Clouds/Lightning/Storms for 16 Channel PWM Expansion
dlplunkett44
Re: Clouds/Lightning/Storms for 16 Channel PWM Expansion
Post by dlplunkett44 »
So this is how I would write the values?
//0 = White Far East
PWMChannel[0]=PWMParabolaHighRes(8,0,20,30,0,3276,0);  //80%
//1 = White Near East
PWMChannel[1]=PWMParabolaHighRes(8,5,20,35,0,3276,0);  //80%
//2 = White Near West
PWMChannel[2]=PWMParabolaHighRes(8,10,20,40,0,3276,0);  //80%
//3 = White Far West
PWMChannel[3]=PWMParabolaHighRes(8,15,20,45,0,3276,0);  //80%
//4 = Blue Far East
PWMChannel[4]=PWMParabolaHighRes(7,15,21,15,0,3276,0);  //80%
//5 = Blue Near East
PWMChannel[5]=PWMParabolaHighRes(7,20,21,20,0,3276,0);  //80%
//6 = Blue Near West
PWMChannel[6]=PWMParabolaHighRes(7,25,21,25,0,3276,0);  //80%
//7 = Blue Far West
PWMChannel[7]=PWMParabolaHighRes(7,30,21,30,0,3276,0);  //80%
//8 = OCW Far East
PWMChannel[8]=PWMParabolaHighRes(8,15,20,15,0,2457,0);  //60%
//9 = OCW Near East
PWMChannel[9]=PWMParabolaHighRes(8,20,20,20,0,2457,0);  //60%
//10 = OCW Near West
PWMChannel[10]=PWMParabolaHighRes(8,25,20,25,0,2457,0);  //60%
//11 = OCW Far West
PWMChannel[11]=PWMParabolaHighRes(8,30,20,30,0,2457,0);  //60%
//12 = Violets
PWMChannel[12]=PWMParabolaHighRes(8,15,20,30,0,2662,0);  //65%
//13 = Moonlight Far East
PWMChannel[13]=PWMParabolaHighRes(20,15,8,30,0,614,0);  //15%
//14 = Moonlight Near East and West
PWMChannel[14]=PWMParabolaHighRes(20,20,8,35,0,614,0);  //15%
//15 = Moonlight Far West
PWMChannel[15]=PWMParabolaHighRes(20,25,8,40,0,614,0);  //15%
CheckCloud();
ReefAngel.PWM.Set16Channel(0,PWMChannel[0]);
ReefAngel.PWM.Set16Channel(1,PWMChannel[1]);
ReefAngel.PWM.Set16Channel(2,PWMChannel[2]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[3]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[4]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[5]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[6]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[7]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[8]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[9]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[10]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[11]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[12]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[13]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[14]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[15]);
AlanM
Post by AlanM »
No, youre getting it backwards. The highres functions take percents as arguments and return values up to 4095. They dont take those values as arguments.
dlplunkett44
ok, so it should be like this, right?
PWMChannel[0]=PWMParabolaHighRes(8,0,20,30,0,80,0);  //80%
PWMChannel[1]=PWMParabolaHighRes(8,5,20,35,0,80,0);  //80%
PWMChannel[2]=PWMParabolaHighRes(8,10,20,40,0,80,0);  //80%
PWMChannel[3]=PWMParabolaHighRes(8,15,20,45,0,80,0);  //80%
//4 = Blue Far East
PWMChannel[4]=PWMParabolaHighRes(7,15,21,15,0,80,0);  //80%
PWMChannel[5]=PWMParabolaHighRes(7,20,21,20,0,80,0);  //80%
PWMChannel[6]=PWMParabolaHighRes(7,25,21,25,0,80,0);  //80%
//7 = Blue Far West
PWMChannel[7]=PWMParabolaHighRes(7,30,21,30,0,80,0);  //80%
//8 = OCW Far East
PWMChannel[8]=PWMParabolaHighRes(8,15,20,15,0,60,0);  //60%
//9 = OCW Near East
PWMChannel[9]=PWMParabolaHighRes(8,20,20,20,0,60,0);  //60%
PWMChannel[10]=PWMParabolaHighRes(8,25,20,25,0,60,0);  //60%
//11 = OCW Far West
PWMChannel[11]=PWMParabolaHighRes(8,30,20,30,0,60,0);  //60%
//12 = Violets
PWMChannel[12]=PWMParabolaHighRes(8,15,20,30,0,65,0);  //65%
PWMChannel[13]=PWMParabolaHighRes(20,15,8,30,0,15,0);  //15%
PWMChannel[14]=PWMParabolaHighRes(20,20,8,35,0,15,0);  //15%
PWMChannel[15]=PWMParabolaHighRes(20,25,8,40,0,15,0);  //15%
CheckCloud();
if it is taking percents would it only have 100 levels of resolution or would it take 46.29% for example and convert that to 1896?
dlplunkett44
Also, as far as the new reversePWMSlope function goes, would this look good?
int FastReversePWMSlope(long fcstart,long fcend,byte fPWMStart,byte fPWMEnd, byte fclength)
 long n=1000*elapsedSecsToday(now());
 fcstart*=60000;
 fcend*=60000;
 if (n<fcstart) return fPWMStart;
 if (n>=fcstart && n<=(fcstart+fclength)) return map(n,fcstart,fcstart+fclength,fPWMStart,fPWMEnd);
 if (n>(fcstart+fclength) && n<(fcend-fclength)) return fPWMEnd;
 if (n>=(fcend-fclength) && n<=fcend) return map(n,fcend-fclength,fcend,fPWMEnd,fPWMStart);
 if (n>fcend) return fPWMStart;
Thanks again for all your help!
AlanM
Post by AlanM »
Sorry I went afk from this forum. Is it working for you now?
