
	break;
	case FastWest;
        PWMChannel[3]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[3],0,20);
        PWMChannel[11]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[11],0,20);
        PWMChannel[2]=ReversePWMSlope(cloudstart+DelayTiming1,cloudstart+cloudduration+DelayTiming1,PWMChannel[2],0,20);
        PWMChannel[10]=ReversePWMSlope(cloudstart+DelayTiming1,cloudstart+cloudduration+DelayTiming1,PWMChannel[10],0,20);
        PWMChannel[1]=ReversePWMSlope(cloudstart+DelayTiming2,cloudstart+cloudduration+DelayTiming2,PWMChannel[1],0,20);
        PWMChannel[9]=ReversePWMSlope(cloudstart+DelayTiming2,cloudstart+cloudduration+DelayTiming2,PWMChannel[9],0,20);
        PWMChannel[0]=ReversePWMSlope(cloudstart+DelayTiming3,cloudstart+cloudduration+DelayTiming3,PWMChannel[0],0,20);
        PWMChannel[8]=ReversePWMSlope(cloudstart+DelayTiming3,cloudstart+cloudduration+DelayTiming3,PWMChannel[8],0,20);
	break;
	case SlowEast;
        PWMChannel[0]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[0],0,180);
        PWMChannel[8]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[8],0,180);
        PWMChannel[1]=ReversePWMSlope(cloudstart+DelayTiming1,cloudstart+cloudduration+DelayTiming1,PWMChannel[1],0,180);
        PWMChannel[9]=ReversePWMSlope(cloudstart+DelayTIming1,cloudstart+cloudduration+DelayTiming1,PWMChannel[9],0,180);
        PWMChannel[2]=ReversePWMSlope(cloudstart+DelayTiming2,cloudstart+cloudduration+DelayTiming2,PWMChannel[2],0,180);
        PWMChannel[10]=ReversePWMSlope(cloudstart+DelayTiming2,cloudstart+cloudduration+DelayTiming2,PWMChannel[10],0,180);
        PWMChannel[3]=ReversePWMSlope(cloudstart+DelayTiming3,cloudstart+cloudduration+DelayTiming3,PWMChannel[3],0,180);
        PWMChannel[11]=ReversePWMSlope(cloudstart+DelayTiming3,cloudstart+cloudduration+DelayTiming3,PWMChannel[11],0,180);
	break;
	case SlowWest;
        PWMChannel[3]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[3],0,180);
        PWMChannel[11]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[11],0,180);
        PWMChannel[2]=ReversePWMSlope(cloudstart+DelayTiming1,cloudstart+cloudduration+DelayTiming1,PWMChannel[2],0,180);
        PWMChannel[10]=ReversePWMSlope(cloudstart+DelayTiming1,cloudstart+cloudduration+DelayTiming1,PWMChannel[10],0,180);
        PWMChannel[1]=ReversePWMSlope(cloudstart+DelayTiming2,cloudstart+cloudduration+DelayTiming2,PWMChannel[1],0,180);
        PWMChannel[9]=ReversePWMSlope(cloudstart+DelayTiming2,cloudstart+cloudduration+DelayTiming2,PWMChannel[9],0,180);
        PWMChannel[0]=ReversePWMSlope(cloudstart+DelayTiming3,cloudstart+cloudduration+DelayTiming3,PWMChannel[0],0,180);
        PWMChannel[8]=ReversePWMSlope(cloudstart+DelayTiming3,cloudstart+cloudduration+DelayTiming3,PWMChannel[8],0,180);
	break;
   	  chooseCloud=true; // Reset the flag to choose a new cloud type
int newdata=4095;
byte channel=0;
if (chooseLightning)
        chooseLightning=false;
      switch (lightningMode)
      case Calm:
        break;
      case Mega:
        // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
        if (lightning		cloudstart+cloudduration,100,0,180))<1 && (millis()-DelayCounter)>DelayTime)
          int a=random(1,5); // Pick a number of consecutive flashes from 1 to 4.
          for (int i=0; i<a; i++)
            for (int g=0;g<16;g++)
              if (bitRead(Daylight_Channels,g)==1)
                  newdata=random(DaylightPWMValue*40.95, 4095);
                  channel=g;
                  Wire.beginTransmission(0x41);
                  Wire.write(0x8+(4*channel));
                  Wire.write(newdata&0xff);
                  Wire.write(newdata>>8);
                  Wire.endTransmission();
            int randy=random(20,80);    // Random number for a delay
            if (randy>71) randy=((randy-70)/2)*100;    // Small chance of a longer delay
            delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
             for (int h=0;h<16;h++)
                if (bitRead(Daylight_Channels,h)==1)
                    newdata=DaylightPWMValue*40.95;
                    channel=h;
            delay(random(30,50));                // Wait from 30 to 49 ms
            wdt_reset();
          DelayCounter=millis();    // If we just had a round of flashes, then lets put in a longer delay
          DelayTime=random(1000);   // of up to a second for dramatic effect before we do another round.
        break;
      case Mega2:
        // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
        if (lightningchance && random(ReversePWMSlope(cloudstart,cloudstart+cloudduration,100,0,180))<2 && (millis()-DelayCounter)>DelayTime)
      for (int k=0;k<16;k++)
      if (bitRead(Daylight_Channels,k)==1)
          channel=k;
      for (int l=0;l<16;l++)
      if (bitRead(Daylight_Channels,l)==1)
          channel=l;
            wdt_reset();
        break;
      case Fast:
            for (int e=0;e<16;e++)
      if (bitRead(Daylight_Channels,e)==1)
          channel=e;
       for (int f=0;f<16;f++)
      if (bitRead(Daylight_Channels,f)==1)
          channel=f;
            wdt_reset();
        break;
      case Slow:
        // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
          else lightningstatus=0;
          if (lightningstatus)
            newdata=4095;
      for (int c=0;c<16;c++)
      if (bitRead(Daylight_Channels,c)==1)
         channel=c;
      newdata=0;
      for (int d=0;d<16;d++)
      if (bitRead(Daylight_Channels,d)==1)
         channel=d;
          delay(1);
        break;
      default:
        break;
       cloudindex++;
       if (cloudindex < numclouds)
  // Write the times of the next cloud, next lightning, and cloud duration to the screen.
       int x=0;
      else x=17;
      else x=35;
 if (lightningchance)
 int x=0;
 if (((cloudstart+(cloudduration/2))/60)>=10) x=51;
 else x=57;
 if (((cloudstart+(cloudduration/2))%60)>=10) x=69;
 else x=75;
 ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));
 cstart*=60;
 cend*=60;
 if (n>cend) return PWMStart;
dlplunkett44
So I haven't had a lot of time to work on this, but I think I have it doing most of what I want as far as the clouds go. My code is posted below. I do have a few concerns though. Is my code using 12-bit resolution for the dimming for light cycles as well as for clouds? When it is dimming for the clouds how quickly is it sending new data to the dimming expansion (once a second, minute, etc)?
Also, how would I be able to change the shortcloudduration to seconds instead of minutes?
int PWMChannel[16];
ReefAngel.Init();
//4 = Blue Far East
//7 = Blue Far West
//8 = OCW Far East
//9 = OCW Near East
//11 = OCW Far West
//12 = Violets
CheckCloud();
void CheckCloud()
 // Minimum number of minutes for long cloud duration. Don't use min duration of less than 6
 // Maximum number of minutes for long cloud duration. Don't use max duration of more than 255
 // Minimum number of minutes for short cloud duration.
#define Min_ShortCloud_Duration 1
 // Maximum number of minutes for short cloud duration.
#define Max_ShortCloud_Duration 2
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 12
 // Minimum number of short clouds that can happen per day
//#define Min_ShortClouds_per_Day 3
 // Maximum number of short clouds that can happen per day
//#define Max_ShortClouds_per_day 10
 // In this example, start could after 8:30am (in minutes since midnight)
 // In this example, end could before 7:00pm (in minutes since midnight)
 // Percentage chance of a lightning happen for every long cloud
#define Lightning_Change_per_Cloud 80
 // 0000111100000000
 // 1111000000000000
  // Set which lightning modes you want to use
#define FastEast 0  //Short cloud coming from the east - No Lightning
#define FastWest 1  //Short cloud coming from the west - No Lightning
#define SlowEast 2  //Long cloud coming from the east - Chance of Lightning
#define SlowWest 3  //Long cloud coming from the west - Chance of Lightning
  // Set which cloud modes you want to use
  byte CloudModes[] = { FastEast, FastWest, FastEast, FastWest, FastEast, FastWest, SlowEast, SlowWest };
#else
#endif
 if (cloudchance)
 // pick a random number for the short cloud duration
 shortcloudduration=random(Min_ShortCloud_Duration,Max_ShortCloud_Duration);
 if (cloudchance)
	if (chooseCloud)
		chooseCloud=false;
	switch (cloudMode)
	case FastEast;
        PWMChannel[0]=ReversePWMSlope(cloudstart,cloudstart+shortcloudduration,PWMChannel[0],0,20);
        PWMChannel[8]=ReversePWMSlope(cloudstart,cloudstart+shortcloudduration,PWMChannel[8],0,20);
        PWMChannel[1]=ReversePWMSlope(cloudstart+DelayTiming1,cloudstart+shortcloudduration+DelayTiming1,PWMChannel[1],0,20);
        PWMChannel[9]=ReversePWMSlope(cloudstart+DelayTiming1,cloudstart+shortcloudduration+DelayTiming1,PWMChannel[9],0,20);
        PWMChannel[2]=ReversePWMSlope(cloudstart+DelayTiming2,cloudstart+shortcloudduration+DelayTiming2,PWMChannel[2],0,20);
        PWMChannel[10]=ReversePWMSlope(cloudstartDelayTiming2,cloudstart+shortcloudduration+DelayTiming2,PWMChannel[10],0,20);
        PWMChannel[3]=ReversePWMSlope(cloudstart+DelayTiming3,cloudstart+shortcloudduration+DelayTiming3,PWMChannel[3],0,20);
        PWMChannel[11]=ReversePWMSlope(cloudstart+DelayTiming3,cloudstart+shortcloudduration+DelayTiming3,PWMChannel[11],0,20);
	break;
	case FastWest;
        PWMChannel[3]=ReversePWMSlope(cloudstart,cloudstart+shortcloudduration,PWMChannel[3],0,20);
        PWMChannel[11]=ReversePWMSlope(cloudstart,cloudstart+shortcloudduration,PWMChannel[11],0,20);
        PWMChannel[2]=ReversePWMSlope(cloudstart+DelayTiming1,cloudstart+shortcloudduration+DelayTiming1,PWMChannel[2],0,20);
        PWMChannel[10]=ReversePWMSlope(cloudstart+DelayTiming1,cloudstart+shortcloudduration+DelayTiming1,PWMChannel[10],0,20);
        PWMChannel[1]=ReversePWMSlope(cloudstart+DelayTiming2,cloudstart+shortcloudduration+DelayTiming2,PWMChannel[1],0,20);
        PWMChannel[9]=ReversePWMSlope(cloudstart+DelayTiming2,cloudstart+shortcloudduration+DelayTiming2,PWMChannel[9],0,20);
        PWMChannel[0]=ReversePWMSlope(cloudstart+DelayTiming3,cloudstart+shortcloudduration+DelayTiming3,PWMChannel[0],0,20);
        PWMChannel[8]=ReversePWMSlope(cloudstart+DelayTiming3,cloudstart+shortcloudduration+DelayTiming3,PWMChannel[8],0,20);
	break;
	case SlowEast;
	break;
	case SlowWest;
	break;
int newdata=4095;
byte channel=0;
      case Calm:
        break;
      case Mega:
                  channel=g;
                    channel=h;
            wdt_reset();
        break;
      case Mega2:
          channel=k;
          channel=l;
            wdt_reset();
        break;
      case Fast:
          channel=e;
          channel=f;
            wdt_reset();
        break;
      case Slow:
            newdata=4095;
         channel=c;
      newdata=0;
         channel=d;
          delay(1);
        break;
      default:
        break;
       cloudindex++;
       int x=0;
      else x=17;
      else x=35;
 int x=0;
 else x=57;
 else x=75;
 cstart*=60;
 cend*=60;
When dimming for the clouds, it sends data every second.
When dimming on regular parabola, it sends once a minute.
Yu would have to change the entire logic to make it in seconds, but when a cloud is activated it takes 20 seconds to ramp down and 20 seconds to ramp up. That's already 40 seconds as it is.
Unless you were planning to have a really fast ramp up/down, the benefit to refactor the entire code is not worth it.
dlplunkett44
What I'm trying to recreate is the clouds that you see on a sunny day that are small and pass by really quickly.
The sun dims down very quickly, like in 1-2 seconds and the cloud may last for 5-30 seconds, and then the sun comes back just as quick.
Also, unless its a really slow dimming, the full 12-bit resolution is not being used if it is just updating once a minute (or once a second for the clouds).
Which parts would have to be changed?
Would this be too taxing for the controller?
AlanM
Post by AlanM »
rimai wrote:When dimming for the clouds, it sends data every second.
I hven't been following the whole thread, but if you use ReefAngel.PWM.PWMParabola functions, they now use the HighRes versions and send once per second in the dev libraries. If you're calling PWMParabola directly from Globals then you can instead call PWMParabolaHighRes and get values once per second.
The output is different, though. In both of them you give an input of startPWM and endPWM as a percent, but the output of PWMParabola will be in percent and change once per minute.
The output of PWMParabolaHighRes will be in values from 0 to 4095 where 4095 is 100 percent, gets updated each second, and can be written to the 16 channel dimming expansion directly.
If you want a really fast cloud, you might as well just recreate a new ReversePWMSlope to use milliseconds instead of seconds and use the regular ReversePWMSlope for long clouds and your new ReversePWMSlope for fast clouds.
You code would also need to be conditional to call one of these depending on your preference.
dlplunkett44
As far as the high res stuff, would this be right?
PWMChannel[0]=PWMParabolaHighRes(8,0,20,30,0,80,0);
PWMChannel[1]=PWMParabolaHighRes(8,5,20,35,0,80,0);
PWMChannel[2]=PWMParabolaHighRes(8,10,20,40,0,80,0);
PWMChannel[3]=PWMParabolaHighRes(8,15,20,45,0,80,0);
//4 = Blue Far East
PWMChannel[4]=PWMParabolaHighRes(7,15,21,15,0,80,0);
PWMChannel[5]=PWMParabolaHighRes(7,20,21,20,0,80,0);
PWMChannel[6]=PWMParabolaHighRes(7,25,21,25,0,80,0);
//7 = Blue Far West
PWMChannel[7]=PWMParabolaHighRes(7,30,21,30,0,80,0);
//8 = OCW Far East
PWMChannel[8]=PWMParabolaHighRes(8,15,20,15,0,60,0);
//9 = OCW Near East
PWMChannel[9]=PWMParabolaHighRes(8,20,20,20,0,60,0);
PWMChannel[10]=PWMParabolaHighRes(8,25,20,25,0,60,0);
//11 = OCW Far West
PWMChannel[11]=PWMParabolaHighRes(8,30,20,30,0,60,0);
//12 = Violets
PWMChannel[12]=PWMParabolaHighRes(8,15,20,30,0,65,0);
PWMChannel[13]=PWMParabolaHighRes(20,15,8,30,0,15,0);
PWMChannel[14]=PWMParabolaHighRes(20,20,8,35,0,15,0);
PWMChannel[15]=PWMParabolaHighRes(20,25,8,40,0,15,0);
or would I have to convert the 80, 60, 65, 15 to what they would be 0-4095?
AlanM
Post by AlanM »
rimai wrote:If you want a really fast cloud, you might as well just recreate a new ReversePWMSlope to use milliseconds instead of seconds and use the regular ReversePWMSlope for long clouds and your new ReversePWMSlope for fast clouds.
This is a great idea. I don't know how fast each loop will be with all that stuff in it, but I'd be interested in seeing how fast you can send new values to the 16 channel PWM for dimming. 8)
AlanM
Post by AlanM »
I don't know if that will be right what you posted above because I don't know for sure what you're doing with those PWMChannel array values. Your inputs are fine as 80, 60, 65, but the PWMChannel array will not have larger numbers.
I suspect that you'll need to change something further down to account for the fact that those PWMChannel[x] now have values up to 4095 in them instead of up to 100 and maybe not multiply something by 40.95 before you're writing the values to the dimming expansion, but I'm not positive.
dlplunkett44
So this is how I would write the values?
PWMChannel[0]=PWMParabolaHighRes(8,0,20,30,0,3276,0);  //80%
PWMChannel[1]=PWMParabolaHighRes(8,5,20,35,0,3276,0);  //80%
PWMChannel[2]=PWMParabolaHighRes(8,10,20,40,0,3276,0);  //80%
PWMChannel[3]=PWMParabolaHighRes(8,15,20,45,0,3276,0);  //80%
//4 = Blue Far East
PWMChannel[4]=PWMParabolaHighRes(7,15,21,15,0,3276,0);  //80%
PWMChannel[5]=PWMParabolaHighRes(7,20,21,20,0,3276,0);  //80%
PWMChannel[6]=PWMParabolaHighRes(7,25,21,25,0,3276,0);  //80%
//7 = Blue Far West
PWMChannel[7]=PWMParabolaHighRes(7,30,21,30,0,3276,0);  //80%
//8 = OCW Far East
PWMChannel[8]=PWMParabolaHighRes(8,15,20,15,0,2457,0);  //60%
//9 = OCW Near East
PWMChannel[9]=PWMParabolaHighRes(8,20,20,20,0,2457,0);  //60%
PWMChannel[10]=PWMParabolaHighRes(8,25,20,25,0,2457,0);  //60%
//11 = OCW Far West
PWMChannel[11]=PWMParabolaHighRes(8,30,20,30,0,2457,0);  //60%
//12 = Violets
PWMChannel[12]=PWMParabolaHighRes(8,15,20,30,0,2662,0);  //65%
PWMChannel[13]=PWMParabolaHighRes(20,15,8,30,0,614,0);  //15%
PWMChannel[14]=PWMParabolaHighRes(20,20,8,35,0,614,0);  //15%
PWMChannel[15]=PWMParabolaHighRes(20,25,8,40,0,614,0);  //15%
CheckCloud();
AlanM
Post by AlanM »
No, youre getting it backwards. The highres functions take percents as arguments and return values up to 4095. They dont take those values as arguments.
dlplunkett44
ok, so it should be like this, right?
PWMChannel[0]=PWMParabolaHighRes(8,0,20,30,0,80,0);  //80%
PWMChannel[1]=PWMParabolaHighRes(8,5,20,35,0,80,0);  //80%
PWMChannel[2]=PWMParabolaHighRes(8,10,20,40,0,80,0);  //80%
PWMChannel[3]=PWMParabolaHighRes(8,15,20,45,0,80,0);  //80%
//4 = Blue Far East
PWMChannel[4]=PWMParabolaHighRes(7,15,21,15,0,80,0);  //80%
PWMChannel[5]=PWMParabolaHighRes(7,20,21,20,0,80,0);  //80%
PWMChannel[6]=PWMParabolaHighRes(7,25,21,25,0,80,0);  //80%
//7 = Blue Far West
PWMChannel[7]=PWMParabolaHighRes(7,30,21,30,0,80,0);  //80%
//8 = OCW Far East
PWMChannel[8]=PWMParabolaHighRes(8,15,20,15,0,60,0);  //60%
//9 = OCW Near East
PWMChannel[9]=PWMParabolaHighRes(8,20,20,20,0,60,0);  //60%
PWMChannel[10]=PWMParabolaHighRes(8,25,20,25,0,60,0);  //60%
//11 = OCW Far West
PWMChannel[11]=PWMParabolaHighRes(8,30,20,30,0,60,0);  //60%
//12 = Violets
PWMChannel[12]=PWMParabolaHighRes(8,15,20,30,0,65,0);  //65%
PWMChannel[13]=PWMParabolaHighRes(20,15,8,30,0,15,0);  //15%
PWMChannel[14]=PWMParabolaHighRes(20,20,8,35,0,15,0);  //15%
PWMChannel[15]=PWMParabolaHighRes(20,25,8,40,0,15,0);  //15%
CheckCloud();
if it is taking percents would it only have 100 levels of resolution or would it take 46.29% for example and convert that to 1896?
dlplunkett44
Also, as far as the new reversePWMSlope function goes, would this look good?
int FastReversePWMSlope(long fcstart,long fcend,byte fPWMStart,byte fPWMEnd, byte fclength)
 long n=1000*elapsedSecsToday(now());
 fcstart*=60000;
 fcend*=60000;
 if (n<fcstart) return fPWMStart;
 if (n>=fcstart && n<=(fcstart+fclength)) return map(n,fcstart,fcstart+fclength,fPWMStart,fPWMEnd);
 if (n>(fcstart+fclength) && n<(fcend-fclength)) return fPWMEnd;
 if (n>=(fcend-fclength) && n<=fcend) return map(n,fcend-fclength,fcend,fPWMEnd,fPWMStart);
 if (n>fcend) return fPWMStart;
Thanks again for all your help!
AlanM
Post by AlanM »
Sorry I went afk from this forum. Is it working for you now?
